查看: 3453|回复: 3
初学菜鸟跪求指点-这种情况是什么问题
发表于 2007-1-9 22:37:49 | 显示全部楼层 |阅读模式
    从论坛上下载了一个valve.c的例子,用 Fluent 6.2.16按照帮助试了一下,先读入case和data文件,然后Define -User Defined-Functions-Interpreted,结果出现下面的情况。
    udf的解释和编译怎么用啊,像这个例子是怎么样的一个使用流程,用turboc可以编译吗。请有经验的前辈指点一下。
Reading "E:\valve\valve.cas"...
     279 quadrilateral cells, zone  2, binary.
    1040 quadrilateral cells, zone  3, binary.
    5994 triangular cells, zone  4, binary.
      23 2D wall faces, zone 23, binary.
      29 2D interior faces, zone 21, binary.
    8860 2D interior faces, zone 19, binary.
    2014 2D interior faces, zone 17, binary.
     509 2D interior faces, zone  1, binary.
      44 2D wall faces, zone  5, binary.
      23 2D interface faces, zone  6, binary.
      45 2D interface faces, zone  7, binary.
       6 2D wall faces, zone  8, binary.
      10 2D wall faces, zone  9, binary.
      68 2D wall faces, zone 10, binary.
      26 2D wall faces, zone 11, binary.
      37 2D wall faces, zone 12, binary.
      56 2D axis faces, zone 13, binary.
      26 2D axis faces, zone 14, binary.
      31 2D pressure-outlet faces, zone 15, binary.
      40 2D mass-flow-inlet faces, zone 16, binary.
      40 2D interior faces, zone 18, binary.
      23 interface face parents, binary.
      29 interface face parents, binary.
      25 shape nodes, zone  6, binary.
      46 shape nodes, zone  7, binary.
    4525 nodes, binary.
    4525 node flags, binary.
Building...
     grid,
     materials,
     interface,
     domains,
mixture
     zones,
Opening library "libudf"...
Error: open_udf_library: 系统找不到指定的路径。
Error Object: ()
default-interior:019
default-interior:017
default-interior:001
default-interior
inlet
outlet
axis
def_axis
def_wall_.077625
inlet_wall
poppet
def_wall_x.31
curved_wall
int_int
ext_intf
wall
wall-22
wall-23
def_zone
inlet_zone
outlet_zone
interior-21
     grid interfaces,
     dynamic zones,
        poppet
Warning: incorrect cg motion UDF valve::libudf on zone 10 (assuming no motion)
        int_int
        def_axis
     shell conduction zones,
Done.
Reading "E:\valve\valve.dat"...
Done.
cpp-IC:\Fluent.Inc\fluent6.2.16/src-IC:\Fluent.Inc\fluent6.2.16/cortex/src-IC:\Fluent.Inc\fluent6.2.16/client/src -IC:\Fluent.Inc\fluent6.2.16/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" E:\valve\valve.c
Error: E:\valve\valve.c: line 8: parse error.
[color=&#35;DC143C]文字[color=&#35;DC143C]文字
发表于 2007-1-10 12:45:19 | 显示全部楼层
初学菜鸟跪求指点-这种情况是什么问题
可能是你没有安装VC
发表于 2007-1-10 12:47:26 | 显示全部楼层
初学菜鸟跪求指点-这种情况是什么问题
另外你应该用编译,而不应该是通绎
 楼主| 发表于 2007-1-10 18:32:27 | 显示全部楼层
初学菜鸟跪求指点-这种情况是什么问题
我装vc++6了,但是编译的时候也是有错。
