查看: 119597|回复: 48
[分享]UIUC Airfoil Data Site(翼型数据库大全)
发表于 2007-4-6 20:41:32 | 显示全部楼层 |阅读模式
LBHIDDEN[0]LBHIDDEN[这个贴子最后由yxjbuaa在 2007/05/11 08:27pm 第 3 次编辑]
数据库网址:
http://www.uiuc.edu/ph/www/m-selig/ads.html
下面是关于该数据库的详细介绍,鉴于很多人都很需要一些数据,我下载并上传上来了,也就是UIUC Database Version 2.0,这里面有多达1550种的叶型数据,还有一些数据不在这里面,不过网站上有更新,大家可以按照上面的网址去下载。
Download the executable program: AIRFOIL1.EXE (42 kb). 8/6/98
Hanley Innovations
Aerodynamics software from Patrick Hanley includes - VisualFoil, ModelFoil, WingSections, AirfoilBrowser. Most of these packages make use of the UIUC airfoil coordinates database.
FoilSim from NASA Glenn Research Center
A neat NASA web site where you can interactively change an airfoil';s camber, angle of attack and other parameters and watch the resulting flow, pressure, and lift. Click on the "FoilSim applet".
CompuFoil ~3D~
Airfoil geometry modification and plotting software for foam cutting and rib layout.
CNC@NET Software for CNC Foam Cutting (in French)
Someone gave me this link and had this to say: "I think some people may be interested in the CNC software developed in France for CNC foam wing cutting. The site is in French, but it is an excellent program, best of all it is free."
发表于 2012-11-8 13:23:50 | 显示全部楼层
试试其他的
原来又一个很有名的网站:www.worldofkrauss.com, 提供JavaFoil计算得到的性能数据。但可惜这个网站关闭了之后就再没开过。
其他选择可以试试:www.upwhirlwind.com
或者www.airfoiltools.com
至于风洞数据,相信在哪儿都很难找。毕竟是大把大把的钱换来的。
回复 支持 1 反对 0
使用道具 举报
 楼主| 发表于 2007-4-6 20:49:02 | 显示全部楼层
[这个贴子最后由yxjbuaa在 2007/04/06 08:52pm 第 1 次编辑]
翼型数据资源列表
Archives(该数据包是一个软件或者集成数据包,包括1550个翼型数据)
Unix tar archive of Version 2.0 (1550 airfoils):
[coord_seligFmt.tar.gz 618 kb]
Note that the files are in the Unix EOF format.
Zip archive:
[coord_seligFmt.zip 911 kb]
Note that the files are in the DOS EOF format.
Coordinates in "Selig" format (individual files): Directory listing
Coordinates in AutoCAD "dwg" format (individual files and large tar file) thanks to Bill Gilmore: Directory listing
(以下是大量翼型的详细坐标数据和图片)
Update Directory (zero airfoils so far)
The update directory includes additions not yet included in the Version 2.0 archives above or A-Z listing below. Several updates from David Lednicer (for details see "Last update" link above).
HS1404.DAT \ HS1 family of prop airfoils from US Patent No. 4,519,746
HS1430.DAT \ HS1 family of prop airfoils from US Patent No. 4,519,746
HS1606.DAT \ HS1 family of prop airfoils from US Patent No. 4,519,746
HS1620.DAT \ HS1 family of prop airfoils from US Patent No. 4,519,746
HS1708.DAT \ HS1 family of prop airfoils from US Patent No. 4,519,746
HS1712.DAT \ HS1 family of prop airfoils from US Patent No. 4,519,746
BACNLF.DAT \ Boeing high speed natural laminar flow airfoil from a European patent (EP 0111785A1)
HOR04.DAT \ Onera propeller blade airfoils from US patent 4,773,825
HOR07.DAT \ Onera propeller blade airfoils from US patent 4,773,825
HOR12.DAT \ Onera propeller blade airfoils from US patent 4,773,825
HOR20.DAT \ Onera propeller blade airfoils from US patent 4,773,825
S102B.DAT \ Dan Somers airfoil for the Toyota general aviation airplane
S102S.DAT \ Dan Somers airfoil for the Toyota general aviation airplane
US06607164__.pdf The Toyota patent
DU84132V.DAT \ Airfoil measured from an ASW22 wing
HQ17.DAT \ Airfoil measured from an ASW22 wing
L1003.DAT \ Liebeck high lift airfoil
LA5055.DAT \ Liebeck high lift airfoil
S8064 \ Designed for Q-500 (Q500) pylon racing (12.33%). Used on the Hobbico/Great Planes Viper Q-500 model airplane.
S8065 \ Designed for Q-40 pylon racing (11%).
S8066 \ Designed for Q-40 pylon racing (10%).
GNU General Public License
If you want to use this data in a commercial product or other product (shareware, freeware, etc.), then use the GNU General Public License. In a nutshell this states that you can use the data so long as you acknowledge this source, include the GNU General Public License to cover the use of the airfoil data, do not restrict the user from giving the data away, and do not charge any more than your cost of distributing the data.
2032c.dat \ Dillner 20-32-C low Reynolds number airfoil \ 2032c.gif\ \ \
A .  B .  C .  D .  E .  F .  G .  H .  I .  J .  K .  L .  M .  N .  O .  P .  Q .  R .  S .  T .  U .  V .  W .  X .  Y .  Z top
a18.dat \ Archer A18 F1C free flight airfoil(original) \ a18.gif\ \ \ Low Reynolds number data
a18sm.dat \ Archer A18 F1C free flight airfoil (smoothed) \ a18sm.gif\ \ \ Low Reynolds number data
a63a108c.dat \ NASA/AMES modification of the NACA 63A-108 airfoil \ a63a108c.gif\ \ \
ag03.dat \ Drela AG03 (flat aft bottom) airfoil \ ag03.gif\ \ \ Ref [3]
ag04.dat \ Drela AG04 airfoil \ ag04.gif\ \ \ Ref [3]
ag08.dat \ Drela AG08 airfoil \ ag08.gif\ \ \ Ref [3]
ag09.dat \ Drela AG09 airfoil \ ag09.gif\ \ \ Ref [3]
ag10.dat \ Drela AG10 airfoil \ ag10.gif\ \ \ Ref [3]
ag11.dat \ Drela AG11 airfoil \ ag11.gif\ \ \ Ref [3]
ag12.dat \ Drela AG12 airfoil \ ag12.gif\ \ \ Ref [3]
ag13.dat \ Drela AG13 airfoil \ ag13.gif\ \ \ Ref [3]
ag14.dat \ Drela AG14 airfoil \ ag14.gif\ \ \ Ref [3]
ag16.dat \ Drela AG16 airfoil \ ag16.gif\ \ \ Ref [3]
ag17.dat \ Drela AG17 airfoil \ ag17.gif\ \ \ Ref [3]
ag18.dat \ Drela AG18 airfoil \ ag18.gif\ \ \ Ref [3]
ag19.dat \ Drela AG19 airfoil \ ag19.gif\ \ \ Ref [3]
ag24.dat \ Drela AG24 airfoil used on the Bubble Dancer R/C DLG \ ag24.gif\ \ \ Ref [3]
ag25.dat \ Drela AG25 airfoil used on the Bubble Dancer R/C DLG \ ag25.gif\ \ \ Ref [3]
ag26.dat \ Drela AG26 airfoil used on the Bubble Dancer R/C DLG \ ag26.gif\ \ \ Ref [3]
ag27.dat \ Drela AG27 airfoil used on the Bubble Dancer R/C DLG \ ag27.gif\ \ \ Ref [3]
ag35.dat \ Drela AG35 airfoil \ ag35.gif\ \ \ Ref [3]
ag36.dat \ Drela AG36 airfoil \ ag36.gif\ \ \ Ref [3]
ag37.dat \ Drela AG37 airfoil \ ag37.gif\ \ \ Ref [3]
ag38.dat \ Drela AG38 airfoil \ ag38.gif\ \ \ Ref [3]
ag44ct02r.dat \ Drela AG44ct -02f airfoil \ ag44ct02r.gif\ \ \ Ref [3]
ag455ct02r.dat \ Drela AG455ct -02f airfoil \ ag455ct02r.gif\ \ \ Ref [3]
ag45c03.dat \ Drela AG45c -03f airfoil \ ag45c03.gif\ \ \ Ref [3]
ag45ct02r.dat \ Drela AG45ct -02f airfoil \ ag45ct02r.gif\ \ \ Ref [3]
ag46c03.dat \ Drela AG46c -03f airfoil \ ag46c03.gif\ \ \ Ref [3]
ag46ct02r.dat \ Drela AG46ct -02f airfoil \ ag46ct02r.gif\ \ \ Ref [3]
ag47c03.dat \ Drela AG47c -03f airfoil \ ag47c03.gif\ \ \ Ref [3]
ag47ct02r.dat \ Drela AG47ct -02f airfoil \ ag47ct02r.gif\ \ \ Ref [3]
ah21-7.dat \ Andrew Hollom AH 21 airfoil (7% version)\ ah21-7.gif\ \ \ ah21ref.txt
ah21-9.dat \ Andrew Hollom AH 21 airfoil (original 9% version)\ ah21-9.gif\ \ \ ah21_ref.html
ah63k127.dat \ Althaus AH 63-K-127/24 airfoil for use with flaps (K) \ ah63k127.gif\ \ \ Ref [2]
ah6407.dat \ Althaus AH 6-407 airfoil \ ah6407.gif\ \ \
ah7476.dat \ Althaus AH 7-476 airfoil \ ah7476.gif\ \ \
ah79100a.dat \ Althaus AH 79-100A airfoil \ ah79100a.gif\ \ \
ah79100b.dat \ Althaus AH 79-100B airfoil \ ah79100b.gif\ \ \
ah79100c.dat \ Althaus AH 79-100C airfoil \ ah79100c.gif\ \ \
ah79k132.dat \ Althaus AH 79-K-132/20 airfoil for use with flaps (K) \ ah79k132.gif\ \ \ Ref [2]
ah79k135.dat \ Althaus AH 79-K-135/20 airfoil for use with flaps (K) \ ah79k135.gif\ \ \ Ref [2]
ah79k143.dat \ Althaus AH 79-K-143/18 airfoil for use with flaps (K) \ ah79k143.gif\ \ \ Ref [2]
ah80129.dat \ Althaus AH 80-129 airfoil \ ah80129.gif\ \ \ Ref [2]
ah80136.dat \ Althaus AH 80-136 airfoil \ ah80136.gif\ \ \ Ref [2]
ah80140.dat \ Althaus AH 80-140 airfoil \ ah80140.gif\ \ \ Ref [2]
ah81131.dat \ Althaus AH 81-131 airfoil \ ah81131.gif\ \ \ Ref [2]
ah81k144.dat \ Althaus AH 81-K-144/17 airfoil for use with flaps (K) \ ah81k144.gif\ \ \ Ref [2]
ah81k144wfKlappe.dat \ Althaus AH 81-K-144 W-F KLAPPE airfoil for use with flaps (K) \ ah81k144wfKlappe.gif\ \ \ Ref [2]
ah82150a.dat \ Althaus AH 82-150 A airfoil \ ah82150a.gif\ \ \ Ref [2]
ah82150f.dat \ Althaus AH 82-150 F airfoil \ ah82150f.gif\ \ \ Ref [2]
ah83150q.dat \ Althaus AH 83-150 Q airfoil \ ah83150q.gif\ \ \ Ref [2]
ah83159.dat \ Althaus AH 83-159 airfoil \ ah83159.gif\ \ \ Ref [2]
ah85l120.dat \ Althaus AH 85-L-120/17 symmetrical airfoil \ ah85l120.gif\ \ \ Ref [2]
ah88k130.dat \ Althaus AH 88-K-130/20 airfoil for use with flaps (K) \ ah88k130.gif\ \ \ Ref [2]
ah88k136.dat \ Althaus AH 88-K-136/16 airfoil for use with flaps (K) \ ah88k136.gif\ \ \ Ref [2]
ah93156.dat \ Althaus AH 93-156 airfoil \ ah93156.gif\ \ \ Ref [2]
ah93157.dat \ Althaus AH 93-157 airfoil \ ah93157.gif\ \ \ Ref [2]
ah93k130.dat \ Althaus AH 93-K-130/15 airfoil for use with flaps (K) \ ah93k130.gif\ \ \ Ref [2]
ah93k131.dat \ Althaus AH 93-K-131/15 airfoil for use with flaps (K) \ ah93k131.gif\ \ \ Ref [2]
ah93k132.dat \ Althaus AH 93-K-132/15 airfoil for use with flaps (K) \ ah93k132.gif\ \ \ Ref [2]
ah93w145.dat \ Althaus AH 93-W-145 airfoil for use on wind turbines (W) \ ah93w145.gif\ \ \ Ref [2]
ah93w174.dat \ Althaus AH 93-W-174 airfoil for use on wind turbines (W) \ ah93w174.gif\ \ \ Ref [2]
ah93w215.dat \ Althaus AH 93-W-215 airfoil for use on wind turbines (W) \ ah93w215.gif\ \ \ Ref [2]
ah93w257.dat \ Althaus AH 93-W-257 airfoil for use on wind turbines (W) \ ah93w257.gif\ \ \ Ref [2]
ah93w300.dat \ Althaus AH 93-W-300 airfoil for use on wind turbines (W) \ ah93w300.gif\ \ \ Ref [2]
ah93w480b.dat \ Althaus AH 93-W-480B airfoil for use on wind turbines (W) \ ah93w480b.gif\ \ \ Ref [2]
ah94145.dat \ Althaus AH 94-145 airfoil \ ah94145.gif\ \ \ Ref [2]
ah94156.dat \ Althaus AH 94-156 airfoil \ ah94156.gif\ \ \ Ref [2]
ah94w301.dat \ Althaus AH 94-W-301 airfoil for use on wind turbines (W) \ ah94w301.gif\ \ \ Ref [2]
ah95160.dat \ Althaus AH 95-160 airfoil \ ah94w301.gif\ \ \ Ref [2]
ames01.dat \ NASA/AMES/Hicks A-01 transonic rotorcraft airfoil \ ames01.gif\ \ \
ames02.dat \ NASA/AMES/Hicks A-02 transonic rotorcraft airfoil \ ames02.gif\ \ \
ames03.dat \ NASA/AMES/Kennelly A-03 transonic rotorcraft airfoil \ ames03.gif\ \ \
amsoil1.dat \ Rutan AMSOIL racer canard airfoil \ amsoil1.gif\ \ \
amsoil2.dat \ Rutan AMSOIL racer wing airfoil \ amsoil2.gif\ \ \
apex16.dat \ Drela Apex 16 low Reynolds number transonic research airfoil \ apex16.gif\ \ \ ref/apex16_ref.html
aquilasm.dat \ AQUILA R/C sailplane airfoil \ aquilasm.gif\ \ \ Low Reynolds number data
arad10.dat \ Aeronautical Research Association/Bocci-Dowty Rotol ARA-D 10% thick propeller airfoil \ arad10.gif\ \ \
arad13.dat \ Aeronautical Research Association/Bocci-Dowty Rotol ARA-D 13% thick propeller airfoil \ arad13.gif\ \ \
arad20.dat \ Aeronautical Research Association/Bocci-Dowty Rotol ARA-D 20% thick propeller airfoil \ arad20.gif\ \ \
arad6.dat \ Aeronautical Research Association/Bocci-Dowty Rotol ARA-D 6% thick propeller airfoil \ arad6.gif\ \ \
as5045.dat \ AS5045 airfoil Ashok Gopalarathnam/Selig 15% airfoil \ as5045.gif\ \ \
as5046.dat \ AS5046 airfoil Ashok Gopalarathnam/Selig 16% airfoil \ as5046.gif\ \ \
as5048.dat \ AS5048 airfoil Ashok Gopalarathnam/Selig 18% airfoil \ as5048.gif\ \ \
atr72sm.dat \ ATR 72 wing airfoil (from NTSB report) \ atr72sm.gif\ \ \ ref/atr72sm_ref.html
august160.dat \ AUGUST 160 airfoil \ august160.gif\ \ \ Ref [2]
avistar.dat \ Hobbico R/C Avistar trainer airfoil \ avistar.gif\ \ \ Low Reynolds number data
b29root.dat \ Boeing B-29 root airfoil \ b29root.gif\ \ \
b29tip.dat \ Boeing B-29 tip airfoil \ b29tip.gif\ \ \
b540ols.dat \ Bell AH-1 rotor blade airfoil (operational loads survey) \ b540ols.gif\ \ \
b707a.dat \ Boeing Commercial Airplane Company model 707 airfoils \ b707a.gif\ \ \
b707b.dat \ continued \ b707b.gif\ \ \
b707c.dat \ continued \ b707c.gif\ \ \
b707d.dat \ continued \ b707d.gif\ \ \
b707e.dat \ continued \ b707e.gif\ \ \
b737a.dat \ Boeing Commercial Airplane Company model 737 airfoils \ b737a.gif\ \ \
b737b.dat \ continued \ b737b.gif\ \ \
b737c.dat \ continued \ b737c.gif\ \ \
b737d.dat \ continued \ b737d.gif\ \ \
bacj.dat \ Boeing Commercial Airplane Company airfoil J \ bacj.gif\ \ \
bacxxx.dat \ Boeing Commercial Airplane Company BACXXX Energy Efficient Transport Program airfoil \ bacxxx.gif\ \ \
bambino6.dat \ Bambino 6 airfoil \ bambino6.gif\ \ \
be50.dat \ Verbitsky BE50 free flight airfoil (original) \ be50.gif\ \ \
be50sm.dat \ Verbitsky BE50 free flight airfoil (original) \ be50sm.gif\ \ \
boe103.dat \ Boeing 103 airfoil \ boe103.gif\ \ \
boe106.dat \ Boeing 106 airfoil \ boe106.gif\ \ \
bqm34.dat \ Ryan BQM-34 Firebee wing airfoil (NACA 63-014A W/NACA 0014 nose and thinned to .09899 to account for sweep) \ bqm34.gif\ \ \
bw3.dat \ Bergey BW-3 wind turbine airfoil (smoothed) \ bw3.gif\ \ \ Low Reynolds number data
c141a.dat \ Lockheed-Georgia C-141 transonic wing airfoils \ c141a.gif\ \ \
c141b.dat \ continued \ c141b.gif\ \ \
c141c.dat \ continued \ c141c.gif\ \ \
c141d.dat \ continued \ c141d.gif\ \ \
c141e.dat \ continued \ c141e.gif\ \ \
c141f.dat \ continued \ c141f.gif\ \ \
c5a.dat \ Lockheed-Georgia C-5A transonic wing airfoils \ c5a.gif\ \ \
c5b.dat \ continued \ c5b.gif\ \ \
c5c.dat \ continued \ c5c.gif\ \ \
c5d.dat \ continued \ c5d.gif\ \ \
c5e.dat \ continued \ c5e.gif\ \ \
cap21c.dat \ CAP 21 (TraCFoil) airfoil \ cap21c.gif\ \ \
cast102.dat \ CAST 10-2/DOA 2 transonic airfoil \ cast102.gif\ \ \
ch10sm.dat \ Chuch Hollinger CH 10-48-13 high lift low Reynolds number airfoil \ ch10sm.gif\ \ \ Low Reynolds number data
chen.dat \ University of Illinois/Chen high lift airfoil \ chen.gif\ \ \
clarkk.dat \ CLARK K airfoil \ clarkk.gif\ \ \ Low Reynolds number data
clarkv.dat \ CLARK V airfoil \ clarkv.gif\ \ \
clarkw.dat \ CLARK W airfoil \ clarkw.gif\ \ \
clarkx.dat \ CLARK X airfoil \ clarkx.gif\ \ \
clarky.dat \ CLARK Y airfoil \ clarky.gif\ \ \
clarkyh.dat \ CLARK YH airfoil \ clarkyh.gif\ \ \
clarkys.dat \ CLARK YS airfoil \ clarkys.gif\ \ \
clarkysm.dat \ CLARK Y airfoil (smoothed) \ clarkysm.gif\ \ \
clarkz.dat \ CLARK Z airfoil \ clarkz.gif\ \ \
clarym15.dat \ CLARK YM15 airfoil \ clarym15.gif\ \ \
clarym18.dat \ CLARK YM18 airfoil \ clarym18.gif\ \ \
coanda1.dat \ Coanda 1 airfoil \ coanda1.gif\ \ \
coanda2.dat \ Coanda 2 airfoil \ coanda2.gif\ \ \
coanda3.dat \ Coanda 3 airfoil \ coanda3.gif\ \ \
cootie.dat \ Waco Cootie airfoil \ cootie.gif\ \ \ ref/cootie_ref.html
cr001sm.dat \ Cody Robertson CR 001 R/C hand-launch low Reynolds number airfoil (smoothed) \ cr001sm.gif\ \ \ Low Reynolds number data
cr1.dat \ Curtiss CR-1 general aviation airfoil \ cr1.gif\ \ \
curtisc72.dat \ Curtis C-72 airfoil \ curtisc72.gif\ \ \
dae11.dat \ Drela DAE11 low Reynolds number airfoil \ dae11.gif\ \ \
dae21.dat \ Drela DAE21 low Reynolds number airfoil \ dae21.gif\ \ \
dae31.dat \ Drela DAE31 low Reynolds number airfoil \ dae31.gif\ \ \
dae51.dat \ Drela DAE51 low Reynolds number airfoil \ dae51.gif\ \ \ Low Reynolds number data
davis.dat \ Consolidated/Davis airfoil (B-24 wing?) \ davis.gif\ \ \
davis_corrected.dat \ Davis basic B-24 wing airfoil \ davis_corrected.gif\ \ \ ref/davis_corrected_ref.html
davissm.dat \ Davis 3R F1B free flight airfoil (smoothed) \ davissm.gif\ \ \ Low Reynolds number data
daytonwright6.dat \ Dayton-Wright 6 airfoil \ daytonwright6.gif\ \ \
daytonwrightt1.dat \ Dayton-Wright T-1 airfoil \ daytonwrightt1.gif\ \ \
dbln526.dat \ Sikorsky DBLN-526 double ended rotorcraft airfoil \ dbln526.gif\ \ \
defcnd1.dat \ Rutan DEFIANT canard BL20 airfoil \ defcnd1.gif\ \ \
defcnd2.dat \ Rutan DEFIANT canard BL110 airfoil \ defcnd2.gif\ \ \
defcnd3.dat \ Rutan DEFIANT canard BL145 airfoil \ defcnd3.gif\ \ \
df101.dat \ David Fraser DF 101 low Reynolds number airfoil \ df101.gif\ \ \ ref/lsats_ref.html
df102.dat \ David Fraser DF 102 low Reynolds number airfoil \ df102.gif\ \ \ ref/lsats_ref.html
dfvlrr4.dat \ DFVLR R-4 transonic airfoil \ dfvlrr4.gif\ \ \
dga1138.dat \ D.G.A. 1138 airfoil \ dga1138.gif\ \ \
dga1182.dat \ D.G.A. 1182 airfoil \ dga1182.gif\ \ \
dh4009sm.dat \ Dale House DH4009 (smoothed) used on the Storm R/C aerobatic aircraft \ dh4009sm.gif\ \ \ ref/lsats_ref.html
doa5.dat \ Dornier A-5 airfoil (reconstruction) (DO 228 wing) \ doa5.gif\ \ \
dormoy.dat \ Dormoy airfoil \ dormoy.gif\ \ \
drgnfly.dat \ Dragonfly Canard airfoil \ drgnfly.gif\ \ \ ref/drgnfly_ref.html
dsma523a.dat \ McDonnell/Douglas DSMA-523 transonic airfoil with sharp trailing edge \ dsma523a.gif\ \ \
dsma523b.dat \ McDonnell/Douglas DSMA-523 transonic airfoil with blunt trailing edge \ dsma523b.gif\ \ \
du8608418.dat \ Deflt University DU 86-084/18 low Reynolds number airfoil \ du8608418.gif\ \ \
du861372.dat \ Delft University DU 86-137/25 Airfoil \ du861372.gif\ \ \ ref/du861372_ref.html
e1098.dat \ Eppler E1098 general aviation airfoil \ e1098.gif\ \ \
e1200.dat \ Eppler E1200 general aviation airfoil \ e1200.gif\ \ \
e1210.dat \ Eppler E1210 general aviation airfoil \ e1210.gif\ \ \
e1211.dat \ Eppler E1211 general aviation airfoil \ e1211.gif\ \ \
e1212.dat \ Eppler E1212 general aviation airfoil \ e1212.gif\ \ \
e1212mod.dat \ Eppler E1212 general aviation airfoil (as modified for use as Quickie wing airfoil) \ e1212mod.gif\ \ \
e1213.dat \ Eppler E1213 general aviation airfoil \ e1213.gif\ \ \
e1214.dat \ Eppler E1214 general aviation airfoil \ e1214.gif\ \ \
e1230.dat \ Eppler E1230 general aviation airfoil (Long-EZ and Defiant wing airfoil) \ e1230.gif\ \ \
e1233.dat \ Eppler E1233 general aviation airfoil \ e1233.gif\ \ \
e168.dat \ Eppler E168 low Reynolds number airfoil \ e168.gif\ \ \
e169.dat \ Eppler E169 low Reynolds number airfoil \ e169.gif\ \ \
e171.dat \ Eppler E171 low Reynolds number airfoil \ e171.gif\ \ \
e174.dat \ Eppler E174 low Reynolds number airfoil \ e174.gif\ \ \
e176.dat \ Eppler E176 low Reynolds number airfoil \ e176.gif\ \ \
e178.dat \ Eppler E178 low Reynolds number airfoil \ e178.gif\ \ \
e180.dat \ Eppler E180 low Reynolds number airfoil \ e180.gif\ \ \
e182.dat \ Eppler E182 low Reynolds number airfoil \ e182.gif\ \ \
e184.dat \ Eppler E184 low Reynolds number airfoil \ e184.gif\ \ \
e186.dat \ Eppler E186 low Reynolds number airfoil \ e186.gif\ \ \
e193.dat \ Eppler E193 low Reynolds number airfoil \ e193.gif\ \ \ Low Reynolds number data
e195.dat \ Eppler E195 low Reynolds number airfoil \ e195.gif\ \ \
e197.dat \ Eppler E197 low Reynolds number airfoil \ e197.gif\ \ \
e201.dat \ Eppler E201 low Reynolds number airfoil \ e201.gif\ \ \
e203.dat \ Eppler E203 low Reynolds number airfoil \ e203.gif\ \ \
e205.dat \ Eppler E205 low Reynolds number airfoil \ e205.gif\ \ \ Low Reynolds number data
e207.dat \ Eppler E207 low Reynolds number airfoil \ e207.gif\ \ \
e209.dat \ Eppler E209 low Reynolds number airfoil \ e209.gif\ \ \
e210.dat \ Eppler E210 low Reynolds number airfoil \ e210.gif\ \ \
e211.dat \ Eppler E211 low Reynolds number airfoil \ e211.gif\ \ \
e212.dat \ Eppler E212 low Reynolds number airfoil \ e212.gif\ \ \
e214.dat \ Eppler E214 low Reynolds number airfoil \ e212.gif\ \ \ Low Reynolds number data
e216.dat \ Eppler E216 low Reynolds number airfoil \ e216.gif\ \ \
e220.dat \ Eppler E220 low Reynolds number airfoil \ e220.gif\ \ \
e221.dat \ Eppler E221 low Reynolds number airfoil \ e221.gif\ \ \
e222.dat \ Eppler E222 low Reynolds number airfoil \ e222.gif\ \ \
e224.dat \ Eppler E224 low Reynolds number airfoil \ e224.gif\ \ \
e226.dat \ Eppler E226 low Reynolds number airfoil \ e226.gif\ \ \
e228.dat \ Eppler E228 low Reynolds number airfoil \ e228.gif\ \ \
e230.dat \ Eppler E230 airfoil \ e230.gif\ \ \
e231.dat \ Eppler E231 R/C sailplane airfoil \ e231.gif\ \ \ Low Reynolds number data
e266.dat \ Eppler E266 general purpose airfoil \ e266.gif\ \ \
e297.dat \ Eppler E297 tailplane airfoil \ e297.gif\ \ \
e325.dat \ Eppler E325 flying wing airfoil \ e325.gif\ \ \
e326.dat \ Eppler E326 flying wing airfoil \ e326.gif\ \ \
e327.dat \ Eppler E327 flying wing airfoil \ e327.gif\ \ \
e328.dat \ Eppler E328 flying wing airfoil \ e328.gif\ \ \
e329.dat \ Eppler E329 flying wing airfoil \ e329.gif\ \ \
e330.dat \ Eppler E330 flying wing airfoil \ e330.gif\ \ \
e331.dat \ Eppler E331 flying wing airfoil \ e331.gif\ \ \
e332.dat \ Eppler E332 flying wing airfoil \ e332.gif\ \ \
e333.dat \ Eppler E333 flying wing airfoil \ e333.gif\ \ \
e334.dat \ Eppler E334 flying wing airfoil \ e334.gif\ \ \
e335.dat \ Eppler E335 flying wing airfoil \ e335.gif\ \ \
e336.dat \ Eppler E336 flying wing airfoil \ e336.gif\ \ \
e337.dat \ Eppler E337 flying wing airfoil \ e337.gif\ \ \
e338.dat \ Eppler E338 flying wing airfoil \ e338.gif\ \ \
e339.dat \ Eppler E339 flying wing airfoil \ e339.gif\ \ \
e340.dat \ Eppler E340 flying wing airfoil \ e340.gif\ \ \
e341.dat \ Eppler E341 flying wing airfoil \ e341.gif\ \ \
e342.dat \ Eppler E342 flying wing airfoil \ e342.gif\ \ \
e343.dat \ Eppler E343 flying wing airfoil \ e343.gif\ \ \
e344.dat \ Eppler E344 flying wing airfoil \ e344.gif\ \ \
e360.dat \ Eppler E360 rotorcraft airfoil \ e360.gif\ \ \
e361.dat \ Eppler E361 rotorcraft airfoil \ e361.gif\ \ \
e374.dat \ Eppler E374 low Reynolds number airfoil \ e374.gif\ \ \ Low Reynolds number data
e376.dat \ Eppler E376 ultralight airfoil \ e376.gif\ \ \
e377.dat \ Eppler E377 ultralight airfoil \ e377.gif\ \ \
e377m.dat \ Eppler E377 (modified) ultralight airfoil \ e377m.gif\ \ \
e378.dat \ Eppler E378 ultralight airfoil \ e378.gif\ \ \
e379.dat \ Eppler E379 ultralight airfoil \ e379.gif\ \ \
e385.dat \ Eppler E385 airfoil \ e385.gif\ \ \
e387.dat \ Eppler E387 low Reynolds number airfoil \ e387.gif\ \ \ Low Reynolds number data
e392.dat \ Eppler E392 low Reynolds number airfoil \ e392.gif\ \ \
e393.dat \ Eppler E393 airfoil \ e393.gif\ \ \
e395.dat \ Eppler E395 human powered aircraft airfoil \ e395.gif\ \ \
e396.dat \ Eppler E396 human powered aircraft airfoil \ e396.gif\ \ \
e397.dat \ Eppler E397 human powered aircraft airfoil \ e397.gif\ \ \
e398.dat \ Eppler E398 human powered aircraft airfoil \ e398.gif\ \ \
e399.dat \ Eppler E399 human powered aircraft airfoil \ e399.gif\ \ \
e403.dat \ Eppler E403 general purpose airfoil \ e403.gif\ \ \
e407.dat \ Eppler E407 sailplane airfoil \ e407.gif\ \ \
e417.dat \ Eppler E417 general purpose airfoil \ e417.gif\ \ \
e420.dat \ Eppler E420 high lift airfoil \ e420.gif\ \ \
e421.dat \ Eppler E421 high lift airfoil \ e421.gif\ \ \
e422.dat \ Eppler E422 high lift airfoil \ e422.gif\ \ \
e423.dat \ Eppler E423 high lift airfoil \ e423.gif\ \ \ Low Reynolds number data
e426.dat \ Eppler E426 airfoil \ e426.gif\ \ \
e428.dat \ Eppler E428 airfoil \ e428.gif\ \ \
e431.dat \ Eppler E431 sailplane airfoil \ e431.gif\ \ \
e432.dat \ Eppler E432 sailplane airfoil \ e432.gif\ \ \
e433.dat \ Eppler E433 sailplane airfoil \ e433.gif\ \ \
e434.dat \ Eppler E434 sailplane airfoil \ e434.gif\ \ \
e435.dat \ Eppler E435 sailplane airfoil \ e435.gif\ \ \
e471.dat \ Eppler E471 airfoil \ e471.gif\ \ \
e472.dat \ Eppler E472 aerobatic aircraft airfoil \ e472.gif\ \ \ Low Reynolds number data
e473.dat \ Eppler E473 aerobatic aircraft airfoil \ e473.gif\ \ \
e474.dat \ Eppler E474 aerobatic aircraft airfoil \ e474.gif\ \ \
e475.dat \ Eppler E475 aerobatic aircraft airfoil \ e475.gif\ \ \
e479.dat \ Eppler E479 aerobatic aircraft airfoil \ e479.gif\ \ \
e485.dat \ Eppler E485 tailplane airfoil \ e485.gif\ \ \
e49.dat \ Eppler E49 low Reynolds number airfoil \ e49.gif\ \ \
e502.dat \ Eppler E502 general purpose airfoil \ e502.gif\ \ \
e520.dat \ Eppler E520 tailplane airfoil \ e520.gif\ \ \
e521.dat \ Eppler E521 tailplane airfoil \ e521.gif\ \ \
e540.dat \ Eppler E540 general aviation airfoil \ e540.gif\ \ \
e541.dat \ Eppler E541 general aviation airfoil \ e541.gif\ \ \
e542.dat \ Eppler E542 general aviation airfoil \ e542.gif\ \ \
e543.dat \ Eppler E543 general aviation airfoil \ e543.gif\ \ \
e544.dat \ Eppler E544 general aviation airfoil \ e544.gif\ \ \
e545.dat \ Eppler E545 general aviation airfoil \ e545.gif\ \ \
e546.dat \ Eppler E546 general aviation airfoil \ e546.gif\ \ \
e547.dat \ Eppler E547 general aviation airfoil \ e547.gif\ \ \
e548.dat \ Eppler E548 general aviation airfoil \ e548.gif\ \ \
e549.dat \ Eppler E549 general aviation airfoil \ e549.gif\ \ \
e550.dat \ Eppler E550 general aviation airfoil \ e550.gif\ \ \
e551.dat \ Eppler E551 general aviation airfoil \ e551.gif\ \ \
e552.dat \ Eppler E552 general aviation airfoil \ e552.gif\ \ \
e553.dat \ Eppler E553 general aviation airfoil \ e553.gif\ \ \
e554.dat \ Eppler E554 general aviation airfoil \ e554.gif\ \ \
e555.dat \ Eppler E555 general aviation airfoil \ e555.gif\ \ \
e556.dat \ Eppler E556 general aviation airfoil \ e556.gif\ \ \
e557.dat \ Eppler E557 general aviation airfoil \ e557.gif\ \ \
e558.dat \ Eppler E558 general aviation airfoil \ e558.gif\ \ \
e559.dat \ Eppler E559 general aviation airfoil \ e559.gif\ \ \
e560.dat \ Eppler E560 general aviation airfoil \ e560.gif\ \ \
e561.dat \ Eppler E561 general aviation airfoil \ e561.gif\ \ \
e562.dat \ Eppler E562 general aviation airfoil \ e562.gif\ \ \
e58.dat \ Eppler E58 low Reynolds number airfoil \ e58.gif\ \ \
e580.dat \ Eppler E580 general purpose airfoil \ e580.gif\ \ \
e582.dat \ Eppler E582 sailplane airfoil \ e582.gif\ \ \
e583.dat \ Eppler E583 sailplane airfoil \ e583.gif\ \ \
e584.dat \ Eppler E584 sailplane airfoil \ e584.gif\ \ \
e585.dat \ Eppler E585 sailplane airfoil \ e585.gif\ \ \
e587.dat \ Eppler E587 sailplane airfoil \ e587.gif\ \ \
e59.dat \ Eppler E59 low Reynolds number airfoil \ e59.gif\ \ \
e591.dat \ Eppler E591 airfoil \ e591.gif\ \ \
e593.dat \ Eppler E593 airfoil \ e593.gif\ \ \
e598.dat \ Eppler E598 airfoil \ e598.gif\ \ \
e603.dat \ Eppler E603 general purpose airfoil \ e603.gif\ \ \
e604.dat \ Eppler E604 sailplane airfoil \ e604.gif\ \ \
e61.dat \ Eppler E61 low Reynolds number airfoil \ e61.gif\ \ \
e62.dat \ Eppler E62 low Reynolds number airfoil \ e62.gif\ \ \
e625.dat \ Eppler E625 airfoil \ e625.gif\ \ \
e63.dat \ Eppler E63 low Reynolds number airfoil \ e63.gif\ \ \
e635.dat \ Eppler E635 airfoil \ e635.gif\ \ \
e636.dat \ Eppler E636 airfoil \ e636.gif\ \ \
e637.dat \ Eppler E637 airfoil \ e637.gif\ \ \
e638.dat \ Eppler E638 airfoil \ e638.gif\ \ \
e639.dat \ Eppler E639 airfoil \ e639.gif\ \ \
e64.dat \ Eppler E64 low Reynolds number airfoil \ e64.gif\ \ \
e642.dat \ Eppler E642 sailplane airfoil \ e642.gif\ \ \
e654.dat \ Eppler E654 sailplane airfoil \ e654.gif\ \ \
e655.dat \ Eppler E655 sailplane airfoil \ e655.gif\ \ \
e656.dat \ Eppler E656 sailplane airfoil \ e656.gif\ \ \
e657.dat \ Eppler E657 sailplane airfoil \ e657.gif\ \ \
e66.dat \ Eppler E66 low Reynolds number airfoil \ e66.gif\ \ \
e662.dat \ Eppler E662 sailplane airfoil \ e662.gif\ \ \
e664.dat \ Eppler E664 variable geometry sailplane airfoil \ e664.gif\ \ \
e664ex.dat \ Eppler E664 (extended) variable geometry sailplane airfoil \ e664ex.gif\ \ \
e668.dat \ Eppler E668 sailplane airfoil \ e668.gif\ \ \
e67.dat \ Eppler E67 low Reynolds number airfoil \ e67.gif\ \ \
e678.dat \ Eppler E678 sailplane airfoil \ e678.gif\ \ \
e68.dat \ Eppler E68 low Reynolds number airfoil \ e68.gif\ \ \
e682.dat \ Eppler E682 sailplane airfoil \ e682.gif\ \ \
e694.dat \ Eppler E694 sailplane airfoil \ e694.gif\ \ \
e71.dat \ Eppler E71 low Reynolds number airfoil \ e71.gif\ \ \
e715.dat \ Eppler E715 tailplane airfoil \ e715.gif\ \ \
e748.dat \ Eppler E748 sailplane airfoil \ e748.gif\ \ \
e793.dat \ Eppler E793 general purpose airfoil (gyroflug speed canard canard) \ e793.gif\ \ \
e817.dat \ Eppler E817 hydrofoil \ e817.gif\ \ \
e818.dat \ Eppler E818 hydrofoil \ e818.gif\ \ \
e836.dat \ Eppler E836 hydrofoil \ e836.gif\ \ \
e837.dat \ Eppler E837 hydrofoil \ e837.gif\ \ \
e838.dat \ Eppler E838 hydrofoil \ e838.gif\ \ \
e850.dat \ Eppler E850 propeller airfoil \ e850.gif\ \ \
e851.dat \ Eppler E851 propeller airfoil \ e851.gif\ \ \
e852.dat \ Eppler E852 propeller airfoil \ e852.gif\ \ \
e853.dat \ Eppler E853 propeller airfoil \ e853.gif\ \ \
e854.dat \ Eppler E854 propeller airfoil \ e854.gif\ \ \
e855.dat \ Eppler E855 propeller airfoil \ e855.gif\ \ \
e856.dat \ Eppler E856 propeller airfoil \ e856.gif\ \ \
e857.dat \ Eppler E857 propeller airfoil \ e857.gif\ \ \
e858.dat \ Eppler E858 propeller airfoil \ e858.gif\ \ \
e862.dat \ Eppler E862 strut airfoil \ e862.gif\ \ \
e863.dat \ Eppler E863 strut airfoil \ e863.gif\ \ \
e864.dat \ Eppler E864 strut airfoil \ e864.gif\ \ \
e874.dat \ Eppler E874 hydrofoil \ e874.gif\ \ \
e904.dat \ Eppler E904 hydrofoil \ e904.gif\ \ \
e908.dat \ Eppler E908 hydrofoil \ e908.gif\ \ \
ea61009.dat \ Eppler EA 6(-1)-009 airfoil \ ea61009.gif\ \ \
ea61012.dat \ Eppler EA 6(-1)-012 airfoil \ ea61012.gif\ \ \
ea81006.dat \ Eppler EA 8(-1)-006 airfoil \ ea81006.gif\ \ \
ebambino7.dat \ E. Bambino airfoil \ ebambino7.gif\ \ \
ec863914.dat \ Eppler EC 86(-3)-914 airfoil \ ec863914.gif\ \ \
eh0009.dat \ John Yost EH 0.0/9.0 for tailless R/C aircraft \ eh0009.gif\ \ \ http://www.b2streamlines.com/EH.html, More info
eh1070.dat \ John Yost EH 1.0/7.0 for tailless R/C aircraft \ eh1070.gif\ \ \ http://www.b2streamlines.com/EH.html, More info
eh1090.dat \ John Yost EH 1.0/9.0 for tailless R/C aircraft \ eh1090.gif\ \ \ http://www.b2streamlines.com/EH.html, More info
eh1590.dat \ John Yost EH 1.5/9.0 for tailless R/C aircraft \ eh1590.gif\ \ \ http://www.b2streamlines.com/EH.html, More info
eh2010.dat \ John Yost EH 2.0/10 for tailless R/C aircraft \ eh2010.gif\ \ \ http://www.b2streamlines.com/EH.html, More info
eh2012.dat \ John Yost EH 2.0/12 for tailless R/C aircraft \ eh2012.gif\ \ \ http://www.b2streamlines.com/EH.html, More info
eh2070.dat \ John Yost EH 2.0/7.0 for tailless R/C aircraft \ eh2070.gif\ \ \ http://www.b2streamlines.com/EH.html, More info
eh2510.dat \ John Yost EH 2.5/10 for tailless R/C aircraft \ eh2510.gif\ \ \ http://www.b2streamlines.com/EH.html, More info
eh3012.dat \ John Yost EH 3.0/12 for tailless R/C aircraft \ eh3012.gif\ \ \ http://www.b2streamlines.com/EH.html, More info
eiffel10.dat \ Eiffel 10 (Wright) - 1903 Wright Flyer airfoil \ eiffel10.gif\ \ \ NACA Report 93, 1921, More info Ref [6]
eiffel371.dat \ Eiffel 371 (Monge) airfoil \ eiffel371.gif\ \ \
eiffel385.dat \ Eiffel 385 (S.T. Ae) airfoil \ eiffel385.gif\ \ \
eiffel428.dat \ Eiffel 428 (Bleriot) airfoil \ eiffel428.gif\ \ \
eiffel430.dat \ Eiffel 430 (Lachassgne) airfoil \ eiffel430.gif\ \ \
esa40.dat \ Evans Simitar Airfoil ESA40 for R/C tailless aircraft \ esa40.gif\ \ \ Low Reynolds number data
falcon.dat \ Falcon airfoil used on the Carl Goldberg Falcon 56 Mk II R/C powerplane \ falcon.gif\ \ \ Low Reynolds number data
fauvel.dat \ Fauvel 14% flying wing airfoil \ fauvel.gif\ \ \
fg1.dat \ Fage & Collins 1 airfoil \ fg1.gif\ \ \
fg2.dat \ Fage & Collins 2 airfoil \ fg2.gif\ \ \
fg3.dat \ Fage & Collins 3 airfoil \ fg3.gif\ \ \
fg4.dat \ Fage & Collins 4 airfoil \ fg4.gif\ \ \
fx049915.dat \ Wortmann FX 049-915 airfoil \ fx049915.gif\ \ \
fx05188.dat \ Wortmann FX 05-188 airfoil \ fx05188.gif\ \ \
fx05191.dat \ Wortmann FX 05-191 airfoil \ fx05191.gif\ \ \
fx057816.dat \ Wortmann FX 057-816 airfoil \ fx057816.gif\ \ \
fx05h126.dat \ Wortmann FX 05-H-126 rotorcraft airfoil \ fx05h126.gif\ \ \
fx082512.dat \ Wortmann FX 082-512 airfoil \ fx082512.gif\ \ \
fx08s176.dat \ Wortmann FX 08-S-176 airfoil \ fx08s176.gif\ \ \
fx2.dat \ Wortmann FX 2 airfoil \ fx2.gif\ \ \
fx3.dat \ Wortmann FX 3 airfoil \ fx3.gif\ \ \
fx38153.dat \ Wortmann FX 38-153 airfoil \ fx38153.gif\ \ \
fx60100.dat \ Wortmann FX 60-100 airfoil \ fx60100.gif\ \ \
fx601001.dat \ Wortmann FX 60-100 (126) airfoil \ fx601001.gif\ \ \
fx60100sm.dat \ Wortmann FX 60-100 airfoil (smoothed) \ fx60100sm.gif\ \ \ Low Reynolds number data
fx60126.dat \ Wortmann FX 60-126 airfoil \ fx60126.gif\ \ \
fx601261.dat \ Wortmann FX 60-126/1 airfoil \ fx601261.gif\ \ \
fx60157.dat \ Wortmann FX 60-157 airfoil \ fx60157.gif\ \ \
fx60160.dat \ Wortmann FX 60-160 airfoil \ fx60160.gif\ \ \
fx60177.dat \ Wortmann FX 60-177 airfoil \ fx60177.gif\ \ \
fx61140.dat \ Wortmann FX 61-140 airfoil \ fx61140.gif\ \ \
fx61147.dat \ Wortmann FX 61-147 airfoil \ fx61147.gif\ \ \
fx61163.dat \ Wortmann FX 61-163 airfoil \ fx61163.gif\ \ \
fx61168.dat \ Wortmann FX 61-168 airfoil \ fx61168.gif\ \ \
fx61184.dat \ Wortmann FX 61-184 airfoil \ fx61184.gif\ \ \
fx62k131.dat \ Wortmann FX 62-K-131/17 airfoil \ fx62k131.gif\ \ \
fx62k153.dat \ Wortmann FX 62-K-153/20 airfoil \ fx62k153.gif\ \ \
fx63100.dat \ Wortmann FX 63-100 airfoil \ fx63100.gif\ \ \
fx63110.dat \ Wortmann FX 63-110 airfoil \ fx63110.gif\ \ \
fx63120.dat \ Wortmann FX 63-120 airfoil \ fx63120.gif\ \ \
fx63137.dat \ Wortmann FX 63-137 human power aircraft airfoil (Liver Puffin) airfoil \ fx63137.gif\ \ \ Low Reynolds number data
fx63137sm.dat \ Wortmann FX 63-137 airfoil (smoothed) \ fx63137sm.gif\ \ \ Low Reynolds number data
fx63143.dat \ Wortmann FX 63-143 airfoil \ fx63143.gif\ \ \
fx63145.dat \ Wortmann FX 63-145 airfoil \ fx63145.gif\ \ \
fx63147.dat \ Wortmann FX 63-147 airfoil \ fx63147.gif\ \ \
fx63158.dat \ Wortmann FX 63-158 airfoil \ fx63158.gif\ \ \
fx6617a2.dat \ Wortmann FX 66-17AII-182 airfoil \ fx6617a2.gif\ \ \
fx6617ai.dat \ Wortmann FX 66-17AII-182 airfoil (as tested at NASA) \ fx6617ai.gif\ \ \
fx66182.dat \ Wortmann FX 66-182 airfoil \ fx66182.gif\ \ \
fx66196v.dat \ Wortmann FX 66-S-196 V1 airfoil \ fx66196v.gif\ \ \
fx66a175.dat \ Wortmann FX 66-17A-175 airfoil \ fx66a175.gif\ \ \
fx66h60.dat \ Wortmann FX 66-H-60 airfoil \ fx66h60.gif\ \ \ Ref [2]
fx66h80.dat \ Wortmann FX 66-H-80 airfoil \ fx66h80.gif\ \ \ Ref [2]
fx66s161.dat \ Wortmann FX 66-S-161 airfoil \ fx66s161.gif\ \ \
fx66s171.dat \ Wortmann FX 66-S-171 airfoil \ fx66s171.gif\ \ \
fx66s196.dat \ Wortmann FX 66-S-196 airfoil \ fx66s196.gif\ \ \
fx67k150.dat \ Wortmann FX 67-K-150/17 airfoil \ fx67k150.gif\ \ \
fx67k170.dat \ Wortmann FX 67-K-170/17 airfoil \ fx67k170.gif\ \ \
fx68h120.dat \ Wortmann FX 68-H-120 airfoil \ fx68h120.gif\ \ \ Ref [2]
fx69274.dat \ Wortmann FX 69-274 airfoil \ fx69274.gif\ \ \ Ref [2]
fx69h083.dat \ Bell/Wortmann FX 69-H-083 rotorcraft airfoil \ fx69h083.gif\ \ \
fx69h098.dat \ Bell/Wortmann FX 69-H-098 rotorcraft airfoil \ fx69h098.gif\ \ \
fx69pr281.dat \ Wortmann FX 69-PR-281 airfoil \ fx69pr281.gif\ \ \ Ref [2]
fx71089a.dat \ Wortmann FX 71-089A airfoil \ fx71089a.gif\ \ \
fx71120.dat \ Wortmann FX 71-120 airfoil \ fx71120.gif\ \ \
fx711520.dat \ Wortmann FX 71-L-150/20 airfoil \ fx711520.gif\ \ \
fx711525.dat \ Wortmann FX 71-L-150/25 airfoil \ fx711525.gif\ \ \
fx711530.dat \ Wortmann FX 71-L-150/30 airfoil \ fx711530.gif\ \ \ ref/fx711530_ref.html
fx71l150.dat \ Wortmann FX 71-L-150/30 airfoil \ fx71l150.gif\ \ \
fx72150a.dat \ Wortmann FX 72-MS-150A airfoil \ fx72150a.gif\ \ \
fx72150b.dat \ Wortmann FX 72-MS-150B airfoil \ fx72150b.gif\ \ \
fx72ls160.dat \ Wortmann FX 72-LS-160 airfoil \ fx72ls160.gif\ \ \ Ref [2]
fx73170.dat \ Wortmann FX 73-170 airfoil \ fx73170.gif\ \ \ Ref [2]
fx73170a.dat \ Wortmann FX 73-170 A airfoil \ fx73170a.gif\ \ \ Ref [2]
fx73cl1152.dat \ Wortmann FX 73-CL1-152 airfoil \ fx73cl1152.gif\ \ \ Ref [2]
fx73cl2152.dat \ Wortmann FX 73-CL2-152 airfoil \ fx73cl2152.gif\ \ \ Ref [2]
fx73cl3152.dat \ Wortmann FX 73-CL3-152 airfoil \ fx73cl3152.gif\ \ \ Ref [2]
fx73k170.dat \ Wortmann FX 73-K-170/22 airfoil for use with flaps (K) \ fx73k170.gif\ \ \ Ref [2]
fx74080.dat \ Wortmann FX 74-080 airfoil \ fx74080.gif\ \ \ Ref [2]
fx74130wp1.dat \ Wortmann FX 74-130 WP1 airfoil \ fx74130wp1.gif\ \ \ Ref [2]
fx74130wp2.dat \ Wortmann 74-130 WP2 airfoil \ fx74130wp2.gif\ \ \ Ref [2]
fx74130wp2mod.dat \ Wortmann 74-130 WP2 MOD airfoil \ fx74130wp2mod.gif\ \ \ Ref [2]
fx74cl5140.dat \ Wortmann FX 74-CL5-140 high lift airfoil \ fx74cl5140.gif\ \ \
fx74cl6140.dat \ Wortmann FX 74-CL6-140 airfoil \ fx74cl6140.gif\ \ \ Ref [2]
fx74modsm.dat \ Modified Wortmann FX 74-CL5-140 high lift airfoil \ fx74modsm.gif\ \ \ Low Reynolds number data
fx75141.dat \ Wortmann FX 75-141 airfoil \ fx75141.gif\ \ \ Ref [2]
fx75193.dat \ Wortmann FX 75-193 airfoil \ fx75193.gif\ \ \ Ref [2]
fx75vg166.dat \ Wortmann FX 75-VG-166/22 variable geometry airfoil \ fx75vg166.gif\ \ \ Ref [2]
fx76100.dat \ Wortmann FX 76-100 symmetrical airfoil \ fx76100.gif\ \ \ Ref [2]
fx76120.dat \ Wortmann FX 76-120 symmetrical airfoil \ fx76120.gif\ \ \ Ref [2]
fx76mp120.dat \ Wortmann FX 76-MP-120 airfoil \ fx76mp120.gif\ \ \ Ref [2]
fx76mp140.dat \ Wortmann FX 76-MP-140 airfoil \ fx76mp140.gif\ \ \ Ref [2]
fx76mp160.dat \ Wortmann FX 76-MP-160 airfoil \ fx76mp160.gif\ \ \ Ref [2]
fx77080.dat \ Wortmann FX 77-080 symmetrical airfoil \ fx77080.gif\ \ \ Ref [2]
fx77w121.dat \ Wortmann FX 77-W-121 airfoil for use on wind turbines (W) \ fx77w121.gif\ \ \ Ref [2]
fx77w153.dat \ Wortmann FX 77-W-153 wind turbine airfoil \ fx77w153.gif\ \ \
fx77w258.dat \ Wortmann FX 77-W-258 wind turbine airfoil \ fx77w258.gif\ \ \
fx77w270.dat \ Wortmann FX 77-W-270 airfoil for use on wind turbines (W) \ fx77w270.gif\ \ \ Ref [2]
fx77w270s.dat \ Wortmann FX 77-W-270S airfoil for use on wind turbines (W) \ fx77w270s.gif\ \ \ Ref [2]
fx77w343.dat \ Wortmann FX 77-W-343 wind turbine airfoil \ fx77w343.gif\ \ \
fx78k140.dat \ Wortmann FX 78-K-140/20 airfoil for use with flaps (K) \ fx78k140.gif\ \ \ Ref [2]
fx78k140a20.dat \ Wortmann FX 78-K-140 airfoil for use with flaps (K) A/20 \ fx78k140a20.gif\ \ \ Ref [2]
fx78k150.dat \ Wortmann FX 78-K-150/20 airfoil for use with flaps (K) \ fx78k150.gif\ \ \ Ref [2]
fx78k161.dat \ Wortmann FX 78-K-161 airfoil for use with flaps (K) \ fx78k161.gif\ \ \ Ref [2]
fx78pk188.dat \ Wortmann FX 78-PK-188/20 variable geometry airfoil \ fx78pk188.gif\ \ \ Ref [2]
fx79k144.dat \ Wortmann FX 79-K-144/17 sailplane airfoil \ fx79k144.gif\ \ \
fx79l100.dat \ Wortmann FX 79-L-100 symmetrical airfoil \ fx79l100.gif\ \ \ Ref [2]
fx79l120.dat \ Wortmann FX 79-L-120 symmetrical airfoil \ fx79l100.gif\ \ \ Ref [2]
fx79w151a.dat \ Wortmann FX 79-W-151 airfoil for use on wind turbines (W) A \ fx79w151a.gif\ \ \ Ref [2]
fx79w470a.dat \ Wortmann FX 79-W-470A airfoil for use on wind turbines (W) \ fx79w470a.gif\ \ \ Ref [2]
fx79w660a.dat \ Wortman FX 79-W-660A airfoil for use on wind turbines (W) \ fx79w660a.gif\ \ \ Ref [2]
fx80080.dat \ Wortmann FX 80-080 airfoil \ fx80080.gif\ \ \ Ref [2]
fx83w108.dat \ Wortmann FX 83-W-108 airfoil for use on wind turbines (W) \ fx83w108.gif\ \ \ Ref [2]
fx83w160.dat \ Wortmann FX 83-W-160 airfoil for use on wind turbines (W) \ fx83w160.gif\ \ \ Ref [2]
fx83w227.dat \ Wortmann FX 83-W-227 airfoil for use on wind turbines (W) \ fx83w227.gif\ \ \ Ref [2]
fx84w097.dat \ Wortmann FX 84-W-097 airfoil for use on wind turbines (W) \ fx84w097.gif\ \ \ Ref [2]
fx84w127.dat \ Wortmann FX 84-W-127 airfoil for use on wind turbines (W) \ fx84w127.gif\ \ \ Ref [2]
fx84w140.dat \ Wortmann FX 84-W-140 airfoil for use on wind turbines (W) \ fx84w140.gif\ \ \ Ref [2]
fx84w150.dat \ Wortmann FX 84-W-150 airfoil for use on wind turbines (W) \ fx84w150.gif\ \ \ Ref [2]
fx84w175.dat \ Wortmann FX 84-W-175 airfoil for use on wind turbines (W) \ fx84w175.gif\ \ \ Ref [2]
fx84w218.dat \ Wortmann FX 84-W-218 airfoil for use on wind turbines (W) \ fx84w218.gif\ \ \ Ref [2]
fxl142k.dat \ Wortmann FX LIII-142 K 25 airfoil \ fxl142k.gif\ \ \
fxlv152.dat \ Wortmann FX L V-152 airfoil \ fxlv152.gif\ \ \
fxm2.dat \ Wortmann FX M2 airfoil \ fxm2.gif\ \ \
fxs02196.dat \ Wortmann FX S 02-196 airfoil \ fxs02196.gif\ \ \
fxs03182.dat \ Wortmann FX S 03-182 airfoil \ fxs03182.gif\ \ \
fxs21158.dat \ Wortmann FX S 02/1-158 airfoil \ fxs21158.gif\ \ \
geminism.dat \ GEMINI R/C sailplane airfoil (smoothed) \ geminism.gif\ \ \ Low Reynolds number data
giiia.dat \ Grumman/Gulfstream GIII transonic airfoils \ giiia.gif\ \ \
giiib.dat \ continued \ giiib.gif\ \ \
giiic.dat \ continued \ giiic.gif\ \ \
giiid.dat \ continued \ giiid.gif\ \ \
giiie.dat \ continued \ giiie.gif\ \ \
giiif.dat \ continued \ giiif.gif\ \ \
giiig.dat \ continued \ giiig.gif\ \ \
giiih.dat \ continued \ giiih.gif\ \ \
giiii.dat \ continued \ giiii.gif\ \ \
giiij.dat \ continued \ giiij.gif\ \ \
giiik.dat \ continued \ giiik.gif\ \ \
giiil.dat \ continued \ giiil.gif\ \ \
giiim.dat \ continued \ giiim.gif\ \ \
giiin.dat \ continued \ giiin.gif\ \ \
glennmartin2.dat \ Glenn Martin 2 airfoil \ glennmartin2.gif\ \ \
glennmartin3.dat \ Glenn Martin 3 airfoil \ glennmartin3.gif\ \ \
glennmartin4.dat \ Glenn Martin 4 airfoil \ glennmartin4.gif\ \ \
gm15sm.dat \ Gilbert Morris GM15 F1C class free flight flapper airfoil \ gm15sm.gif\ \ \ Low Reynolds number data
goe05k.dat \ Gottingen 5K airfoil \ goe05k.gif\ \ \
goe06k.dat \ Gottingen 6K airfoil \ goe06k.gif\ \ \
goe07k.dat \ Gottingen 7K airfoil \ goe07k.gif\ \ \
goe08k.dat \ Gottingen 8K airfoil \ goe08k.gif\ \ \
goe09k.dat \ Gottingen 9K airfoil \ goe09k.gif\ \ \
goe100.dat \ Gottingen 100 (Sopwith) airfoil \ goe100.gif\ \ \
goe101.dat \ Gottingen 101 airfoil \ goe101.gif\ \ \
goe10k.dat \ Gottingen 10K airfoil \ goe10k.gif\ \ \
goe113.dat \ Gottingen 113 airfoil \ goe113.gif\ \ \
goe114.dat \ Gottingen 114 (MVA MK.1) airfoil \ goe114.gif\ \ \
goe115.dat \ Gottingen 115 (MVA MK.2) airfoil \ goe115.gif\ \ \
goe116.dat \ Gottingen 116 (MVA MK.3) airfoil \ goe116.gif\ \ \
goe117.dat \ Gottingen 117 (MVA MK.4) airfoil \ goe117.gif\ \ \
goe118.dat \ Gottingen 118 (MVA MK.7) airfoil \ goe118.gif\ \ \
goe11k.dat \ Gottingen 11K airfoil \ goe11k.gif\ \ \
goe121.dat \ Gottingen 121 (MVA H.1) airfoil \ goe121.gif\ \ \
goe122.dat \ Gottingen 122 (MVA H.2) airfoil \ goe122.gif\ \ \
goe123.dat \ Gottingen 123 airfoil \ goe123.gif\ \ \
goe124.dat \ Gottingen 124 (MVA H.4) airfoil \ goe124.gif\ \ \
goe12k.dat \ Gottingen 12K airfoil \ goe12k.gif\ \ \
goe133.dat \ Gottingen 133 (MVA H.11) airfoil \ goe133.gif\ \ \
goe134.dat \ Gottingen 134 (MVA H.12) airfoil \ goe134.gif\ \ \
goe137.dat \ Gottingen 137 (MVA H.15) airfoil \ goe137.gif\ \ \
goe13k.dat \ Gottingen 13K airfoil \ goe13k.gif\ \ \
goe14.dat \ Gottingen 14 airfoil \ goe14.gif\ \ \
goe140.dat \ Gottingen 140 (MVA H.17) airfoil \ goe140.gif\ \ \
goe142.dat \ Gottingen 142 (MVA H.19) airfoil \ goe142.gif\ \ \
goe143.dat \ Gottingen 143 (MVA H.20) airfoil \ goe143.gif\ \ \
goe144.dat \ Gottingen 144 (MVA H.21) airfoil \ goe144.gif\ \ \
goe147.dat \ Gottingen 147 (MVA H.6) airfoil \ goe147.gif\ \ \
goe14k.dat \ Gottingen 14K airfoil \ goe14k.gif\ \ \
goe15.dat \ Gottingen 15 airfoil \ goe15.gif\ \ \
goe155.dat \ Gottingen 155 (SSW D.1) airfoil \ goe155.gif\ \ \
goe15k.dat \ Gottingen 15K airfoil \ goe15k.gif\ \ \
goe164.dat \ Gottingen 164 (MVA MK.10) airfoil \ goe164.gif\ \ \
goe165.dat \ Gottingen 165 (MVA MK.11) airfoil \ goe165.gif\ \ \
goe167.dat \ Gottingen 167 (V.Karman PROP.2) airfoil \ goe167.gif\ \ \
goe16k.dat \ Gottingen 16K airfoil \ goe16k.gif\ \ \
goe173.dat \ Gottingen 173 (Albatros 6020) airfoil \ goe173.gif\ \ \
goe174.dat \ Gottingen 174 (Albatros 5020) airfoil \ goe174.gif\ \ \
goe176.dat \ Gottingen 176 (Albatros 7020) airfoil \ goe176.gif\ \ \
goe177.dat \ Gottingen 177 airfoil \ goe177.gif\ \ \
goe178.dat \ Gottingen 178 airfoil \ goe178.gif\ \ \
goe180.dat \ Gottingen 180 (MVA H.26) airfoil \ goe180.gif\ \ \
goe182.dat \ Gottingen 182 (MVA H.27) airfoil \ goe182.gif\ \ \
goe184.dat \ Gottingen 184 (MVA H.29) airfoil \ goe184.gif\ \ \
goe187.dat \ Gottingen 187 (Schatte-Lanz 2U10) airfoil \ goe187.gif\ \ \
goe188.dat \ Gottingen 188 (Schatte-Lanz 3U10) airfoil \ goe188.gif\ \ \
goe190.dat \ Gottingen 190 (MVA MK.18) airfoil \ goe190.gif\ \ \
goe195.dat \ Gottingen 195 airfoil \ goe195.gif\ \ \
goe198.dat \ Gottingen 198 (L.F.G. 5294) airfoil \ goe198.gif\ \ \
goe199.dat \ Gottingen 199 (L.F.G. 5406) airfoil \ goe199.gif\ \ \
goe207.dat \ Gottingen 207 (AVIATIK V8) airfoil \ goe207.gif\ \ \
goe210.dat \ Gottingen 210 (DAIMLER) airfoil \ goe210.gif\ \ \
goe217.dat \ Gottingen 217 (MVA MK.12) airfoil \ goe217.gif\ \ \
goe222.dat \ Gottingen 222 (MVA H.33) airfoil \ goe222.gif\ \ \
goe223.dat \ Gottingen 223 (MVA H.34) airfoil \ goe223.gif\ \ \
goe225.dat \ Gottingen 225 (MVA H.35) airfoil \ goe225.gif\ \ \
goe226.dat \ Gottingen 226 (MVA H.36) airfoil \ goe226.gif\ \ \
goe227.dat \ Gottingen 227 (MVA H.37) airfoil \ goe227.gif\ \ \
goe228.dat \ Gottingen 228 (MVA H.38) airfoil \ goe228.gif\ \ \
goe229.dat \ Gottingen 229 (MVA H.39) airfoil \ goe229.gif\ \ \
goe233.dat \ Gottingen 233 (MVA CA4) airfoil \ goe233.gif\ \ \
goe234.dat \ Gottingen 234 (MVA CA5) airfoil \ goe234.gif\ \ \
goe235.dat \ Gottingen 235 (SCHATTE-LANZ) airfoil \ goe235.gif\ \ \
goe238.dat \ Gottingen 238 (HANSA-BRANDENBURG) airfoil \ goe238.gif\ \ \
goe239.dat \ Gottingen 239 (MVA H.31) airfoil \ goe239.gif\ \ \
goe240.dat \ Gottingen 240 (KOLLER) airfoil \ goe240.gif\ \ \
goe241.dat \ Gottingen 241 (MVA PR.1) airfoil \ goe241.gif\ \ \
goe242.dat \ Gottingen 242 (MVA PR.2) airfoil \ goe242.gif\ \ \
goe243.dat \ Gottingen 243 (MVA PR.3) airfoil \ goe243.gif\ \ \
goe244.dat \ Gottingen 244 (MVA PR.4) airfoil \ goe244.gif\ \ \
goe255.dat \ Gottingen 255 (MVA CA.6) airfoil \ goe255.gif\ \ \
goe256.dat \ Gottingen 256 (JUNKERS E) airfoil \ goe256.gif\ \ \
goe257.dat \ Gottingen 257 airfoil \ goe257.gif\ \ \
goe264.dat \ Gottingen 264 airfoil \ goe264.gif\ \ \
goe265.dat \ Gottingen 265 airfoil \ goe265.gif\ \ \
goe269.dat \ Gottingen 269 airfoil \ goe269.gif\ \ \
goe274.dat \ Gottingen 274 (DAIMLER V) airfoil \ goe274.gif\ \ \
goe275.dat \ Gottingen 275 (DAIMLER VI) airfoil \ goe275.gif\ \ \
goe276.dat \ Gottingen 276 (DAIMLER VII) airfoil \ goe276.gif\ \ \
goe277.dat \ Gottingen 277 (DAIMLER VIII) airfoil \ goe277.gif\ \ \
goe278.dat \ Gottingen 278 (DAIMLER IX) airfoil \ goe278.gif\ \ \
goe279.dat \ Gottingen 279 (DAIMLER X) airfoil \ goe279.gif\ \ \
goe280.dat \ Gottingen 280 (DAIMLER XI) airfoil \ goe280.gif\ \ \
goe281.dat \ Gottingen 281 (DAIMLER XII) airfoil \ goe281.gif\ \ \
goe282.dat \ Gottingen 282 (DAIMLER XIII) airfoil \ goe282.gif\ \ \
goe284.dat \ Gottingen 284 airfoil \ goe284.gif\ \ \
goe285.dat \ Gottingen 285 airfoil \ goe285.gif\ \ \
goe286.dat \ Gottingen 286 airfoil \ goe286.gif\ \ \
goe287.dat \ Gottingen 287 airfoil \ goe287.gif\ \ \
goe288.dat \ Gottingen 288 airfoil \ goe288.gif\ \ \
goe289.dat \ Gottingen 289 (MVA 289) airfoil \ goe289.gif\ \ \
goe290.dat \ Gottingen 290 (MVA 290) airfoil \ goe290.gif\ \ \
goe298.dat \ Gottingen 298 airfoil \ goe298.gif\ \ \
goe29b.dat \ Gottingen 29B airfoil \ goe29b.gif\ \ \
goe300.dat \ Gottingen 300 (Friedrichshafen G20) airfoil \ goe300.gif\ \ \
goe301.dat \ Gottingen 301 (Friedrichshafen G 13) airfoil \ goe301.gif\ \ \
goe303.dat \ Gottingen 303 (Friedrichshafen G03) airfoil \ goe303.gif\ \ \
goe304.dat \ Gottingen 304 (Friedrichshafen G02) airfoil \ goe304.gif\ \ \
goe308.dat \ Gottingen 308 (MVA H.40) airfoil \ goe308.gif\ \ \
goe309.dat \ Gottingen 309 (MVA H.41) airfoil \ goe309.gif\ \ \
goe310.dat \ Gottingen 310 (MVA H.42) airfoil \ goe310.gif\ \ \
goe311.dat \ Gottingen 311 (MVA H.43) airfoil \ goe311.gif\ \ \
goe314.dat \ Gottingen 314 (Hansa-Brandenburg) airfoil \ goe314.gif\ \ \
goe315.dat \ Gottingen 315 (Hansa-Brandenburg III.5) airfoil \ goe315.gif\ \ \
goe316.dat \ Gottingen 316 (Hansa-Brandenburg IV.5) airfoil \ goe316.gif\ \ \
goe318.dat \ Gottingen 318 (Hansa-Brandenburg VI.5) airfoil \ goe318.gif\ \ \
goe319.dat \ Gottingen 319 (Hansa-Brandenburg II) airfoil \ goe319.gif\ \ \
goe320.dat \ Gottingen 320 (Hansa-Brandenburg II.1) airfoil \ goe320.gif\ \ \
goe321.dat \ Gottingen 321 (Hansa-Brandenburg III.1) airfoil \ goe321.gif\ \ \
goe322.dat \ Gottingen 322 (Hansa-Brandenburg IV.1) airfoil \ goe322.gif\ \ \
goe323.dat \ Gottingen 323 (Hansa-Brandenburg V.1) airfoil \ goe323.gif\ \ \
goe324.dat \ Gottingen 324 (Hansa-Brandenburg) airfoil \ goe324.gif\ \ \
goe325.dat \ Gottingen 325 (Pfalz 54) airfoil \ goe325.gif\ \ \
goe326.dat \ Gottingen 326 (Pfalz 55) airfoil \ goe326.gif\ \ \
goe328.dat \ Gottingen 328 airfoil \ goe328.gif\ \ \
goe329.dat \ Gottingen 329 (Pfalz 58) airfoil \ goe329.gif\ \ \
goe330.dat \ Gottingen 330 (Pfalz 59) airfoil \ goe330.gif\ \ \
goe331.dat \ Gottingen 331 (Pfalz 60) airfoil \ goe331.gif\ \ \
goe332.dat \ Gottingen 332 (Pfalz 61) airfoil \ goe332.gif\ \ \
goe335.dat \ Gottingen 335 (D.F.W.) airfoil \ goe335.gif\ \ \
goe336.dat \ Gottingen 336 (MVA H.44) airfoil \ goe336.gif\ \ \
goe342.dat \ Gottingen 342 airfoil \ goe342.gif\ \ \
goe344.dat \ Gottingen 344 (Pfalz 71) airfoil \ goe344.gif\ \ \
goe346.dat \ Gottingen 346 (Friedrichshafen-Staaken) airfoil \ goe346.gif\ \ \
goe358.dat \ Gottingen 358 airfoil \ goe358.gif\ \ \
goe359.dat \ Gottingen 359 airfoil \ goe359.gif\ \ \
goe360.dat \ Gottingen 360 airfoil \ goe360.gif\ \ \
goe361.dat \ Gottingen 361 airfoil \ goe361.gif\ \ \
goe362.dat \ Gottingen 362 airfoil \ goe362.gif\ \ \
goe363.dat \ Gottingen 363 airfoil \ goe363.gif\ \ \
goe364.dat \ Gottingen 364 airfoil \ goe364.gif\ \ \
goe365.dat \ Gottingen 365 airfoil \ goe365.gif\ \ \
goe366.dat \ Gottingen 366 airfoil \ goe366.gif\ \ \
goe367.dat \ Gottingen 367 airfoil \ goe367.gif\ \ \
goe368.dat \ Gottingen 368 airfoil \ goe368.gif\ \ \
goe369.dat \ Gottingen 369 airfoil \ goe369.gif\ \ \
goe370.dat \ Gottingen 370 airfoil \ goe370.gif\ \ \
goe371.dat \ Gottingen 371 airfoil \ goe371.gif\ \ \
goe372.dat \ Gottingen 372 airfoil \ goe372.gif\ \ \
goe373.dat \ Gottingen 373 airfoil \ goe373.gif\ \ \
goe374.dat \ Gottingen 374 airfoil \ goe374.gif\ \ \
goe375.dat \ Gottingen 375 airfoil \ goe375.gif\ \ \
goe376.dat \ Gottingen 376 airfoil \ goe376.gif\ \ \
goe377.dat \ Gottingen 377 airfoil \ goe377.gif\ \ \
goe379.dat \ Gottingen 379 airfoil \ goe379.gif\ \ \
goe380.dat \ Gottingen 380 airfoil \ goe380.gif\ \ \
goe381.dat \ Gottingen 381 airfoil \ goe381.gif\ \ \
goe382.dat \ Gottingen 382 airfoil \ goe382.gif\ \ \
goe383.dat \ Gottingen 383 airfoil \ goe383.gif\ \ \
goe384.dat \ Gottingen 384 airfoil \ goe384.gif\ \ \
goe385.dat \ Gottingen 385 airfoil \ goe385.gif\ \ \
goe386.dat \ Gottingen 386 airfoil \ goe386.gif\ \ \
goe387.dat \ Gottingen 387 airfoil \ goe387.gif\ \ \
goe388.dat \ Gottingen 388 airfoil \ goe388.gif\ \ \
goe389.dat \ Gottingen 389 airfoil \ goe389.gif\ \ \
goe390.dat \ Gottingen 390 airfoil \ goe390.gif\ \ \
goe391.dat \ Gottingen 391 airfoil \ goe391.gif\ \ \
goe392.dat \ Gottingen 392 airfoil \ goe392.gif\ \ \
goe393.dat \ Gottingen 393 airfoil \ goe393.gif\ \ \
goe394.dat \ Gottingen 394 airfoil \ goe394.gif\ \ \
goe395.dat \ Gottingen 395 airfoil \ goe395.gif\ \ \
goe396.dat \ Gottingen 396 airfoil \ goe396.gif\ \ \
goe397.dat \ Gottingen 397 airfoil \ goe397.gif\ \ \
goe398.dat \ Gottingen 398 airfoil \ goe398.gif\ \ \
goe399.dat \ Gottingen 399 airfoil \ goe399.gif\ \ \
goe400.dat \ Gottingen 400 airfoil \ goe400.gif\ \ \
goe401.dat \ Gottingen 401 airfoil \ goe401.gif\ \ \
goe402.dat \ Gottingen 402 airfoil \ goe402.gif\ \ \
goe403.dat \ Gottingen 403 airfoil \ goe403.gif\ \ \
goe404.dat \ Gottingen 404 airfoil \ goe404.gif\ \ \
goe405.dat \ Gottingen 405 airfoil \ goe405.gif\ \ \
goe406.dat \ Gottingen 406 airfoil \ goe406.gif\ \ \
goe407.dat \ Gottingen 407 airfoil \ goe407.gif\ \ \
goe408.dat \ Gottingen 408 airfoil \ goe408.gif\ \ \
goe409.dat \ Gottingen 409 airfoil \ goe409.gif\ \ \
goe410.dat \ Gottingen 410 airfoil \ goe410.gif\ \ \
goe411.dat \ Gottingen 411 airfoil \ goe411.gif\ \ \
goe412.dat \ Gottingen 412 airfoil \ goe412.gif\ \ \
goe413.dat \ Gottingen 413 airfoil \ goe413.gif\ \ \
goe414.dat \ Gottingen 414 airfoil \ goe414.gif\ \ \
goe415.dat \ Gottingen 415 airfoil \ goe415.gif\ \ \
goe416a.dat \ Gottingen 416A airfoil \ goe416a.gif\ \ \
goe417.dat \ Gottingen 417 airfoil \ goe417.gif\ \ \
goe417a.dat \ Gottingen 417A (GEW. PLATTE) airfoil \ goe417a.gif\ \ \ Low Reynolds number data
goe418.dat \ Gottingen 418 airfoil \ goe418.gif\ \ \
goe419.dat \ Gottingen 419 airfoil \ goe419.gif\ \ \
goe420.dat \ Gottingen 420 airfoil \ goe420.gif\ \ \
goe421.dat \ Gottingen 421 airfoil \ goe421.gif\ \ \
goe422.dat \ Gottingen 422 airfoil \ goe422.gif\ \ \
goe423.dat \ Gottingen 423 airfoil \ goe423.gif\ \ \
goe424.dat \ Gottingen 424 airfoil \ goe424.gif\ \ \
goe425.dat \ Gottingen 425 airfoil \ goe425.gif\ \ \
goe426.dat \ Gottingen 426 airfoil \ goe426.gif\ \ \
goe427.dat \ Gottingen 427 airfoil \ goe427.gif\ \ \
goe428.dat \ Gottingen 428 airfoil \ goe428.gif\ \ \
goe429.dat \ Gottingen 429 airfoil \ goe429.gif\ \ \
goe430.dat \ Gottingen 430 airfoil \ goe430.gif\ \ \
goe431.dat \ Gottingen 431 airfoil \ goe431.gif\ \ \
goe432.dat \ Gottingen 432 airfoil \ goe432.gif\ \ \
goe433.dat \ Gottingen 433 airfoil \ goe432.gif\ \ \
goe434.dat \ Gottingen 434 airfoil \ goe434.gif\ \ \
goe435.dat \ Gottingen 435 airfoil \ goe435.gif\ \ \
goe436.dat \ Gottingen 436 airfoil \ goe436.gif\ \ \
goe437.dat \ Gottingen 437 airfoil \ goe437.gif\ \ \
goe438.dat \ Gottingen 438 airfoil \ goe438.gif\ \ \
goe439.dat \ Gottingen 439 airfoil \ goe439.gif\ \ \
goe440.dat \ Gottingen 440 airfoil \ goe440.gif\ \ \
goe441.dat \ Gottingen 441 airfoil \ goe441.gif\ \ \
goe442.dat \ Gottingen 442 airfoil \ goe442.gif\ \ \
goe443.dat \ Gottingen 443 airfoil \ goe443.gif\ \ \
goe444.dat \ Gottingen 444 airfoil \ goe444.gif\ \ \
goe445.dat \ Gottingen 445 airfoil \ goe445.gif\ \ \
goe446.dat \ Gottingen 446 airfoil \ goe446.gif\ \ \
goe447.dat \ Gottingen 447 airfoil \ goe447.gif\ \ \
goe448.dat \ Gottingen 448 airfoil \ goe448.gif\ \ \
goe449.dat \ Gottingen 449 airfoil \ goe449.gif\ \ \
goe450.dat \ Gottingen 450 airfoil \ goe450.gif\ \ \
goe451.dat \ Gottingen 451 airfoil \ goe451.gif\ \ \
goe456.dat \ Gottingen 456 airfoil \ goe456.gif\ \ \
goe457.dat \ Gottingen 457 airfoil \ goe457.gif\ \ \
goe458.dat \ Gottingen 458 airfoil \ goe458.gif\ \ \
goe459.dat \ Gottingen 459 airfoil \ goe459.gif\ \ \
goe460.dat \ Gottingen 460 airfoil \ goe460.gif\ \ \
goe462.dat \ Gottingen 462 airfoil \ goe462.gif\ \ \
goe464.dat \ Gottingen 464 airfoil \ goe464.gif\ \ \
goe474.dat \ Gottingen 474 airfoil \ goe474.gif\ \ \
goe476.dat \ Gottingen 476 airfoil \ goe476.gif\ \ \
goe477.dat \ Gottingen 477 airfoil \ goe477.gif\ \ \
goe478.dat \ Gottingen 478 airfoil \ goe478.gif\ \ \
goe479.dat \ Gottingen 479 airfoil \ goe479.gif\ \ \
goe480.dat \ Gottingen 480 airfoil \ goe480.gif\ \ \
goe481.dat \ Gottingen 481 airfoil \ goe481.gif\ \ \
goe481a.dat \ Gottingen 481A airfoil \ goe481a.gif\ \ \
goe482.dat \ Gottingen 482 airfoil \ goe482.gif\ \ \
goe483.dat \ Gottingen 483 airfoil \ goe483.gif\ \ \
goe484.dat \ Gottingen 484 airfoil \ goe484.gif\ \ \
goe488.dat \ Gottingen 488 airfoil \ goe488.gif\ \ \
goe490.dat \ Gottingen 490 airfoil \ goe490.gif\ \ \
goe491.dat \ Gottingen 491 airfoil \ goe491.gif\ \ \
goe492.dat \ Gottingen 492 airfoil \ goe492.gif\ \ \
goe493.dat \ Gottingen 493 airfoil \ goe493.gif\ \ \
goe494.dat \ Gottingen 494 airfoil \ goe494.gif\ \ \
goe495.dat \ Gottingen 495 airfoil \ goe495.gif\ \ \
goe496.dat \ Gottingen 496 airfoil \ goe496.gif\ \ \
goe497.dat \ Gottingen 497 airfoil \ goe497.gif\ \ \
goe498.dat \ Gottingen 498 airfoil \ goe498.gif\ \ \
goe499.dat \ Gottingen 499 airfoil \ goe499.gif\ \ \
goe500.dat \ Gottingen 500 airfoil \ goe500.gif\ \ \
goe501.dat \ Gottingen 501 airfoil \ goe501.gif\ \ \
goe502.dat \ Gottingen 502 airfoil \ goe502.gif\ \ \
goe503.dat \ Gottingen 503 airfoil \ goe503.gif\ \ \
goe504.dat \ Gottingen 504 airfoil \ goe504.gif\ \ \
goe505.dat \ Gottingen 505 airfoil \ goe505.gif\ \ \
goe506.dat \ Gottingen 506 airfoil \ goe506.gif\ \ \
goe507.dat \ Gottingen 507 airfoil \ goe507.gif\ \ \
goe508.dat \ Gottingen 508 airfoil \ goe508.gif\ \ \
goe509.dat \ Gottingen 509 airfoil \ goe509.gif\ \ \
goe510.dat \ Gottingen 510 airfoil \ goe510.gif\ \ \
goe511.dat \ Gottingen 511 airfoil \ goe511.gif\ \ \
goe512.dat \ Gottingen 512 airfoil \ goe512.gif\ \ \
goe513.dat \ Gottingen 513 airfoil \ goe513.gif\ \ \
goe514.dat \ Gottingen 514 airfoil \ goe514.gif\ \ \
goe515.dat \ Gottingen 515 airfoil \ goe515.gif\ \ \
goe517.dat \ Gottingen 517 airfoil \ goe517.gif\ \ \
goe518.dat \ Gottingen 518 airfoil \ goe518.gif\ \ \
goe522.dat \ Gottingen 522 airfoil \ goe522.gif\ \ \
goe523.dat \ Gottingen 523 airfoil \ goe523.gif\ \ \
goe525.dat \ Gottingen 525 airfoil \ goe525.gif\ \ \
goe526.dat \ Gottingen 526 airfoil \ goe526.gif\ \ \
goe527.dat \ Gottingen 527 airfoil \ goe527.gif\ \ \
goe528.dat \ Gottingen 528 airfoil \ goe528.gif\ \ \
goe529.dat \ Gottingen 529 airfoil \ goe529.gif\ \ \
goe530.dat \ Gottingen 530 airfoil \ goe530.gif\ \ \
goe531.dat \ Gottingen 531 airfoil \ goe531.gif\ \ \
goe532.dat \ Gottingen 532 airfoil \ goe532.gif\ \ \
goe533.dat \ Gottingen 533 airfoil \ goe533.gif\ \ \
goe534.dat \ Gottingen 534 airfoil \ goe534.gif\ \ \
goe535.dat \ Gottingen 535 airfoil \ goe535.gif\ \ \
goe54.dat \ Gottingen 54 airfoil \ goe54.gif\ \ \
goe546.dat \ Gottingen 546 airfoil \ goe546.gif\ \ \
goe547.dat \ Gottingen 547 airfoil \ goe547.gif\ \ \
goe548.dat \ Gottingen 548 airfoil \ goe548.gif\ \ \
goe549.dat \ Gottingen 549 airfoil \ goe549.gif\ \ \
goe55.dat \ Gottingen 55 airfoil \ goe55.gif\ \ \
goe550.dat \ Gottingen 550 airfoil \ goe550.gif\ \ \
goe553.dat \ Gottingen 553 airfoil \ goe553.gif\ \ \
goe559.dat \ Gottingen 559 airfoil \ goe559.gif\ \ \
goe561.dat \ Gottingen 561 airfoil \ goe561.gif\ \ \
goe562.dat \ Gottingen 562 airfoil \ goe562.gif\ \ \
goe563.dat \ Gottingen 563 airfoil \ goe563.gif\ \ \
goe564.dat \ Gottingen 564 airfoil \ goe564.gif\ \ \
goe565.dat \ Gottingen 565 airfoil \ goe565.gif\ \ \
goe566.dat \ Gottingen 566 airfoil \ goe566.gif\ \ \
goe567.dat \ Gottingen 567 airfoil \ goe567.gif\ \ \
goe57.dat \ Gottingen 57 airfoil \ goe57.gif\ \ \
goe570.dat \ Gottingen 570 airfoil \ goe570.gif\ \ \
goe571.dat \ Gottingen 571 airfoil \ goe571.gif\ \ \
goe572.dat \ Gottingen 572 airfoil \ goe572.gif\ \ \
goe573.dat \ Gottingen 573 airfoil \ goe573.gif\ \ \
goe574.dat \ Gottingen 574 airfoil \ goe574.gif\ \ \
goe575.dat \ Gottingen 575 airfoil \ goe575.gif\ \ \
goe584.dat \ Gottingen 584 airfoil \ goe584.gif\ \ \
goe585.dat \ Gottingen 585 airfoil \ goe585.gif\ \ \
goe587.dat \ Gottingen 587 airfoil \ goe587.gif\ \ \
goe590.dat \ Gottingen 590 airfoil \ goe590.gif\ \ \
goe591.dat \ Gottingen 591 airfoil \ goe591.gif\ \ \
goe592.dat \ Gottingen 592 airfoil \ goe592.gif\ \ \
goe593.dat \ Gottingen 593 airfoil \ goe593.gif\ \ \
goe595.dat \ Gottingen 595 airfoil \ goe595.gif\ \ \
goe596.dat \ Gottingen 596 airfoil \ goe596.gif\ \ \
goe598.dat \ Gottingen 598 airfoil \ goe598.gif\ \ \
goe599.dat \ Gottingen 599 airfoil \ goe599.gif\ \ \
goe600.dat \ Gottingen 600 airfoil \ goe600.gif\ \ \
goe601.dat \ Gottingen 601 airfoil \ goe601.gif\ \ \
goe602.dat \ Gottingen 602 airfoil \ goe602.gif\ \ \
goe602m.dat \ Gottingen 602 MOD airfoil \ goe602m.gif\ \ \
goe604.dat \ Gottingen 604 airfoil \ goe604.gif\ \ \
goe610b.dat \ Gottingen 610 B airfoil \ goe610b.gif\ \ \
goe610bm.dat \ Gottingen 610-B MOD airfoil \ goe610bm.gif\ \ \
goe611.dat \ Gottingen 611 airfoil \ goe611.gif\ \ \
goe612.dat \ Gottingen 612 airfoil \ goe612.gif\ \ \
goe613.dat \ Gottingen 613 airfoil \ goe613.gif\ \ \
goe614.dat \ Gottingen 614 airfoil \ goe614.gif\ \ \
goe615.dat \ Gottingen 615 airfoil \ goe615.gif\ \ \
goe617.dat \ Gottingen 617 airfoil \ goe617.gif\ \ \
goe619.dat \ Gottingen 619 airfoil \ goe619.gif\ \ \
goe620.dat \ Gottingen 620 airfoil \ goe620.gif\ \ \
goe621.dat \ Gottingen 621 airfoil \ goe621.gif\ \ \
goe622.dat \ Gottingen 622 airfoil \ goe622.gif\ \ \
goe623.dat \ Gottingen 623 airfoil \ goe623.gif\ \ \
goe624.dat \ Gottingen 624 airfoil \ goe624.gif\ \ \
goe625.dat \ Gottingen 625 airfoil \ goe625.gif\ \ \
goe626.dat \ Gottingen 626 airfoil \ goe626.gif\ \ \
goe627.dat \ Gottingen 627 airfoil \ goe627.gif\ \ \
goe628.dat \ Gottingen 628 airfoil \ goe628.gif\ \ \
goe629.dat \ Gottingen 629 airfoil \ goe629.gif\ \ \
goe63.dat \ Gottingen 63 airfoil \ goe63.gif\ \ \
goe630.dat \ Gottingen 630 airfoil \ goe630.gif\ \ \
goe632.dat \ Gottingen 632 airfoil \ goe632.gif\ \ \
goe633.dat \ Gottingen 633 airfoil \ goe633.gif\ \ \
goe645.dat \ Gottingen 645 airfoil \ goe645.gif\ \ \
goe646.dat \ Gottingen 646 airfoil \ goe646.gif\ \ \
goe647.dat \ Gottingen 647 airfoil \ goe647.gif\ \ \
goe648.dat \ Gottingen 648 airfoil \ goe647.gif\ \ \
goe650.dat \ Gottingen 650 airfoil \ goe650.gif\ \ \
goe652.dat \ Gottingen 652 airfoil \ goe652.gif\ \ \
goe654.dat \ Gottingen 654 airfoil \ goe654.gif\ \ \
goe655.dat \ Gottingen 655 airfoil \ goe655.gif\ \ \
goe670.dat \ Gottingen 670 airfoil \ goe670.gif\ \ \
goe673.dat \ Gottingen 673 airfoil \ goe673.gif\ \ \
goe675.dat \ Gottingen 675 airfoil \ goe675.gif\ \ \
goe676.dat \ Gottingen 676 (= M 12) airfoil \ goe676.gif\ \ \
goe677.dat \ Gottingen 677 (= M 6) airfoil \ goe677.gif\ \ \
goe679.dat \ Gottingen 679 airfoil \ goe679.gif\ \ \
goe681.dat \ Gottingen 681 airfoil \ goe681.gif\ \ \
goe682.dat \ Gottingen 682 airfoil \ goe682.gif\ \ \
goe683.dat \ Gottingen 683 airfoil \ goe683.gif\ \ \
goe685.dat \ Gottingen 685 airfoil \ goe685.gif\ \ \
goe692.dat \ Gottingen 692 airfoil \ goe692.gif\ \ \
goe693.dat \ Gottingen 693 airfoil \ goe693.gif\ \ \
goe701.dat \ Gottingen 701 airfoil \ goe701.gif\ \ \
goe702.dat \ Gottingen 702 airfoil \ goe702.gif\ \ \
goe703.dat \ Gottingen 703 airfoil \ goe703.gif\ \ \
goe704.dat \ Gottingen 704 airfoil \ goe704.gif\ \ \
goe711.dat \ Gottingen 711 airfoil \ goe711.gif\ \ \
goe723.dat \ Gottingen 723 airfoil \ goe723.gif\ \ \
goe735.dat \ Gottingen 735 airfoil \ goe735.gif\ \ \
goe738.dat \ Gottingen 738 airfoil \ goe738.gif\ \ \
goe741.dat \ Gottingen 741 airfoil \ goe741.gif\ \ \
goe744.dat \ Gottingen 744 airfoil \ goe744.gif\ \ \
goe746.dat \ Gottingen 746 airfoil \ goe746.gif\ \ \
goe758.dat \ Gottingen 758 airfoil \ goe758.gif\ \ \
goe766.dat \ Gottingen 766 airfoil \ goe766.gif\ \ \
goe767.dat \ Gottingen 767 airfoil \ goe767.gif\ \ \
goe769.dat \ Gottingen 769 airfoil \ goe769.gif\ \ \
goe770.dat \ Gottingen 770 airfoil \ goe770.gif\ \ \
goe775.dat \ Gottingen 775 airfoil \ goe770.gif\ \ \
goe776.dat \ Gottingen 776 airfoil \ goe776.gif\ \ \
goe777.dat \ Gottingen 777 airfoil \ goe777.gif\ \ \
goe780.dat \ Gottingen 780 airfoil \ goe780.gif\ \ \
goe79.dat \ Gottingen 79 (Pfalz 11) airfoil \ goe79.gif\ \ \
goe795.dat \ Gottingen 795 airfoil \ goe795.gif\ \ \ Low Reynolds number data
goe795sm.dat \ Gottingen 795 airfoil (smoothed) \ goe795sm.gif\ \ \ Low Reynolds number data
goe796.dat \ Gottingen 796 airfoil \ goe796.gif\ \ \
goe797.dat \ Gottingen 797 airfoil \ goe797.gif\ \ \
goe798.dat \ Gottingen 798 airfoil \ goe798.gif\ \ \
goe801.dat \ Gottingen 801 (MVA 301) airfoil \ goe801.gif\ \ \
goe802.dat \ Gottingen 802 airfoil \ goe802.gif\ \ \
goe802a.dat \ Gottingen 802 A airfoil \ goe802a.gif\ \ \
goe802b.dat \ Gottingen 802 B airfoil \ goe802b.gif\ \ \
goe803h.dat \ Gottingen 803 (Hacklinger) airfoil \ goe803h.gif\ \ \
goe804.dat \ Gottingen 804 (EA 8) airfoil \ goe804.gif\ \ \
goe81.dat \ Gottingen 81 airfoil \ goe81.gif\ \ \
goe92.dat \ Gottingen 92 airfoil \ goe92.gif\ \ \
griffith30SymSuction.dat \ Griffith 30% suction airfoil \ griffith30SymSuction.gif\ \ \ ref/griffith30SymSuction_ref.html
gs1.dat \ Gluharoff/Sikorsky GS-1 airfoil \ gs1.gif\ \ \
gu255118.dat \ University of Glasgow GU 25-5(11)8 canard airfoil (Quickie, Varieze and Long-EZ canard airfoil) \ gu255118.gif\ \ \
hh02.dat \ Hughes helicopters HH-02 rotorcraft airfoil \ hh02.gif\ \ \
hobie.dat \ Hobie Hawk airfoil (Hobie Hawk R/C sailplane) \ hobie.gif\ \ \
hobiesm.dat \ Hobie Hawk airfoil (Hobie Hawk R/C sailplane) \ hobiesm.gif\ \ \
hq010.dat \ Quabeck HQ 0/10 R/C sailplane airfoil \ hq010.gif\ \ \ http://www.hq-modellflug.de
hq07.dat \ Quabeck HQ 0/7 R/C sailplane airfoil \ hq07.gif\ \ \ http://www.hq-modellflug.de
hq09.dat \ Quabeck HQ 0/9 R/C sailplane airfoil \ hq09.gif\ \ \ http://www.hq-modellflug.de
hq1010.dat \ Quabeck HQ 1.0/10 R/C sailplane airfoil \ hq1010.gif\ \ \ http://www.hq-modellflug.de
hq1012.dat \ Quabeck HQ 1.0/12 R/C sailplane airfoil \ hq1012.gif\ \ \ http://www.hq-modellflug.de
hq108.dat \ Quabeck HQ 1.0/8 R/C sailplane airfoil \ hq108.gif\ \ \ http://www.hq-modellflug.de
hq109.dat \ Quabeck HQ 1.0/9 R/C sailplane airfoil \ hq109.gif\ \ \ http://www.hq-modellflug.de
hq1510.dat \ Quabeck HQ 1.5/10 R/C sailplane airfoil \ hq1510.gif\ \ \ http://www.hq-modellflug.de
hq1511.dat \ Quabeck HQ 1.5/11 R/C sailplane airfoil \ hq1511.gif\ \ \ http://www.hq-modellflug.de
hq1512.dat \ Quabeck HQ 1.5/12 R/C sailplane airfoil \ hq1512.gif\ \ \ http://www.hq-modellflug.de
hq158.dat \ Quabeck HQ 1.5/8 R/C sailplane airfoil \ hq158.gif\ \ \ http://www.hq-modellflug.de
hq1585.dat \ Quabeck HQ 1.5/8.5 R/C sailplane airfoil \ hq1585.gif\ \ \ http://www.hq-modellflug.de
hq159.dat \ Quabeck HQ 1.5/9 R/C sailplane airfoil \ hq159.gif\ \ \ http://www.hq-modellflug.de
hq159b.dat \ Quabeck HQ 1.5/9 B R/C sailplane airfoil \ hq159b.gif\ \ \ http://www.hq-modellflug.de
hq2010.dat \ Quabeck HQ 2.0/10 R/C sailplane airfoil \ hq2010.gif\ \ \ http://www.hq-modellflug.de
hq2012.dat \ Quabeck HQ 2.0/12 R/C sailplane airfoil \ hq2012.gif\ \ \ http://www.hq-modellflug.de
hq208.dat \ Quabeck HQ 2.0/8 R/C sailplane airfoil \ hq208.gif\ \ \ http://www.hq-modellflug.de
hq209.dat \ Quabeck HQ 2.0/9 R/C sailplane airfoil \ hq209.gif\ \ \ http://www.hq-modellflug.de Low Reynolds number data
hq2090sm.dat \ Quabeck HQ 2.0/9 R/C sailplane airfoil (smoothed) \ hq2090sm.gif\ \ \ http://www.hq-modellflug.de Low Reynolds number data
hq2195.dat \ Quabeck HQ 2.1/9.5 R/C sailplane airfoil \ hq2195.gif\ \ \ http://www.hq-modellflug.de
hq2510.dat \ Quabeck HQ 2.5/10 R/C sailplane airfoil \ hq2510.gif\ \ \ http://www.hq-modellflug.de
hq2511.dat \ Quabeck HQ 2.5/11 R/C sailplane airfoil \ hq2511.gif\ \ \ http://www.hq-modellflug.de
hq2512.dat \ Quabeck HQ 2.5/12 R/C sailplane airfoil \ hq2512.gif\ \ \ http://www.hq-modellflug.de
hq258.dat \ Quabeck HQ 2.5/8 R/C sailplane airfoil \ hq2512.gif\ \ \ http://www.hq-modellflug.de
hq259.dat \ Quabeck HQ 2.5/9 R/C sailplane airfoil \ hq259.gif\ \ \ http://www.hq-modellflug.de
hq2590sm.dat \ Quabeck HQ 2.5/9 R/C sailplane airfoil (smoothed) \ hq2590sm.gif\ \ \ http://www.hq-modellflug.de
hq259b.dat \ Quabeck HQ 2.5/9 B R/C sailplane airfoil \ hq259b.gif\ \ \ http://www.hq-modellflug.de
hq300gd2.dat \ DFVLR/Braunschweig Horstmann and Quast HQ-300 GD(MOD 2) sailplane airfoil \ hq300gd2.gif\ \ \
hq3010.dat \ Quabeck HQ 3.0/10 R/C sailplane airfoil \ hq3010.gif\ \ \ http://www.hq-modellflug.de
hq3011.dat \ Quabeck HQ 3.0/11 R/C sailplane airfoil \ hq3011.gif\ \ \ http://www.hq-modellflug.de
hq3012.dat \ Quabeck HQ 3.0/12 R/C sailplane airfoil \ hq3012.gif\ \ \ http://www.hq-modellflug.de
hq3013.dat \ Quabeck HQ 3.0/13 R/C sailplane airfoil \ hq3013.gif\ \ \ http://www.hq-modellflug.de
hq3014.dat \ Quabeck HQ 3.0/14 R/C sailplane airfoil \ hq3014.gif\ \ \ http://www.hq-modellflug.de
hq3015.dat \ Quabeck HQ 3.0/15 R/C sailplane airfoil \ hq3015.gif\ \ \ http://www.hq-modellflug.de
hq308.dat \ Quabeck HQ 3.0/8 R/C sailplane airfoil \ hq308.gif\ \ \ http://www.hq-modellflug.de
hq309.dat \ Quabeck HQ 3.0/9 R/C sailplane airfoil \ hq309.gif\ \ \ http://www.hq-modellflug.de
hq3510.dat \ Quabeck HQ 3.5/10 R/C sailplane airfoil \ hq3510.gif\ \ \ http://www.hq-modellflug.de
hq3512.dat \ Quabeck HQ 3.5/12 R/C sailplane airfoil \ hq3510.gif\ \ \ http://www.hq-modellflug.de
hq3513.dat \ Quabeck HQ 3.5/13 R/C sailplane airfoil \ hq3513.gif\ \ \ http://www.hq-modellflug.de
hq3514.dat \ Quabeck HQ 3.5/14 R/C sailplane airfoil \ hq3514.gif\ \ \ http://www.hq-modellflug.de
hq3518.dat \ Quabeck HQ 3.5/18 R/C sailplane airfoil \ hq3518.gif\ \ \ http://www.hq-modellflug.de
hq358.dat \ Quabeck HQ 3.5/8 R/C sailplane airfoil \ hq358.gif\ \ \ http://www.hq-modellflug.de
hq359.dat \ Quabeck HQ 3.5/9 R/C sailplane airfoil \ hq359.gif\ \ \ http://www.hq-modellflug.de
hsnlf213.dat \ NASA/Langley HSNLF(1)-0213 high speed natural laminar flow airfoil \ hsnlf213.gif\ \ \
ht05.dat \ Drela HT05 airfoil \ ht05.gif\ \ \ Ref [3]
ht08.dat \ Drela HT08 airfoil \ ht08.gif\ \ \ Ref [3]
ht12.dat \ Drela HT12 airfoil \ ht12.gif\ \ \ Ref [3]
ht22.dat \ Drela HT22 airfoil \ ht22.gif\ \ \ Ref [3]
ht23.dat \ Drela HT23 airfoil \ ht23.gif\ \ \ Ref [3]
A .  B .  C .  D .  E .  F .  G .  H .  I .  J .  K .  L .  M .  N .  O .  P .  Q .  R .  S .  T .  U .  V .  W .  X .  Y .  Z top
isa571.dat \ I.S.A. 571 airfoil \ isa571.gif\ \ \
isa960.dat \ I.S.A. 960 airfoil \ isa960.gif\ \ \
isa961.dat \ I.S.A. 961 airfoil \ isa961.gif\ \ \
isa962.dat \ I.S.A. 962 airfoil \ isa962.gif\ \ \
j5012.dat \ Jef Raskin (originator of the Apple Macintosh Project) J5012 airfoil \ j5012.gif\ \ \ Low Reynolds number data
jn153.dat \ Narramore JN153 airfoil \ jn153.gif\ \ \
joukowsk.dat \ 12% Joukowski airfoil \ joukowsk.gif\ \ \
k1.dat \ NYU/Grumman K-1 transonic airfoil (GAC .75-.63-11.6) \ k1.gif\ \ \
k2.dat \ Grumman K-2 transonic airfoil (GAC .80-.53-10.3) \ k2.gif\ \ \
k3.dat \ Grumman K-3 transonic airfoil (GAC .70-.83-17.5) \ k3.gif\ \ \
k3311.dat \ Leon Kincaid K3311 airfoil (original) \ k3311.gif\ \ \ Low Reynolds number data
k3311sm.dat \ Leon Kincaid K3311 airfoil (smoothed) \ k3311sm.gif\ \ \ Low Reynolds number data
kc135a.dat \ Boeing KC-135 transonic airfoils \ kc135a.gif\ \ \
kc135b.dat \ continued \ kc135b.gif\ \ \
kc135c.dat \ continued \ kc135c.gif\ \ \
kc135d.dat \ continued \ kc135d.gif\ \ \
kenmar.dat \ University of Alberta/Kennedy and Marsden high lift airfoil \ kenmar.gif\ \ \
l188root.dat \ Lockheed L-188/P-3 root airfoil NACA 0014 -1.10 40/1.051 Cli=.3 a=.8 \ l188root.gif\ \ \
l188tip.dat \ Lockheed L-188/P-3 tip airfoil NACA 0012 -1.10 40/1.051 Cli=.4 a=.8 \ l188tip.gif\ \ \
l7769.dat \ Lissaman 7769 human powered aircraft airfoil \ l7769.gif\ \ \
la2573a.dat \ Liebeck LA2573A airfoil \ la2573a.gif\ \ \
la203a.dat \ Douglas/Liebeck LA203A high lift airfoil \ la203a.gif\ \ \
lds2.dat \ LDS-2 airfoil \ lds2.gif\ \ \ ref/lds2_ref.html
lg10sc.dat \ Lockheed-Georgia/NASA/Blackwell rotorcraft airfoil \ lg10sc.gif\ \ \
lnv109a.dat \ Douglas/Liebeck LNV109A high lift airfoil \ lnv109a.gif\ \ \
lrn1007.dat \ LRN(1)-1007 low Reynolds number airfoil \ lrn1007.gif\ \ \ Ref [1] Low Reynolds number data
ls013.dat \ NASA/Langley LS(1)-0013 general aviation airfoil \ ls013.gif\ \ \
ls413.dat \ NASA/Langley LS(1)-0413 (GA(W)-2) general aviation airfoil \ ls413.gif\ \ ref/ls0413_ref.html
ls413mod.dat \ NASA/Langley LS(1)-0413MOD general aviation airfoil \ ls413mod.gif\ \ \
ls417.dat \ NASA/Langley/Whitcomb LS(1)-0417 (GA(W)-1) general aviation airfoil \ ls417.gif\ \ \
ls417mod.dat \ NASA/Langley LS(1)-0417MOD general aviation airfoil \ ls417mod.gif\ \ \
ls421.dat \ NASA/Langley LS(1)-0421 general aviation airfoil \ ls421.gif\ \ \
ls421mod.dat \ NASA/Langley LS(1)-0421MOD general aviation airfoil \ ls421mod.gif\ \ \
lwk79100.dat \ LWK 79-100 symmetrical airfoil \ lwk79100.gif\ \ \ Ref [2]
lwk80080.dat \ LWK 80-080 symmetrical airfoil \ lwk80080.gif\ \ \ Ref [2]
lwk80100.dat \ LWK 80-100 symmetrical airfoil \ lwk80100.gif\ \ \ Ref [2]
lwk80120k25.dat \ LWK 80-120/K25 symmetrical airfoil \ lwk80120k25.gif\ \ \ Ref [2]
lwk80150k25.dat \ LWK 80-150/K25 symmetrical airfoil \ lwk80150k25.gif\ \ \ Ref [2]
m1.dat \ NACA/Munk M-1 airfoil \ m1.gif\ \ \
m10.dat \ NACA/Munk M-10 airfoil \ m10.gif\ \ \
m11.dat \ NACA/Munk M-11 airfoil \ m11.gif\ \ \
m12.dat \ NACA/Munk M-12 airfoil \ m12.gif\ \ \
m13.dat \ NACA/Munk M-13 airfoil \ m13.gif\ \ \
m14.dat \ NACA/Munk M-14 airfoil \ m14.gif\ \ \
m15.dat \ NACA/Munk M-15 airfoil \ m15.gif\ \ \
m16.dat \ NACA/Munk M-16 airfoil \ m16.gif\ \ \
m17.dat \ NACA/Munk M-17 airfoil \ m17.gif\ \ \
m18.dat \ NACA/Munk M-18 airfoil \ m18.gif\ \ \
m19.dat \ NACA/Munk M-19 airfoil \ m19.gif\ \ \
m2.dat \ NACA/Munk M-2 airfoil \ m2.gif\ \ \
m20.dat \ NACA/Munk M-20 airfoil \ m20.gif\ \ \
m21.dat \ NACA/Munk M-21 airfoil \ m21.gif\ \ \
m22.dat \ NACA/Munk M-22 airfoil \ m22.gif\ \ \
m23.dat \ NACA/Munk M-23 airfoil \ m23.gif\ \ \
m24.dat \ NACA/Munk M-24 airfoil \ m23.gif\ \ \
m25.dat \ NACA/Munk M-25 airfoil \ m25.gif\ \ \
m26.dat \ NACA/Munk M-26 airfoil \ m26.gif\ \ \
m27.dat \ NACA/Munk M-27 airfoil \ m27.gif\ \ \
m3.dat \ NACA/Munk M-3 airfoil \ m3.gif\ \ \
m4.dat \ NACA/Munk M-4 airfoil \ m4.gif\ \ \
m5.dat \ NACA/Munk M-5 airfoil \ m5.gif\ \ \
m6.dat \ NACA/Munk M-6 airfoil \ m6.gif\ \ \
m665.dat \ NACA/Munk M6 (65%) \ m665.gif\ \ \ Low Reynolds number data
m685.dat \ NACA/Munk M6 (85%) \ m685.gif\ \ \ Low Reynolds number data
m7.dat \ NACA/Munk M-7 airfoil \ m7.gif\ \ \
m8.dat \ NACA/Munk M-8 airfoil \ m8.gif\ \ \
m9.dat \ NACA/Munk M-9 airfoil \ m9.gif\ \ \
ma409.dat \ Michael Achterberg MA409 F1C class free flight airfoil (original) \ ma409.gif\ \ \ Low Reynolds number data
ma409sm.dat \ Michael Achterberg MA409 F1C class free flight airfoil (smoothed) \ ma409sm.gif\ \ \ Low Reynolds number data
marsden.dat \ Marsden airfoil \ marsden.gif\ \ \
marske1.dat \ Marske XM-1D airfoil (F14-3.0) \ marske1.gif\ \ \
marske2.dat \ Marske Pioneer IA airfoil (NACA 23112/43012A hybrid) \ marske2.gif\ \ \
marske3.dat \ Marske Pioneer IID root airfoil (NACA 43012A/24112 hybrid) \ marske3.gif\ \ \
marske4.dat \ Marske Pioneer IID tip airfoil (NACA 43012A*.833 hybrid) \ marske4.gif\ \ \
marske5.dat \ Marske Monarch airfoil (NACA 43012A) \ marske5.gif\ \ \
marske7.dat \ Roncz/Marske-7 low drag flying wing airfoil \ marske7.gif\ \ \
mb253515sm.dat \ Mike Bame MB253515 low Reynolds number airfoil \ mb253515sm.gif\ \ \
mh102.dat \ Martin Hepperle MH 102 for stall controlled wind turbines (root) \ mh102.gif\ \ \
mh104.dat \ Martin Hepperle MH 104 for stall controlled wind turbines \ mh104.gif\ \ \
mh106.dat \ Martin Hepperle MH 106 for stall controlled wind turbines \ mh106.gif\ \ \
mh108.dat \ Martin Hepperle MH 108 for stall controlled wind turbines \ mh108.gif\ \ \
mh110.dat \ Martin Hepperle MH 110 for stall controlled wind turbines (tip) \ mh110.gif\ \ \
mh112.dat \ Martin Hepperle MH 112 for a propeller for ultralight (root) \ mh112.gif\ \ \
mh113.dat \ Martin Hepperle MH 113 for a propeller for ultralight \ mh113.gif\ \ \
mh114.dat \ Martin Hepperle MH 114 for a propeller for ultralight \ mh114.gif\ \ \
mh115.dat \ Martin Hepperle MH 115 for a propeller for ultralight \ mh115.gif\ \ \
mh116.dat \ Martin Hepperle MH 116 for a propeller for ultralight \ mh116.gif\ \ \
mh117.dat \ Martin Hepperle MH 117 for a propeller for ultralight (tip) \ mh117.gif\ \ \
mh120.dat \ Martin Hepperle MH 120 for tip section of a propeller \ mh120.gif\ \ \
mh121.dat \ Martin Hepperle MH 121 for tip section of a propeller \ mh121.gif\ \ \
mh122.dat \ Martin Hepperle MH 122 for tip section of a propeller \ mh122.gif\ \ \
mh150.dat \ Martin Hepperle MH 150 for marine ruddershaft for torque reduction (schottel units) \ mh150.gif\ \ \
mh152.dat \ Martin Hepperle MH 152 for marine ruddershaft for torque reduction (schottel units) \ mh152.gif\ \ \
mh18.dat \ Martin Hepperle MH 18 for F3D Pylon Racing \ mh18.gif\ \ \
mh18.dat \ Martin Hepperle MH 18 low Reynolds number airfoil \ mh18.gif\ \ \
mh20.dat \ Martin Hepperle MH 20 for F3D Pylon Racing \ mh20.gif\ \ \
mh20.dat \ Martin Hepperle MH 20 low Reynolds number airfoil \ mh20.gif\ \ \
mh200.dat \ Martin Hepperle MH 200 for a canard airplane (main wing) \ mh200.gif\ \ \
mh201.dat \ Martin Hepperle MH 201 for a canard airplane (canard) \ mh201.gif\ \ \
mh22.dat \ Martin Hepperle MH 22 for F3D Pylon Racing \ mh22.gif\ \ \
mh22.dat \ Martin Hepperle MH 22 low Reynolds number airfoil \ mh22.gif\ \ \
mh23.dat \ Martin Hepperle MH 23 for F3D Pylon Racing (extended laminar flow) \ mh23.gif\ \ \
mh24.dat \ Martin Hepperle MH 24 for F3D Pylon Racing (extended laminar flow) \ mh24.gif\ \ \
mh25.dat \ Martin Hepperle MH 25 for F3D Pylon Racing (extended laminar flow) \ mh25.gif\ \ \
mh26.dat \ Martin Hepperle MH 26 for F3D Pylon Racing (extended laminar flow) \ mh26.gif\ \ \
mh27.dat \ Martin Hepperle MH 27 for F3D Pylon Racing (extended laminar flow) \ mh27.gif\ \ \
mh30.dat \ Martin Hepperle MH 30 for F3E and F3B \ mh30.gif\ \ \
mh30.dat \ Martin Hepperle MH 30 low Reynolds number airfoil \ mh30.gif\ \ \
mh32.dat \ Martin Hepperle MH 32 for F3E and F3B \ mh32.gif\ \ \ Low Reynolds number data
mh32.dat \ Martin Hepperle MH 32 low Reynolds number airfoil \ mh32.gif\ \ \
mh33.dat \ Martin Hepperle MH 33 for F3E and F3B \ \ \ \ MH 33 Ref
mh38.dat \ Martin Hepperle MH 38 for Endurance Model \ mh38.gif\ \ \
mh41.dat \ Martin Hepperle MH 41 for Endurance Model \ mh41.gif\ \ \
mh42.dat \ Martin Hepperle MH 42 for F3B and F3E \ mh42.gif\ \ \
mh42.dat \ Martin Hepperle MH 42 low Reynolds number airfoil \ mh42.gif\ \ \
mh43.dat \ Martin Hepperle MH 43 for F3B and F3E \ mh43.gif\ \ \
mh43.dat \ Martin Hepperle MH 43 low Reynolds number airfoil \ mh43.gif\ \ \
mh44.dat \ Martin Hepperle MH 44 for flying wings \ mh44.gif\ \ \
mh45.dat \ Martin Hepperle MH 45 for flying wings \ mh45.gif\ \ \
mh45.dat \ Martin Hepperle MH 45 low Reynolds number airfoil \ mh45.gif\ \ \ Low Reynolds number data
mh46.dat \ Martin Hepperle MH 46 for flying wings \ mh46.gif\ \ \
mh60.dat \ Martin Hepperle MH 60 for flying wings \ mh60.gif\ \ \
mh60.dat \ Martin Hepperle MH 60 low Reynolds number airfoil \ mh60.gif\ \ \
mh61.dat \ Martin Hepperle MH 61 for flying wings \ mh61.gif\ \ \
mh61.dat \ Martin Hepperle MH 61 low Reynolds number airfoil \ mh61.gif\ \ \
mh62.dat \ Martin Hepperle MH 62 for flying wings \ mh62.gif\ \ \
mh62.dat \ Martin Hepperle MH 62 low Reynolds number airfoil \ mh62.gif\ \ \
mh64.dat \ Martin Hepperle MH 64 for flying wings \ mh62.gif\ \ \
mh70.dat \ Martin Hepperle MH 70 for fying wing (full size) \ mh70.gif\ \ \
mh78.dat \ Martin Hepperle MH 78 for flying wings (hang glider) \ mh78.gif\ \ \
mh80.dat \ Martin Hepperle MH 80 for flying wings (hang glider) \ mh80.gif\ \ \
mh81.dat \ Martin Hepperle MH 81 for flying wings (hang glider) \ mh81.gif\ \ \
mh82.dat \ Martin Hepperle MH 82 for flying wings (hang glider) \ mh82.gif\ \ \
mh83.dat \ Martin Hepperle MH 83 for flying wings (hang glider) \ mh83.gif\ \ \
mh84.dat \ Martin Hepperle MH 84 for flying wings (hang glider) \ mh84.gif\ \ \
mh85.dat \ Martin Hepperle MH 85 for flying wings (hang glider) \ \ \ \ missing
mh86.dat \ Martin Hepperle MH 86 for flying wings (hang glider) \ \ \ \ missing
mh87.dat \ Martin Hepperle MH 87 for flying wings (hang glider) \ \ \ \ missing
mh91.dat \ Martin Hepperle MH 91 parafoil \ mh91.gif\ \ \
mh92.dat \ Martin Hepperle MH 92 parafoil \ mh92.gif\ \ \
mh93.dat \ Martin Hepperle MH 93 parafoil \ mh93.gif\ \ \
mh94.dat \ Martin Hepperle MH 94 parafoil \ mh94.gif\ \ \
mh95.dat \ Martin Hepperle MH 95 parafoil \ mh95.gif\ \ \
miley.dat \ Miley MO6-13-128 airfoil \ miley.gif\ \ \ Low Reynolds number data
mrc-16.dat \ Drela MRC-16 \ mrc-16.gif\ \ \ ref/mrc-16_ref.html
mrc-20.dat \ Drela MRC-20 \ mrc-20.gif\ \ \ ref/mrc-20_ref.html
ms313.dat \ NASA/Langley MS(1)-0313 general aviation airfoil (buggy, shows the 0413 instead) \ mrc-20.gif\ \ \
ms317.dat \ NASA/Langley MS(1)-0317 general aviation airfoil \ ms317.gif\ \ \
mue139.dat \ MUE 139 airfoil \ mue139.gif\ \ \ Ref [2]
n0009sm.dat \ NACA 0009 airfoil (smoothed) \ n0009sm.gif\ \ \
n0011sc.dat \ NASA/Langley 11% symmetrical supercritical airfoil \ n0011sc.gif\ \ \
n0012.dat \ NACA 0012 airfoil \ n0012.gif\ \ \
n10.dat \ N-10 airfoil \ n10.gif\ \ \
n11.dat \ N-11 airfoil \ n11.gif\ \ \
n11h9.dat \ NACA 11-H-9 rotorcraft airfoil \ n11h9.gif\ \ \
n12.dat \ N-12 airfoil \ n12.gif\ \ \
n13.dat \ N-13 airfoil \ n13.gif\ \ \
n14.dat \ N-14 airfoil \ n14.gif\ \ \
n1h15.dat \ NACA 1-H-15 rotorcraft airfoil \ n1h15.gif\ \ \
n22.dat \ N-22 airfoil \ n22.gif\ \ \
n24.dat \ N-24 airfoil \ n22.gif\ \ \
n2414.dat \ NACA 2414 airfoil \ n2414.gif\ \ \ Low Reynolds number data
n2415.dat \ NACA 2415 airfoil \ n2415.gif\ \ \ Low Reynolds number data
n2h15.dat \ NACA 2-H-15 rotorcraft airfoil \ n2h15.gif\ \ \
n5h10.dat \ NACA 5-H-10 rotorcraft airfoil \ n5h10.gif\ \ \
n5h15.dat \ NACA 5-H-15 rotorcraft airfoil \ n5h15.gif\ \ \
n5h20.dat \ NACA 5-H-20 rotorcraft airfoil \ n5h20.gif\ \ \
n63010a.dat \ NACA 63-010A airfoil \ n63010a.gif\ \ \
n63012a.dat \ NACA 63-012A airfoil \ n63012a.gif\ \ \
n63015a.dat \ NACA 63-015A airfoil \ n63015a.gif\ \ \
n63210.dat \ NACA 63-210 airfoil \ n63210.gif\ \ \
n63212.dat \ NACA 63(1)-212 airfoil \ n63212.gif\ \ \
n63215.dat \ NACA 63(2)-215 airfoil \ n63215.gif\ \ \
n63215b.dat \ NACA-NASA/AMES/Hicks 63(2)-215 MOD B airfoil \ n63215b.gif\ \ \
n63412.dat \ NACA 63(1)-412 airfoil \ n63412.gif\ \ \
n63415.dat \ NACA 63(2)-415 airfoil \ n63415.gif\ \ \
n64008a.dat \ NACA 64-008A airfoil \ n64008a.gif\ \ \
n64012.dat \ NACA 64(1)-012 airfoil \ n64012.gif\ \ \
n64012a.dat \ NACA 64(1)-012A airfoil \ n64012a.gif\ \ \
n64015.dat \ NACA 64(2)-015 airfoil \ n64015.gif\ \ \
n64015a.dat \ NACA 64(2)-015A airfoil \ n64015a.gif\ \ \
n6409.dat \ NACA 6409 \ n6409.gif\ \ \
n64108.dat \ NACA 64-108 airfoil \ n64108.gif\ \ \
n64110.dat \ NACA 64-110 airfoil \ n64110.gif\ \ \
n64212.dat \ NACA 64(1)-212 airfoil \ n64212.gif\ \ \
n64212ma.dat \ NACA-NASA/AMES/Hicks 63(1)-212 MOD A airfoil \ n64212ma.gif\ \ \
n64212mb.dat \ NACA-NASA/AMES/Hicks 63(1)-212 MOD B airfoil \ n64212mb.gif\ \ \
n64215.dat \ NACA 64(2)-215 airfoil \ n64215.gif\ \ \
n642415.dat \ NACA 64(2)-415 [NACA 6a series from Theory of Wing Sections] \ n642415.gif\ \ \ ref/n642415_ref.html
n66021.dat \ NACA 66(4)-021 airfoil \ n66021.gif\ \ \
n6h10.dat \ NACA 6-H-10 rotorcraft airfoil \ n6h10.gif\ \ \
n6h15.dat \ NACA 6-H-15 rotorcraft airfoil \ n6h15.gif\ \ \
n6h20.dat \ NACA 6-H-20 rotorcraft airfoil \ n6h20.gif\ \ \
n8h12.dat \ NACA 8-H-12 rotorcraft airfoil \ n8h12.gif\ \ \
n9.dat \ N-9 airfoil \ n9.gif\ \ \
naca0006.dat \ NACA 0006 airfoil \ naca0006.gif\ \ \
naca0008.dat \ NACA 0008 airfoil \ naca0008.gif\ \ \
naca000834.dat \ NACA 0008-34 airfoil \ naca000834.gif\ \ \
naca0010.dat \ NACA 0010 airfoil \ naca0010.gif\ \ \
naca001034.dat \ NACA 0010-34 airfoil \ naca001034.gif\ \ \
naca001034a08cli0.2.dat \ NACA 0010-34 a=0.8 c(li)=0.2 airfoil \ naca001034a08cli0.2.gif\ \ \
naca001035.dat \ NACA 0010-35 airfoil \ naca001035.gif\ \ \
naca001064.dat \ NACA 0010-64 airfoil \ naca001064.gif\ \ \
naca001065.dat \ NACA 0010-65 airfoil \ naca001065.gif\ \ \
naca001066.dat \ NACA 0010-66 airfoil \ naca001066.gif\ \ \
naca001234.dat \ NACA 0012-34 airfoil \ naca001234.gif\ \ \
naca001264.dat \ NACA 0012-64 airfoil \ naca001264.gif\ \ \
naca001264a08cli0.2.dat \ NACA 0012-64 a=0.8 c(li)=0.2 airfoil \ naca001264a08cli0.2.gif\ \ \
naca0015.dat \ NACA 0015 airfoil \ naca0015.gif\ \ \
naca0018.dat \ NACA 0018 airfoil \ naca0018.gif\ \ \
naca0021.dat \ NACA 0021 airfoil \ naca0021.gif\ \ \
naca0024.dat \ NACA 0024 airfoil \ naca0024.gif\ \ \
naca1.dat \ NACA-1 COWL \ naca1.gif\ \ \ ref/naca1_ref.html
naca1408.dat \ NACA 1408 airfoil \ naca1408.gif\ \ \
naca1410.dat \ NACA 1410 airfoil \ naca1410.gif\ \ \
naca1412.dat \ NACA 1412 airfoil \ naca1412.gif\ \ \
naca16006.dat \ NACA 16-006 airfoil \ naca16006.gif\ \ \
naca16009.dat \ NACA 16009 airfoil \ naca16009.gif\ \ \
naca16012.dat \ NACA 16-012 airfoil \ naca16012.gif\ \ \
naca16015.dat \ NACA 16-015 airfoil \ naca16015.gif\ \ \
naca16018.dat \ NACA 16-018 airfoil \ naca16018.gif\ \ \
naca16021.dat \ NACA 16-021 airfoil \ naca16018.gif\ \ \
naca23012.dat \ NACA 23012 airfoil \ naca23012.gif\ \ \
naca23015.dat \ NACA 23015 airfoil \ naca23015.gif\ \ \
naca23018.dat \ NACA 23018 airfoil \ naca23018.gif\ \ \
naca23021.dat \ NACA 23021 airfoil \ naca23021.gif\ \ \
naca23024.dat \ NACA 23024 airfoil \ naca23024.gif\ \ \
naca2408.dat \ NACA 2408 airfoil \ naca2408.gif\ \ \
naca2410.dat \ NACA 2410 airfoil \ naca2410.gif\ \ \
naca2411.dat \ NACA 2411 airfoil \ naca2411.gif\ \ \
naca2412.dat \ NACA 2412 airfoil \ naca2412.gif\ \ \
naca2415.dat \ NACA 2415 airfoil \ naca2415.gif\ \ \
naca2418.dat \ NACA 2418 airfoil \ naca2418.gif\ \ \
naca2421.dat \ NACA 2421 airfoil \ naca2421.gif\ \ \
naca2424.dat \ NACA 2424 airfoil \ naca2424.gif\ \ \
naca4412.dat \ NACA 4412 airfoil \ naca4412.gif\ \ \
naca4415.dat \ NACA 4415 airfoil \ naca4415.gif\ \ \
naca4418.dat \ NACA 4418 airfoil \ naca4418.gif\ \ \
naca4421.dat \ NACA 4421 airfoil \ naca4421.gif\ \ \
naca4424.dat \ NACA 4424 airfoil \ naca4424.gif\ \ \
naca63206.dat \ NACA 63-206 airfoil \ naca63206.gif\ \ \
naca63209.dat \ NACA 63-209 airfoil \ naca63209.gif\ \ \
naca632615.dat \ NACA 63(2)-615 airfoil \ naca632615.gif\ \ \
naca632a015.dat \ NACA 63(2)A-015 airfoil \ naca632a015.gif\ \ \ Ref [2]
naca633018.dat \ NACA 63(3)-018 airfoil \ naca633018.gif\ \ \ Ref [2]
naca633218.dat \ NACA 63(3)-218 airfoil \ naca633218.gif\ \ \
naca633418.dat \ NACA 63,3-418 airfoil \ naca633418.gif\ \ \
naca633618.dat \ NACA 63(3)-618 airfoil \ naca633618.gif\ \ \
naca634221.dat \ NACA 63(4)-221 airfoil \ naca634221.gif\ \ \
naca634421.dat \ NACA 63(4)-421 airfoil \ naca634421.gif\ \ \
naca63a210.dat \ NACA 63A210 airfoil \ naca63a210.gif\ \ \
naca641112.dat \ NACA 64(1)-112 airfoil \ naca641112.gif\ \ \
naca6412.dat \ NACA 6412 airfoil \ naca641112.gif\ \ \
naca64206.dat \ NACA 64-206 airfoil \ naca64206.gif\ \ \
naca64208.dat \ NACA 64-208 airfoil \ naca64208.gif\ \ \
naca64209.dat \ NACA 64-209 airfoil \ naca64209.gif\ \ \
naca64210.dat \ NACA 64-210 airfoil \ naca64210.gif\ \ \
naca642215.dat \ NACA 64(2)-215 airfoil \ naca642215.gif\ \ \
naca642415.dat \ NACA 64(2)-415 airfoil \ naca642415.gif\ \ \
naca643218.dat \ NACA 64(3)-218 airfoil \ naca643218.gif\ \ \
naca643418.dat \ NACA 64(3)-418 airfoil \ naca643418.gif\ \ \
naca643618.dat \ NACA 64(3)-618 airfoil \ naca643618.gif\ \ \
naca644221.dat \ NACA 64(4)-221 airfoil \ naca644221.gif\ \ \
naca644421.dat \ NACA 64(4)-421 airfoil \ naca644421.gif\ \ \
naca64a010.dat \ NACA 64A010 airfoil \ naca64a010.gif\ \ \
naca64a210.dat \ NACA 64A210 airfoil \ naca64a210.gif\ \ \
naca64a410.dat \ NACA 64A410 airfoil \ naca64a410.gif\ \ \
naca651212.dat \ NACA 65(1)-212 airfoil \ naca651212.gif\ \ \
naca651212a06.dat \ NACA 65(1)-212 a=0.6 airfoil \ naca651212.gif\ \ \
naca651412.dat \ NACA 65(1)-412 airfoil \ naca651412.gif\ \ \
naca65206.dat \ NACA 65-206 airfoil \ naca65206.gif\ \ \
naca65209.dat \ NACA 65-209 airfoil \ naca65209.gif\ \ \
naca65210.dat \ NACA 65-210 airfoil \ naca65210.gif\ \ \
naca652215.dat \ NACA 65(2)-215 airfoil \ naca652215.gif\ \ \
naca652415.dat \ NACA 65(2)-415 airfoil \ naca652415.gif\ \ \
naca652415a05.dat \ NACA 65(2)-415 a=0.5 airfoil \ naca652415a05.gif\ \ \
naca653218.dat \ NACA 65(3)-218 airfoil \ naca653218.gif\ \ \
naca653618.dat \ NACA 65(3)-618 airfoil \ naca653618.gif\ \ \
naca65410.dat \ NACA 65-410 airfoil \ naca65410.gif\ \ \
naca654221.dat \ NACA 65(4)-221 airfoil \ naca654221.gif\ \ \
naca654421.dat \ NACA 65(4)-421 airfoil \ naca654421.gif\ \ \
naca654421a05.dat \ NACA 65(4)-421 a=0.5 airfoil \ naca654421a05.gif\ \ \
naca66-018.dat \ NACA 66-018 airfoil \ naca66-018.gif\ \ \
naca661212.dat \ NACA 66(1)-212 airfoil \ naca661212.gif\ \ \
naca66206.dat \ NACA 66-206 airfoil \ naca66206.gif\ \ \
naca66209.dat \ NACA 66-209 airfoil \ naca66209.gif\ \ \
naca66210.dat \ NACA 66-210 airfoil \ naca66210.gif\ \ \
naca662215.dat \ NACA 66(2)-215 airfoil \ naca662215.gif\ \ \
naca662415.dat \ NACA 66(2)-415 airfoil \ naca662415.gif\ \ \
naca663218.dat \ NACA 66(3)-218 airfoil \ naca663218.gif\ \ \
naca663418.dat \ NACA 66(3)-418 airfoil \ naca663418.gif\ \ \
naca664221.dat \ NACA 66(4)-221 airfoil \ naca664221.gif\ \ \
naca671215.dat \ NACA 67,1-215 airfoil \ naca671215.gif\ \ \
naca747a315.dat \ NACA 747A315 airfoil \ naca747a315.gif\ \ \
naca747a415.dat \ NACA 747A415 airfoil \ naca747a415.gif\ \ \
nacacyh.dat \ NACA CYH airfoil \ nacacyh.gif\ \ \
nacam12.dat \ NACA M12 airfoil \ nacam12.gif\ \ \
nacam18.dat \ NACA M18 airfoil \ nacam18.gif\ \ \
nacam2.dat \ NACA M2 airfoil \ nacam2.gif\ \ \
nacam3.dat \ NACA M3 airfoil \ nacam3.gif\ \ \
nacam6.dat \ NACA M6 airfoil \ nacam6.gif\ \ \
nasasc2-0714.dat \ NASA SC(2)-0714 airfoil (Ref. NASA TP-2890) \ nasasc2-0714.gif\ \ \ ref/nasasc-2-714_ref.html
ncambre.dat \ ONERA/Aerospatiale NACA-CAMBRE rotorcraft airfoil \ ncambre.gif\ \ \
nl722343.dat \ NLR NLR-7223-43 transonic rotorcraft airfoil \ nl722343.gif\ \ \
nl722362.dat \ NLR NLR-7223-62 transonic rotorcraft airfoil \ nl722362.gif\ \ \
nlf0115.dat \ NASA/Langley/Somers-Selig-Maughmer NLF(1)-0115 natural laminar flow airfoil \ nlf0115.gif\ \ \ NLF 0115 publication
nlf0215f.dat \ NASA/Langley/Somers NLF(1)-0215F natural laminar flow airfoil \ nlf0215f.gif\ \ \ See NASA TP-1865
nlf1015.dat \ NASA/Langley/Somers-Maughmer NLF(1)-1015 natural laminar flow airfoil \ nlf1015.gif\ \ \
nlf414f.dat \ NASA/Langley/Viken NLF(1)-0414F natural laminar flow airfoil \ nlf414f.gif\ \ \
nlf415.dat \ NASA/Langley-DFVLR/Somers(NASA)-Horstmann(DFVLR) NLF(2)-0415 natural laminar flow airfoil \ nlf415.gif\ \ \
nlf416.dat \ NASA/Langley/Somers NLF(1)-0416 natural laminar flow airfoil \ nlf416.gif\ \ \ See NASA TP-1861
nlr1t.dat \ Bell/NASA/NLR NLR-1T rotorcraft airfoil \ nlr1t.gif\ \ \
nlr7301.dat \ NLR NLR-7301 transonic airfoil \ nlr7301.gif\ \ \
nn7mk20.dat \ NN7 MK20 airfoil \ nn7mk20.gif\ \ \ Ref [2]
npl9510.dat \ NPL 9510 transonic airfoil \ npl9510.gif\ \ \
npl9615.dat \ NPL 9615 rotorcraft airfoil \ npl9615.gif\ \ \
npl9626.dat \ NPL 9626 rotorcraft airfoil \ npl9626.gif\ \ \
npl9627.dat \ NPL 9627 rotorcraft airfoil \ npl9627.gif\ \ \
npl9660.dat \ NPL 9660 rotorcraft airfoil \ npl9660.gif\ \ \
nplx.dat \ NPL transonic airfoil FROM ARC CP 1372 \ nplx.gif\ \ \
oa206.dat \ ONERA/Aerospatiale OA206 rotorcraft airfoil (Constructed from patent and smoothed) \ oa206.gif\ \ \
oa209.dat \ ONERA/Aerospatiale OA209 rotorcraft airfoil (Constructed from patent and smoothed) \ oa209.gif\ \ \
oa212.dat \ ONERA/Aerospatiale OA212 rotorcraft airfoil (Constructed from patent and smoothed) \ oa212.gif\ \ \
oa213.dat \ ONERA/Aerospatiale OA213 rotorcraft airfoil (Constructed from patent and smoothed) \ oa213.gif\ \ \
oaf095.dat \ ONERA/Aerospatiale OAF095 Fenestron airfoil \ oaf095.gif\ \ \
oaf102.dat \ ONERA/Aerospatiale OAF102 Fenestron airfoil \ oaf102.gif\ \ \
oaf117.dat \ ONERA/Aerospatiale OAF117 Fenestron airfoil \ oaf117.gif\ \ \
oaf128.dat \ ONERA/Aerospatiale OAF128 Fenestron airfoil \ oaf128.gif\ \ \
oaf139.dat \ ONERA/Aerospatiale OAF139 Fenestron airfoil \ oaf139.gif\ \ \
p51droot.dat \ P-51D root (BL17.5) airfoil \ p51droot.gif\ \ \
p51dtip.dat \ P-51D tip (BL215) airfoil \ p51dtip.gif\ \ \
p51hroot.dat \ NACA 66,2-(1.8)15.5 A=.6 P-51H root airfoil \ p51hroot.gif\ \ \
p51htip.dat \ NACA 66,2-(1.8)12 A=.6 P-51H tip airfoil \ p51htip.gif\ \ \
pfcm.dat \ Propfan Cruise Missile wing airfoil \ pfcm.gif\ \ \ ref/pfcm_ref.html
pmc19sm.dat \ PMC19 \ pmc19sm.gif\ \ \
psu-90-125wl.dat \ PSU-90-125WL sailplane winglet airfoil \ psu-90-125wl.gif\ \ \ ref/psu-90-125wl_ref.html
psu94097.dat \ Maughmer PSU 94-097 winglet airfoil \ psu94097.gif\ \ \
pt40.dat \ Great Plane PT-40 trainer airfoil \ pt40.gif\ \ \ Low Reynolds number data
r1046.dat \ Roncz 1046 Voyager canard airfoil \ r1046.gif\ \ \
r1080.dat \ Roncz 1080 Voyager inner aft wing airfoil \ r1080.gif\ \ \
r1082.dat \ Roncz 1082 Voyager root outer aft wing airfoil \ r1082.gif\ \ \
r1082t.dat \ Roncz 1082T Voyager tip outer aft wing airfoil \ r1082t.gif\ \ \
r140.dat \ R140 Quickee 500 airfoil (original) \ r140.gif\ \ \
r140sm.dat \ R140 Quickee 500 airfoil (smoothed) \ r140sm.gif\ \ \
rae100.dat \ RAE 100 airfoil \ rae100.gif\ \ \ ref/rae_ref.html
rae101.dat \ RAE 101 airfoil \ rae101.gif\ \ \ ref/rae_ref.html
rae102.dat \ RAE 102 airfoil \ rae102.gif\ \ \ ref/rae_ref.html
rae103.dat \ RAE 103 airfoil \ rae103.gif\ \ \ ref/rae_ref.html
rae104.dat \ RAE 104 airfoil \ rae104.gif\ \ \ ref/rae_ref.html
rae2822.dat \ RAE 2822 transonic airfoil \ rae2822.gif\ \ \
rae5212.dat \ RAE(NPL) 5212 transonic airfoil \ rae5212.gif\ \ \
rae5213.dat \ RAE(NPL) 5213 transonic airfoil \ rae5213.gif\ \ \
rae5214.dat \ RAE 5214 transonic airfoil \ rae5214.gif\ \ \
rae5215.dat \ RAE 5215 transonic airfoil \ rae5215.gif\ \ \
rae69ck.dat \ RAE6-9CK transonic airfoil \ rae69ck.gif\ \ \
raf15.dat \ RAF-15 airfoil \ raf15.gif\ \ \
raf19.dat \ RAF-19 airfoil \ raf19.gif\ \ \
raf25.dat \ RAF-25 airfoil \ raf25.gif\ \ \
raf26.dat \ RAF-26 airfoil \ raf26.gif\ \ \
raf27.dat \ RAF-27 airfoil \ raf27.gif\ \ \
raf28.dat \ RAF-28 airfoil \ raf28.gif\ \ \
raf30.dat \ RAF-30 airfoil \ raf30.gif\ \ \
raf30md.dat \ RAF-30 MOD airfoil \ raf30md.gif\ \ \
raf31.dat \ RAF-31 airfoil \ raf31.gif\ \ \
raf32.dat \ RAF-32 airfoil \ raf32.gif\ \ \
raf32md.dat \ RAF-32 MOD airfoil \ raf32md.gif\ \ \
raf33.dat \ RAF-33 airfoil \ raf33.gif\ \ \
raf34.dat \ RAF-34 airfoil \ raf34.gif\ \ \
raf38.dat \ RAF-38 airfoil \ raf38.gif\ \ \
raf48.dat \ RAF-48 airfoil \ raf48.gif\ \ \
raf6.dat \ RAF-6 airfoil \ raf6.gif\ \ \
raf69.dat \ RAF-69 airfoil \ raf69.gif\ \ \
raf89.dat \ RAF-89 airfoil \ raf89.gif\ \ \
rc0864c.dat \ NASA/Langley 08-64C rotorcraft airfoil \ rc0864c.gif\ \ \
rc08b3.dat \ NASA/Langley RC-08(B)3 rotorcraft airfoil \ rc08b3.gif\ \ \
rc08n1.dat \ NASA/Langley RC-08(N)1 rotorcraft airfoil \ rc08n1.gif\ \ \
rc1064c.dat \ NASA/Langley 10-64C rotorcraft airfoil \ rc1064c.gif\ \ \
rc10b3.dat \ NASA/Langley RC-10(B)3 rotorcraft airfoil \ rc10b3.gif\ \ \
rc10n1.dat \ NASA/Langley RC-10(N)1 rotorcraft airfoil \ rc10n1.gif\ \ \
rc1264c.dat \ NASA/Langley 12-64C rotorcraft airfoil \ rc1264c.gif\ \ \
rc12b3.dat \ NASA/Langley RC-12(B)3 rotorcraft airfoil \ rc12b3.gif\ \ \
rc12n1.dat \ NASA/Langley RC-12(N)1 rotorcraft airfoil \ rc12n1.gif\ \ \
rc410.dat \ NASA/Langley RC(4)-10 rotorcraft airfoil \ rc410.gif\ \ \
rc510.dat \ NASA/Langley RC(5)-10 rotorcraft airfoil \ rc510.gif\ \ \
rcsc2.dat \ NASA/Langley RC-SC2 rotorcraft airfoil \ rcsc2.gif\ \ \
rg12.dat \ Rolf Girsberger RG 12 airfoil \ rg12.gif\ \ \
rg12a.dat \ Rolf Girsberger RG 12A airfoil \ rg12a.gif\ \ \
rg12a189.dat \ Rolf Girsberger RG 12A-1.8/9.0 airfoil \ rg12a189.gif\ \ \
rg14.dat \ Rolf Girsberger RG 14 airfoil \ rg14.gif\ \ \ Low Reynolds number data
rg1410.dat \ Rolf Girsberger RG 14 (10%) airfoil \ rg1410.gif\ \ \
rg149.dat \ Rolf Girsberger RG 14 (9%) airfoil \ rg149.gif\ \ \
rg1495.dat \ Rolf Girsberger RG 14 (9.5%) airfoil \ rg1495.gif\ \ \
rg14a147.dat \ Rolf Girsberger RG 14A-1.4/7.0 airfoil \ rg14a147.gif\ \ \
rg15.dat \ Rolf Girsberger RG 15 low Reynolds number airfoil \ rg15.gif\ \ \ Low Reynolds number data
rg15a111.dat \ Rolf Girsberger RG 15A-1.8/11.0 airfoil \ rg15a111.gif\ \ \
rg15a213.dat \ Rolf Girsberger RG 15A 2.5/13.0 airfoil \ rg15a213.gif\ \ \
rg8.dat \ Rolf Girsberger RG 8 airfoil \ rg8.gif\ \ \
rhodesg30.dat \ Rhode St. Genese 30 airfoil \ rhodesg30.gif\ \ \
rhodesg32.dat \ Rhode St. Genese 32 airfoil \ rhodesg32.gif\ \ \
rhodesg34.dat \ Rhode St. Genese 34 airfoil \ rhodesg34.gif\ \ \
rhodesg36.dat \ Rhode St. Genese 36 airfoil \ rhodesg36.gif\ \ \
s1010.dat \ Selig S1010 HPV airfoil, used on the Cheetah HPV \ s1010.gif\ \ \
s1012.dat \ Selig S1012 HPV airfoil, used on the Cheetah HPV \ s1012.gif\ \ \
s1014.dat \ Selig S1014 HPV airfoil, used on the Cheetah HPV \ s1014.gif\ \ \
s1016.dat \ Selig S1016 HPV airfoil, used on the Cheetah HPV \ s1016.gif\ \ \
s1020.dat \ Selig S1020 ornithopter airfoil \ s1020.gif\ \ ref/s1020_ref.html
s1046.dat \ Selig S1046 airfoil \ s1046.gif\ \ \
s1048.dat \ Selig S1048 airfoil \ s1048.gif\ \ \
s1091.dat \ Selig S1091 airfoil \ s1091.gif\ \ \
s1210.dat \ Selig S1210 high lift low Reynolds number airfoil \ s1210.gif\ \ ref/s1210s1223_ref.html Low Reynolds number data
s1221.dat \ Selig S1221 airfoil \ s1221.gif\ \ \
s1223.dat \ Selig S1223 high lift low Reynolds number airfoil \ s1223.gif\ \ s1210s1223_ref.html Low Reynolds number data
s1223rtl.dat \ Richard T. LaSalle modification of the S1223 -> S1223RTL \ s1223rtl.gif\ \ \ Low Reynolds number data
s2027.dat \ Selig S2027 low Reynolds number airfoil \ s2027.gif\ \ \
s2046.dat \ Selig S2046 low Reynolds number airfoil \ s2046.gif\ \ \
s2048.dat \ Selig S2048 low Reynolds number airfoil \ s2048.gif\ \ \ Low Reynolds number data
s2050.dat \ Selig S2050 low Reynolds number airfoil \ s2050.gif\ \ \ Low Reynolds number data
s2055.dat \ Selig S2055 low Reynolds number airfoil \ s2055.gif\ \ \ Low Reynolds number data
s2060.dat \ Selig S2060 low Reynolds number airfoil \ s2060.gif\ \ \
s2062.dat \ Selig S2062 low Reynolds number airfoil \ s2062.gif\ \ \
s2091.dat \ Selig S2091 low Reynolds number airfoil \ s2091.gif\ \ \ Low Reynolds number data
s3.dat \ Republic S-3 airfoil (P-47 wing airfoil) \ s3.gif\ \ \
s3002.dat \ Selig S3002 low Reynolds number airfoil \ s3002.gif\ \ \
s3010.dat \ Selig S3010 low Reynolds number airfoil \ s3002.gif\ \ \ Low Reynolds number data
s3014.dat \ Selig S3014 low Reynolds number airfoil \ s3014.gif\ \ \ Low Reynolds number data
s3016.dat \ Selig S3016 low Reynolds number airfoil \ s3016.gif\ \ \ Low Reynolds number data
s3021.dat \ Selig S3021 low Reynolds number airfoil \ s3021.gif\ \ \ Low Reynolds number data
s3024.dat \ Selig S3024 low Reynolds number airfoil \ s3024.gif\ \ \
s3025.dat \ Selig S3025 low Reynolds number airfoil \ s3025.gif\ \ \
s4022.dat \ Selig S4022 low Reynolds number airfoil \ s4022.gif\ \ \
s4053.dat \ Selig S4053 low Reynolds number airfoil \ s4053.gif\ \ \
s4061.dat \ Selig S4061 low Reynolds number airfoil \ s4061.gif\ \ \ Low Reynolds number data
s4062.dat \ Selig S4062 low Reynolds number airfoil \ s4062.gif\ \ \ Low Reynolds number data
s4083.dat \ Selig S4083 low Reynolds number airfoil \ s4083.gif\ \ ref/s4083_ref.html
s4110.dat \ Selig S4110 low Reynolds number airfoil \ s4110.gif\ \ \
s4158.dat \ Selig S4158 low Reynolds number airfoil \ s4158.gif\ \ \
s4180.dat \ Selig S4180 low Reynolds number airfoil \ s4180.gif\ \ \ Low Reynolds number data
s4233.dat \ Selig S4233 low Reynolds number airfoil \ s4233.gif\ \ \ Low Reynolds number data
s4310.dat \ Selig S4310 low Reynolds number airfoil \ s4310.gif\ \ \
s4320.dat \ Selig S4320 low Reynolds number airfoil \ s4320.gif\ \ \
s5010.dat \ Selig S5010 low Reynolds number airfoil \ s5010.gif\ \ \ Low Reynolds number data
s5020.dat \ Selig S5020 low Reynolds number airfoil \ s5020.gif\ \ \
s6061.dat \ Selig S6061 low Reynolds number airfoil \ s6061.gif\ \ \
s6062.dat \ Selig S6062 low Reynolds number airfoil \ s6062.gif\ \ \ Low Reynolds number data
s6063.dat \ Selig S6063 low Reynolds number airfoil \ s6063.gif\ \ \ Low Reynolds number data
s7012.dat \ Selig S7012 low Reynolds number airfoil \ s7012.gif\ \ ref/s7012_ref.html Low Reynolds number data
s7055.dat \ Selig S7055 low Reynolds number airfoil \ s7055.gif\ \ ref/s7055_ref.html Low Reynolds number data
s7075.dat \ Selig S7075 low Reynolds number airfoil \ s7075.gif\ \ \ Low Reynolds number data
s8025.dat \ Selig S8025 low Reynolds number airfoil \ s8025.gif\ \ \ Low Reynolds number data
s8035.dat \ Selig S8035 low Reynolds number airfoil \ s8035.gif\ \ \
s8036.dat \ Selig S8036 low Reynolds number airfoil \ s8036.gif\ \ ref/s8036s8037_ref.html Low Reynolds number data
s8037.dat \ Selig S8037 low Reynolds number airfoil \ s8037.gif\ \ ref.s8036s8037_ref.html Low Reynolds number data
s8038.dat \ Selig S8038 (13%) low Reynolds number airfoil \ s8038.gif\ \ \
s8052.dat \ Selig S8052 low Reynolds number airfoil \ s8052.gif\ \ \ Low Reynolds number data
s8055.dat \ Selig S8055 (12%) low Reynolds number airfoil \ s8055.gif\ \ \
s9000.dat \ Selig S9000 (9%) low Reynolds number airfoil used on the Blackhawk R/C sailplane \ s9000.gif\ \ \ Ref [5]
s9026.dat \ Selig S9026 (9.5%) symmetrical horizontal stab airfoil used on the Opus R/C sailplane \ s9026.gif\ \ \ Ref [4]
s9027.dat \ Selig S9027 (8%) symmetrical vertical stab airfoil used on the Opus R/C sailplane \ s9027.gif\ \ \ Ref [4]
s9032.dat \ Selig S9032 (9%) symmetrical horizontal stab airfoil used on the Blackhawk R/C sailplane \ s9032.gif\ \ \ Ref [5]
s9033.dat \ Selig S9033 (7.5%) symmetrical vertical stab airfoil used on the Blackhawk R/C sailplane\ s9033.gif\ \ \ Ref [5]
s9037.dat \ Selig S9037 (9%) low Reynolds number airfoil used on the Opus R/C sailplane \ s9037.gif\ \ \ Ref [4]
sa7024.dat \ Selig / Ashok Gopalarathnam SA7024 low Reynolds number airfoil \ sa7024.gif\ \ \ Ref [7]
sa7025.dat \ Selig / Ashok Gopalarathnam SA7025 low Reynolds number airfoil \ sa7025.gif\ \ \ Ref [7]
sa7026.dat \ Selig / Ashok Gopalarathnam SA7026 low Reynolds number airfoil \ sa7026.gif\ \ \ Ref [7]
sa7035.dat \ Selig / Ashok Gopalarathnam SA7035 \ sa7035.gif\ \ \ ref/sa7035_ref.html Low Reynolds number data
sa7036.dat \ Selig / Ashok Gopalarathnam SA7036 \ sa7036.gif\ \ \ ref/sa7035_ref.html Low Reynolds number data
sa7038.dat \ Selig / Ashok Gopalarathnam SA7038 \ sa7038.gif\ \ \ ref/sa7035_ref.html Low Reynolds number data
saratov.dat \ Saratov R/C sailplane airfoil \ saratov.gif\ \ \
sc1012r8.dat \ Sikorsky SC1012 R8 rotorcraft airfoil \ sc1012r8.gif\ \ \
sc1094r8.dat \ Sikorsky/Velkoff SC1094 R8 rotorcraft airfoil \ sc1094r8.gif\ \ \
sc1095.dat \ Sikorsky/Balch SC1095 rotorcraft airfoil \ sc1095.gif\ \ \
sc1095r8.dat \ Sikorsky/Velkoff SC1095 R8 rotorcraft airfoil \ sc1095r8.gif\ \ \
sc20010.dat \ NASA SC(2)-0010 airfoil (NASA TP-2969)\ sc20010.gif\ \ \ ref/sc20010_ref.html
sc20012.dat \ NASA SC(2)-0012 airfoil (NASA TP-2969)\ sc20012.gif\ \ \ ref/sc20012_ref.html
sc20402.dat \ NASA SC(2)-0402 airfoil (NASA TP-2969)\ sc20402.gif\ \ \ ref/sc20402_ref.html
sc20403.dat \ NASA SC(2)-0403 airfoil (NASA TP-2969)\ sc20403.gif\ \ \ ref/sc20403_ref.html
sc20404.dat \ NASA SC(2)-0404 airfoil (NASA TP-2969)\ sc20404.gif\ \ \ ref/sc20404_ref.html
sc20406.dat \ NASA SC(2)-0406 airfoil (NASA TP-2969)\ sc20406.gif\ \ \ ref/sc20406_ref.html
sc20410.dat \ NASA SC(2)-0410 airfoil (NASA TP-2969)\ sc20410.gif\ \ \ ref/sc20410_ref.html
sc20412.dat \ NASA SC(2)-0412 airfoil (NASA TP-2969)\ sc20412.gif\ \ \ ref/sc20412_ref.html
sc20414.dat \ NASA SC(2)-0414 airfoil (NASA TP-2969)\ sc20414.gif\ \ \ ref/sc20414_ref.html
sc20503.dat \ NASA SC(2)-0503 airfoil (NASA TP-2969)\ sc20503.gif\ \ \ ref/sc20503_ref.html
sc20518.dat \ NASA SC(2)-0518 airfoil (NASA TP-2969)\ sc20503.gif\ \ \ ref/sc20518_ref.html
sc20606.dat \ NASA SC(2)-0606 airfoil (NASA TP-2969)\ sc20606.gif\ \ \ ref/sc20606_ref.html
sc20610.dat \ NASA SC(2)-0610 airfoil (NASA TP-2969)\ sc20610.gif\ \ \ ref/sc20610_ref.html
sc20612.dat \ NASA SC(2)-0612 airfoil (NASA TP-2969)\ sc20612.gif\ \ \ ref/sc20612_ref.html
sc20614.dat \ NASA SC(2)-0614 airfoil (NASA TP-2969)\ sc20614.gif\ \ \ ref/sc20614_ref.html
sc20706.dat \ NASA SC(2)-0706 airfoil (NASA TP-2969)\ sc20706.gif\ \ \ ref/sc20706_ref.html
sc20710.dat \ NASA SC(2)-0710 airfoil (NASA TP-2969)\ sc20710.gif\ \ \ ref/sc20710_ref.html
sc20712.dat \ NASA SC(2)-0712 airfoil (NASA TP-2969)\ sc20712.gif\ \ \ ref/sc20712_ref.html
sc20714.dat \ NASA SC(2)-0714 airfoil (NASA TP-2969)\ sc20714.gif\ \ \ ref/sc20714_ref.html
sc20714.dat \ NASA/Langley SC(2)-0714 supercritical airfoil \ sc20714.gif\ \ \
sc21006.dat \ NASA SC(2)-1006 airfoil \ sc21006.gif\ \ \ ref/sc21006_ref.html
sc21010.dat \ NASA SC(2)-1010 airfoil \ sc21010.gif\ \ \ ref/sc21010_ref.html
sc2110.dat \ Sikorsky/Lednicer & Owen SC2110 rotorcraft airfoil (SC5410) \ sc2110.gif\ \ \
sd2030.dat \ Selig/Donovan SD2030 low Reynolds number airfoil \ sd2030.gif\ \ \ Low Reynolds number data
sd2083.dat \ Selig/Donovan SD2083 low Reynolds number airfoil \ sd2083.gif\ \ \ Low Reynolds number data
sd5060.dat \ Selig/Donovan SD5060 low Reynolds number airfoil \ sd5060.gif\ \ \ Low Reynolds number data
sd6060.dat \ Selig/Donovan SD6060 low Reynolds number airfoil \ sd6060.gif\ \ \ Low Reynolds number data
sd6080.dat \ Selig/Donovan SD6080 low Reynolds number airfoil \ sd6080.gif\ \ \ Low Reynolds number data
sd7003.dat \ Selig/Donovan SD7003 low Reynolds number airfoil \ sd7003.gif\ \ \ Low Reynolds number data
sd7032.dat \ Selig/Donovan SD7032 low Reynolds number airfoil \ sd7032.gif\ \ \ Low Reynolds number data
sd7034.dat \ Selig/Donovan SD7034 low Reynolds number airfoil \ sd7034.gif\ \ \ Low Reynolds number data
sd7037.dat \ Selig/Donovan SD7037 low Reynolds number airfoil \ sd7037.gif\ \ \ Low Reynolds number data
sd7043.dat \ Selig/Donovan SD7043 low Reynolds number airfoil \ sd7043.gif\ \ \ Low Reynolds number data
sd7062.dat \ Selig/Donovan SD7062 low Reynolds number airfoil \ sd7062.gif\ \ \ Low Reynolds number data
sd7080.dat \ Selig/Donovan SD7080 low Reynolds number airfoil \ sd7080.gif\ \ \ Low Reynolds number data
sd7084.dat \ Selig/Donovan SD7084 low Reynolds number airfoil \ sd7084.gif\ \ \ Low Reynolds number data
sd7090.dat \ Selig/Donovan SD7090 low Reynolds number airfoil \ sd7090.gif\ \ \ Low Reynolds number data
sd8000.dat \ Selig/Donovan SD8000 low Reynolds number airfoil \ sd8000.gif\ \ \ Low Reynolds number data
sd8020.dat \ Selig/Donovan SD8020 low Reynolds number airfoil \ sd8020.gif\ \ \ Low Reynolds number data
sd8040.dat \ Selig/Donovan SD8040 low Reynolds number airfoil \ sd8040.gif\ \ \ Low Reynolds number data
sg6040.dat \ Selig / Giguere SG6040 wind turbine airfoil \ sg6040.gif\ \ \ Low Reynolds number data
sg6041.dat \ Selig / Giguere SG6041 wind turbine airfoil (high L/D) \ sg6041.gif\ \ \ Low Reynolds number data
sg6042.dat \ Selig / Giguere SG6042 wind turbine airfoil (high L/D) \ sg6042.gif\ \ \ Low Reynolds number data
sg6043.dat \ Selig / Giguere SG6043 wind turbine airfoil (high L/D) \ sg6043.gif\ \ \ Low Reynolds number data
sg6050.dat \ Selig / Giguere SG6050 wind turbine airfoil \ sg6050.gif\ \ \ ref/windlite_ref.html
sg6051.dat \ Selig / Giguere SG6051 wind turbine airfoil \ sg6051.gif\ \ \ ref/windlite_ref.html
sm701.dat \ Somers / Maughmer SM701 airfoil \ sm701.gif\ \ \ Ref [2]
sokolov.dat \ Sokolov R/C sailplane airfoil \ sokolov.gif\ \ \
spicasm.dat \ Anderson SPICA R/C sailplane airfoil (smoothed) \ spicasm.gif\ \ \ Low Reynolds number data
ssca07.dat \ Sikorsky/Flemming SSC-A07 transonic rotorcraft airfoil \ ssca07.gif\ \ \
ssca09.dat \ Sikorsky/Flemming SSC-A09 transonic rotorcraft airfoil \ ssca09.gif\ \ \
stcyr171.dat \ St. CYR 171 (Royer) airfoil \ stcyr171.gif\ \ \
stcyr172.dat \ St. CYR 172 (Royer) airfoil \ stcyr172.gif\ \ \
stcyr234.dat \ St. CYR 234 (Bartel 17-IC) airfoil \ stcyr234.gif\ \ \
stcyr24.dat \ St. CYR 24 (Bartel 35-IIIC) airfoil \ stcyr24.gif\ \ \
ste87151.dat \ Eppler STE 871-514 airfoil \ ste87151.gif\ \ \
ste87391.dat \ Eppler STE 87(-3)-914 airfoil \ ste87391.gif\ \ \
stf86361.dat \ Eppler STF 863-615 airfoil \ stf86361.gif\ \ \
strand.dat \ Strand high lift airfoil \ strand.gif\ \ \
s3068.dat \ Selig S3068 is a typo found in some advertising. No such airfoil exists. See S8036.\ \ \ \
s6086.dat \ Selig S6086 is a typo found in some advertising. The reference should be S8036 and S8037.\ \ \ \
s6087.dat \ Selig S6087 is a typo found in some advertising. The reference should be S8036 and S8037. \ \ \ \
tempest1.dat \ Hawker Tempest 37.5% semispan airfoil (NPL?) \ tempest1.gif\ \ \
tempest2.dat \ Hawker Tempest 61% semispan airfoil (NPL?) \ tempest2.gif\ \ \
tempest3.dat \ Hawker Tempest 96.77% semispan airfoil (NPL?) \ tempest3.gif\ \ \
th25816.dat \ Naval Air Development Center/Doug Hall high altitude, long endurance vehicle airfoil \ th25816.gif\ \ \
trainer60.dat \ Great Planes R/C Trainer 60 airfoil \ trainer60.gif\ \ \ Low Reynolds number data
tsagi12.dat \ TSAGI 12% airfoil \ tsagi12.gif\ \ \
tsagi8.dat \ TSAGI 8% airfoil \ tsagi8.gif\ \ \
ua2-180.dat \ UA(2)-180 airfoil for ultralight category aircraft \ ua2-180.gif\ \ \ ref/ua2-180_ref.html
ua2-180sm.dat \ UA(2)-180 (smoothed) airfoil for ultralight category aircraft \ ua2-180sm.gif\ \ \ ref/ua2-180_ref.html
ua79sf18.dat \ University of Alberta/Marsden UA 79-SF-187 FLAPPED sailplane airfoil \ ua79sf18.gif\ \ \
ua79sff.dat \ University of Alberta/Marsden UA 79-SF-187 sailplane airfoil FLAP \ ua79sff.gif\ \ \
ua79sfm.dat \ University of Alberta/Marsden UA 79-SF-187 sailplane airfoil MAIN ELEMENT \ ua79sfm.gif\ \ \
uag8814320.dat \ UAG 88-143/20 airfoil \ uag8814320.gif\ \ \ Ref [2]
ui1720.dat \ University of Illinois UI-1720 high lift airfoil \ ui1720.gif\ \ \
ultimate.dat \ Carl Goldberg R/C Ultimate Bipe airfoil \ ultimate.gif\ \ \ Low Reynolds number data
us1000root.dat \ Great Planes R/C Ultra-Sport 1000 airfoil \ us1000root.gif\ \ \ Low Reynolds number data
usa22.dat \ USA-22 airfoil \ usa22.gif\ \ \
usa25.dat \ USA-25 airfoil \ usa25.gif\ \ \
usa26.dat \ USA-26 airfoil \ usa26.gif\ \ \
usa27.dat \ USA-27 airfoil \ usa27.gif\ \ \
usa27m2.dat \ USA-27MOD airfoil \ usa27m2.gif\ \ \
usa28.dat \ USA-28 airfoil \ usa28.gif\ \ \
usa29.dat \ USA-29 airfoil \ usa29.gif\ \ \
usa31.dat \ USA-31 airfoil \ usa31.gif\ \ \
usa32.dat \ USA-32 airfoil \ usa32.gif\ \ \
usa33.dat \ USA-33 airfoil \ usa33.gif\ \ \
usa34.dat \ USA-34 airfoil \ usa34.gif\ \ \
usa35.dat \ USA-35 airfoil \ usa35.gif\ \ \
usa35a.dat \ USA-35A airfoil \ usa35a.gif\ \ \
usa35b.dat \ USA-35B airfoil \ usa35b.gif\ \ \
usa40.dat \ USA-40 airfoil \ usa40.gif\ \ \
usa40b.dat \ USA-40B airfoil \ usa40b.gif\ \ \
usa41.dat \ USA-41 airfoil \ usa41.gif\ \ \
usa45.dat \ USA-45 airfoil \ usa45.gif\ \ \
usa45m.dat \ USA-45M airfoil \ usa45m.gif\ \ \
usa46.dat \ USA-46 airfoil \ usa46.gif\ \ \
usa48.dat \ USA-48 airfoil \ usa48.gif\ \ \
usa49.dat \ USA-49 airfoil \ usa49.gif\ \ \
usa5.dat \ USA-5 airfoil \ usa5.gif\ \ \
usa50.dat \ USA-50 airfoil \ usa50.gif\ \ \
usa51.dat \ USA-51 airfoil \ usa51.gif\ \ \
usa98.dat \ USA-98 airfoil \ usa98.gif\ \ \
usnps4.dat \ Jacobs USNPS4 (smoothed) 17.5 kW wind turbine airfoil \ usnps4.gif\ \ \ Low Reynolds number data
v13006.dat \ Boeing-Vertol V13006-.7 rotorcraft airfoil \ v13006.gif\ \ \
v13009.dat \ Boeing-Vertol V(1.9)3006-1.25 rotorcraft airfoil \ v13009.gif\ \ \
v23010.dat \ Boeing-Vertol V23010-1.58 rotorcraft airfoil \ v23010.gif\ \ \
v43012.dat \ Boeing-Vertol V43012-1.58 rotorcraft airfoil \ v43012.gif\ \ \
v43015.dat \ Boeing-Vertol V43015-2.48 rotorcraft airfoil \ v43015.gif\ \ \
vr1.dat \ Boeing-Vertol VR-1 rotorcraft airfoil \ vr1.gif\ \ \
vr11x.dat \ Boeing-Vertol/NASA/Dadone VR-11X transonic rotorcraft airfoil \ vr11x.gif\ \ \
vr12.dat \ Boeing-Vertol/Dadone VR-12 rotorcraft airfoil \ vr12.gif\ \ \
vr13.dat \ Boeing-Vertol/Dadone VR-13 rotorcraft airfoil \ vr13.gif\ \ \
vr14.dat \ Boeing-Vertol/Dadone VR-14 rotorcraft airfoil \ vr14.gif\ \ \
vr15.dat \ Boeing-Vertol/Dadone VR-15 transonic rotorcraft airfoil \ vr15.gif\ \ \
vr5.dat \ Boeing-Vertol VR-5 rotorcraft airfoil \ vr5.gif\ \ \
vr7.dat \ Boeing-Vertol VR-7 rotorcraft airfoil \ vr7.gif\ \ \
vr7b.dat \ Boeing-Vertol VR-7 rotorcraft airfoil with tab \ vr7b.gif\ \ \
vr8.dat \ Boeing-Vertol VR-8 rotorcraft airfoil \ vr8.gif\ \ \
vr8b.dat \ Boeing-Vertol VR-8 rotorcraft airfoil with tab \ vr8b.gif\ \ \
vr9.dat \ Boeing-Vertol VR-9 rotorcraft airfoil \ vr9.gif\ \ \
waspsm.dat \ Mike Fox WASP low Reynolds number airfoil \ waspsm.gif\ \ \ Low Reynolds number data
wb13535sm.dat \ Woody Blanchard WB135/35 R/C sailplane airfoil \ wb13535sm.gif\ \ \ Low Reynolds number data
wb140.dat \ Woody Blanchard WB140/35/FB R/C sailplane airfoil \ wb140.gif\ \ \ Low Reynolds number data
whitcomb.dat \ NASA/Langley Whitcomb integral supercritical airfoil \ whitcomb.gif\ \ \
ys900.dat \ YS900 hyrdofoil (Shen / Eppler) \ ys900.gif\ \ \ ref/ys900_ref.html
ys915.dat \ YS915 hydrofoil (Shen / Eppler) \ ys915.gif\ \ \ ref/ys900_ref.html
ys930.dat \ YS930 hydrofoil (Shen / Eppler) \ ys930.gif\ \ \ ref/ys900_ref.html
发表于 2007-5-7 17:51:08 | 显示全部楼层
[分享]UIUC Airfoil Data Site(翼型数据库大全)
文字有没有RG15的翼型数据,有的话发到softboy8900@126.com,谢谢!
发表于 2007-5-7 17:51:46 | 显示全部楼层
font]有没有RG15的翼型数据,有的话发到softboy8900@126.com,谢谢!
 楼主| 发表于 2007-5-10 08:42:33 | 显示全部楼层
数据库中有,按照上面的链接就可以下载。
我没有下载,数据太多了
发表于 2007-5-30 08:45:32 | 显示全部楼层
奇怪,我为什么不能打开附件啊,说我威望只有-6,可我的威望是+1啊!谁能告诉我是怎么回事啊,难道长时间不来威望就自动减了吗?
发表于 2007-6-6 00:24:45 | 显示全部楼层
http://www.ae.uiuc.edu/m-selig/ads/coord_database.html
发表于 2007-6-16 15:08:30 | 显示全部楼层
谢谢分享,很实用,如果有实验数据就完美了!
发表于 2007-7-21 13:44:41 | 显示全部楼层
奇怪,我为什么不能打开附件啊,说我威望只有-6,可我的威望是0啊!谁能告诉我是怎么回事啊,难道长时间不来威望就自动减了吗?
发表于 2007-8-1 23:40:40 | 显示全部楼层
有没有实验数据啊
发表于 2007-8-7 08:19:45 | 显示全部楼层
有实验数据就太nx了。
发表于 2007-9-5 23:15:14 | 显示全部楼层
版主不愧是版主……牛!!!
发表于 2007-10-25 17:43:18 | 显示全部楼层
怎么下不了啊
发表于 2007-11-5 16:52:08 | 显示全部楼层
我的威望是负的?
发表于 2007-11-9 23:01:59 | 显示全部楼层
威望是-6,没资格下.但我急需翼型数据,哪位好心的大虾有下到了的啊,能不能麻烦发一份到我邮箱,跪求啊!
我的邮箱是yx291215@163.com
