查看: 23372|回复: 28
照着fluent动网格(阀门例子)出现的问题!!!
发表于 2005-8-25 22:11:24 | 显示全部楼层 |阅读模式
照着fluent动网格(阀门例子)出现的问题,例子上说迭代80时间步,我迭代22个时间步,说出现负体积,是什么回事?
有这样提示
reversed flow in 16 faces on pressure-outlet 15.
!  813 solution is converged
   813 9.9919e-04 1.8706e-04 1.7329e-04 4.6382e-04 8.9065e-04  0:00:03   62
Flow time = 8.8e-05, time step = 22
58 more time steps
Updating solution at time level N... done.
Updating mesh at time level N...not all cell got interpolated
UDF valve: time = 0.000092, x_vel = -23.416164, force = -399.759033, loc(m)= -0.002837
negative volume: repeat smoothing
WARNING: non-positive volumes exist.
Error: Update-Dynamic-Mesh failed. Negative cell volume detected.
Error Object: ()
Grid Check
Domain Extents:
   x-coordinate: min (m) = 0.000000e+00, max (m) = 1.513770e-02
   y-coordinate: min (m) = 0.000000e+00, max (m) = 6.858001e-03
Volume statistics:
   minimum volume (m3): -1.049265e-09
   maximum volume (m3): 1.530355e-09
     total volume (m3): 8.753680e-07
   minimum 2d volume (m3): -4.709124e-15
   maximum 2d volume (m3): 1.645804e-08
Face area statistics:
   minimum face area (m2): 1.575216e-09
   maximum face area (m2): 1.166621e-06
Checking number of nodes per cell.
Cell on zone 4 has a face 0 (zone 19) with nodes not referenced by the cell
Checking number of faces per cell.
Checking thread pointers.
Checking number of cells per face.
Error: face on thread 19 does not have two cells.
Checking face cells.
Error: face points to cell, but cell doesn';t point to face (thread 19)
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
Error Object: ()
Grid Check
Domain Extents:
Volume statistics:
Error:
Error Object: ()
Error:
Error Object: ()
Error:
Error Object: ()
Error:
Error Object: ()
Contour level 17, value in [2328.4233, 2527.0583].
Contour level 5, value in [-55.196941, 143.43806].
Contour level 6, value in [143.43806, 342.07309].
Contour level 7, value in [342.07309, 540.70807].
Zone ID = 10, name = poppet, type = wall
Error: Floating point error: divide by zero
Error Object: ()
Error Object: ()
Error: FLUENT received a fatal signal (SEGMENTATION VIOLATION).
Error Object: ()
Error: cx-set-list-items: wta[1](widget)
Error Object: #f
Error Object: #f
Error message from graphics function Compute_Selection:
';/driver/opengl/win+w1/inner/text'; is not a direct descendant of ';/driver/opengl/win+w0';
是怎么回事呀!哪位大哥帮帮忙亚!!!
发表于 2006-9-22 10:36:35 | 显示全部楼层
能把例子给发一下吗?
liuwenxia@163.com
非常感谢!!
发表于 2006-11-14 17:12:40 | 显示全部楼层
我也想试一下这个例子,如果出现了你的问题,我会认真阅读,想想解决的方法的
zzl_hust@163.com
发表于 2006-11-16 13:30:04 | 显示全部楼层
出现负体积,参数不合理,特别是时间步及最大最小单元SIZE的设定
发表于 2006-11-17 13:48:47 | 显示全部楼层
楼主能给我也发一下这个例子吗?
blb_ustb@sohu.com
发表于 2006-11-21 12:22:24 | 显示全部楼层
楼主帮忙发个阀门例子,先谢了!
denox@sina.com
发表于 2006-12-25 23:41:52 | 显示全部楼层
我也需要这个例子,楼主能否给我发一份,谢谢!邮箱jimee_lzj@163.com
发表于 2007-2-14 16:59:38 | 显示全部楼层
这个例子我做了,没有问题,照着fluent中的说明就可以了。
发表于 2007-6-30 10:51:07 | 显示全部楼层
给我传份吧
我的邮箱:wangfayong2001@163.com
兄弟先行谢过了
发表于 2007-7-6 22:11:12 | 显示全部楼层
那本书上的例子啊?
发表于 2007-9-28 11:43:00 | 显示全部楼层
下面引用由liyuhu1982在 2005/08/25 10:11pm 发表的内容:
有这样提示
[br][br][以下内容由 sdzym 在 2007年09月28日 11:47am 时添加] [br]
重新划分网格,首先解决网格的问题,不要出现负体积.你的回流问题,估计就是负体积造成的
发表于 2008-4-19 21:11:44 | 显示全部楼层
有这样提示
发表于 2009-11-5 07:57:47 | 显示全部楼层
能分享一下你的例子么,我也想做做,十分感谢
发表于 2010-1-23 14:18:57 | 显示全部楼层
回流应该没有大的影响吧?
发表于 2010-2-8 03:45:31 | 显示全部楼层
共享下吧,,楼主,,谢谢,,icc117@163.com
