查看: 1613|回复: 2
请教fluent如何用批处理的方式求解?
发表于 2005-7-5 13:10:41 | 显示全部楼层 |阅读模式
首先,我想请教,fluent的帮助文件里面给了一大堆命令,可是也没说明怎么用,参数格式是什么,这些命令该怎么用啊?
其次,比如我要调整courant数,每次调整都要等上一个库朗数计算完,很是麻烦,能不能像命令流那样,不用人工干预,自动在库朗数0.1的时候迭代1000步,0.5的时候迭代1000步,1的时候迭代1000步,谢谢!谢谢!
发表于 2005-7-5 14:15:26 | 显示全部楼层
用fluent6.2试试 Non-iterative time advancement (NITA) schemes
我用它做vof的例子收敛很快的。结果也不错,试试吧!!
Non-iterative time advancement (NITA) schemes reduce the splitting error to O(Dt2) by using sub-iterations (not the more expensive outer iterations to eliminate the splitting errors used in ITA) per time step
NITA runs about twice as fast as ITA scheme
Two flavors of NITA schemes available in Fluent v6.2:
PISO (NITA/PISO)
Energy and turbulence equations are still loosely coupled
Fractional-step method (NITA/FSM)
About 20% cheaper than NITA/PISO on a per time-step basis
NITA schemes have a wide range of applications for unsteady simulations: e.g., incompressible, compressible (subsonic, transonic), turbomachinery flows, etc.
NITA schemes are not available for multiphase (except VOF), reacting flows, porous media, and fan models, etc.  Consult Fluent User’s Guide for additional details.
 楼主| 发表于 2005-7-6 15:20:39 | 显示全部楼层
我这儿没有fluent62的帮助文件。另外,我算的喷管出口在3马赫以上,这个方法能用吗,谢谢!
