查看: 5194|回复: 2
Sky sailor broke record and flew for 27
发表于 2008-6-24 00:35:59 | 显示全部楼层 |阅读模式
http://sky-sailor.epfl.ch/
发表于 2008-6-24 14:43:50 | 显示全部楼层
Sky sailor broke record and flew for 27 hours without stop
登录/注册后可看大图
21th of June 2008 : NEW Continuous flight was demonstrated during a solar powered flight of more than 27 hours over 874.4 km what represents a Zurich-London trip. This is a world record for this size and using no thermal winds or altitude gain before the night.
The goal of this project is to design and build a solar powered micro airplane for autonomous exploration. This system, named Sky-Sailor, is fully autonomous in navigation and power generation. Equipped with solar cells covering its wing, it retrieves energy from the sun in order to supply power to the propulsion system and the control electronics, and charge the battery with the surplus of energy. During the night, the only energy available comes from the battery, which discharges slowly until the next morning when a new cycle starts.
This project started in 2004 under a contract with European Space Agency to study the feasibility of a Martian Solair Airplane. The first prototype weighs 2.6 kg for a wingspan of 3.2 meters. The 216 silicone solar cells are able to deliver up to 90 W at noon during summer whereas the power consumption of the airplane is 16 W at level flight. The longest flight so far lasted 5 hours, but measurements validated the design and prove that 24h is possible. This attempt will be done this summer 2007.
发表于 2009-9-3 16:39:06 | 显示全部楼层
2痘痘
根据痤疮的发病原理,治疗痤疮必须三管齐下,标本兼治。青春痘
在用护花呤抗角化改善肤质的同时,还必须用抑菌洗面奶并进行抗雄激素饮食(不吃煎炸、烧烤和辛辣食物,少吃肉类、饱和脂肪和动物油,多食豆类、纤维素等食物)。粉刺
虽然护花呤不是治疗痤疮的药物,但护花呤可以改善肤质。痘痘
用护花呤肤质健康细腻后痤疮就自然改善了。
  【青春痘的饮食注意事项】
  每天吃1公斤以上蔬菜(要吃茎杆)、水果治疗痤疮
(苹果、梨)等高纤维的食物;多食黄豆制品,如豆浆、豆腐……不吃煎炸、烧烤和辛辣食物,煮菜的油要少,要用橄榄油、花生油、菜杼油,不吃动物油和饱和脂肪高的油,不吃高糖食品(糖果、饼干、蛋糕、冰淇淋等……)不吃红肉(哺乳动物的肉),痤疮可以吃一些鱼、蛋(不吃蛋黄),每天100克左右。
  注意:青春痘是多原因造成的,治疗非常困难,一定要注意许多细节。多一个细节就多一分愈合的机会,这也是每一个有痘痘年轻男女的愿望。记住多一个细节就多一分愈合的效果。
