查看: 3917|回复: 1
续发国外做高炉仿真方面的一些材料
发表于 2007-6-18 09:18:39 | 显示全部楼层 |阅读模式
这是Peter Richard AUSTIN.Hiroshi NOGAManId Jun-ichiro YAGl等人在97作过的高炉仿真的论文.
  A two dimensional mathematical model is developed describing four phase chemical reactions, motion,
and heat transfer in the blast furnace. The four phases are gas, Iump solid, Iiquid and powder. The model
simultaneously calculates the steady state composition, velocity, temperature, and volume fraction of all
four phases. The predicted gas, solid and liquid phase compositions are plausible, but the fines dynamic
holdup distribution is sensitive to the fines consumption processes in the raceway. The model has also been
  做这方面的朋友可以看看.
extended to include silicon transfer reactions. Comparedto the base calculations, the predicted cohesive
zone position is higher and the bosh is cooler whensilicon transfer is included, The model predicts SiO
generation from both coke ash silica and molten silica, the latter being the main contributor to hot metal
silicon content in the case considered.
 楼主| 发表于 2007-6-18 09:21:07 | 显示全部楼层
续发国外做高炉仿真方面的一些材料
这是题目:Analysis ot Actual Blast Furnace Operations and Evaluation
Static Liquid Holdup Etfects by the Four Fluid Model
