查看: 2880|回复: 0
udf培训材料上Scheme出错?
发表于 2005-7-4 22:45:47 | 显示全部楼层 |阅读模式
将udf培训材料上的Scheme出错加载时出现如下错误:
Error: eval: unbound variable
Error Object: my/int。
知道是变量的有问题,但是不知道那里出错,高人请指点。
附scheme文件内容:
;;FLUENT User Define Scheme program
;;Define User Scheme Variables
;;Flunet Inc.
(define(set-new-var s v t)
(if(not(rp-var-obect s))
      (rp-var-define s v t #f)
(for-each
(lambda(var)(apply set-new-var var))
    (my/int   1  integer)     ;user integer
    (my/real  0.5  real)      ;user real
    (my/text  "abc"  string)  ;user text
;;Create a panel for the udf
(define gui-my-input-panel
  (let((panel#f)
         ;declare variables-assign values later
     (mybox)
    (my-int-entry)
    (my-real-entry)
    (my-text-entry)
;;;;Function whichis called when pane is opened
;set panel variales to values in set-new-var section
  (define(update-cb.args)
    (cx-set-integer-entry my-int-entry (rpgetvar';my/int))
    (cx-set-real-entry    my-real-entry (rpgetvar';my/real))
    (cx-set-text-entry    my-text-entry (rpgetvar';my/text))
;;;Function which is called when OK button is hit.
;;;assigns variable values that were set in panel after clicking "ok"
  (define(apply-cb.args)
    (rpsetvar';my/int (cx-show-integer-entry my-int-entry))
    (rpsetvar';my/real (cx-show-real-entry my-real-entry))
    (rpsetvar';my/text (cx-show-text-entry my-text-entry))
   (lambda args
;;; if panel does not exit, make panel
       (if(not panel)
       ;;;create panel
         (let((table))
           (set!panel(cx-create-panel "MY Input Panel" apply-cb update-cb))
           ;;Create Custom Variable input.
           (set!table(cx-create-table panel ""';border#f';below 0';right-of 0 ))
;;;Create Custom Variable input.
       (set!mybox(cx-create-table table "My Inputs"';border#t';row 0))
       (set!my-int-entry (cx-create-integer-entry mybox "my integer"';row 0';col 0))
       (set!my-real-entry (cx-create-real-entry mybox "my real"';row 1';col 0))
       (set!my-text-entry (cx-create-text-entry mybox "my text"';row 2';col 0))
       ;;tell  solver to display the panel
       (cx-show-panel panel)
;;Add new panel to end of Oser-Defined menu.
;;no need to modify here except panel name and menu location
(cx-add-item
  "Define"
  "My Input Panel..."
   #\U
   #f
   cx-client?
  gui-my-input-panel
