查看: 3717|回复: 0
How or When I can get CGNS Paralle Abillity?
发表于 2007-6-12 23:22:41 | 显示全部楼层 |阅读模式
I get to know that CGNS has switched to HDF because of ADF has no parallel abillity, the switch has discussed since 2004 in aiaa04-1088,but I havn';t find any clue about paralle API,even in CGNSlib ver2.5 rescently distributed. so could any one tell me how I can implement CGNS parallel if it has parallel abillity, or when the parallel problem can be solved?
