查看: 8656|回复: 4
[求助]请问动网格和滑移网格有什么区别?
发表于 2007-3-5 13:38:22 | 显示全部楼层 |阅读模式
这是fluent的介绍,不过看不出有什么区别。
Dynamic & Moving Mesh
In FLUENT, the dynamic mesh capability meets the needs of challenging applications, including in-cylinder flows, valves and store separation. Several different mesh rebuilding schemes can be used for different moving parts within the same simulation as needed. Only the initial mesh and a description of the boundary movement are required. A built-in six-degrees-of-freedom solver is also available for applications with unconstrained motion, including store separation, missile launch, and tank sloshing. Dynamic meshing is compatible with a host of other models including FLUENT';s suite of spray breakup and combustion models and multiphase models including those for free surface prediction and compressible flow.
FLUENT also provides sliding mesh and multiple reference frame models that have a proven track record for mixing tanks, pumps, and turbomachinery.
发表于 2007-6-23 16:11:24 | 显示全部楼层
依我看,滑移网格是动网格中的一种情况
发表于 2007-6-23 22:30:07 | 显示全部楼层
他们目的一样:实现网格的运动
而操作方法不一样
发表于 2010-12-22 17:51:05 | 显示全部楼层
顶一下
发表于 2010-12-25 20:55:38 | 显示全部楼层
刚刚开始入门,学习一下
