查看: 3707|回复: 0
【求助】付费求一MPI+C的作业代码
发表于 2009-5-15 23:28:58 | 显示全部楼层 |阅读模式
作业要求如下:
  1. The Red/Blue computation simulates two interactive flows: an n by n board is initialized so cells have one of three colors: red, white, and blue, where white is empty, red moves right, and blue moves down. (The board may be initialized with 1/3 cells in read, 1/3 in white and 1/3 in blue and colors should be interleaved and spread across the board.) Colors wraparound to the opposite side when reaching the edge. In the first half step of an iteration, any red color can move right one cell if the cell to the right is unoccupied (white); on the second half step, any blue color can move down one cell if the cell below it is unoccupied; the case where red vacates a cell (first half) and blue moves into is (second half) is okay. Viewing the board as overlaid with t by t tiles (t divides n), the computation terminates if any tile’s colored squares are more than c% one color. Use MPI to write a solution to the Red/Blue computation.
复制代码
会做的朋友请加我QQ:5997793.。价格好说,急用!高手们帮帮忙!
