查看: 3046|回复: 3
求教:NUMECA启动后在DOS窗口出现的错误信息是什么意思
发表于 2009-6-12 00:40:06 | 显示全部楼层 |阅读模式
安装完FINE72_1启动后在DOS窗口的信息如下:
Mar 31 2006
HDriver
  type               : WOGL
  version            : 2.24
  planes             : 24
  colors             : 16777216
  max colors         : 16777216
  z buffer depth     : 0
  hard cutting planes: 0
  hard lights        : 1
  hard gouraud       : yes
  hard phong         : no
  width              : -1 cm
  height             : -1 cm
  aspect ratio       : -1
  max width          : 32 cm
  max height         : 25.6 cm
  width  resolution  : 40 px/cm
  height resolution  : 40 px/cm
****                    FINE 7.2-1              ****
****                  NUMECA International              ****
****                    START Session                   ****
libpvm [pid3884] MyGetUserName returned Administrator
libpvm [pid3884] NI LookupAccountName success :Administrator 595B0B0CD4464B3
libpvm [pid3884] NI valid sid
libpvm [pid3884] NI AddAccessAllowedAce OK
libpvm [pid3884] NI SetSecurityDescriptorDacl OK
libpvm [pid3884] NI C:\tmp\pvmd.Administrator Creation OK: mode=3
libpvm [pid3884] Successfull open C:\tmp\pvmd.Administrator:
Initialize host 595B0B0CD4464B3
HOOPS information (8,224)
        Invalid subscreen specification - Subscreen 'left' is to the right of 'r
ight'
        -- Will use (-1, +1, -1, +1) --
ight'
HOOPS information (2,2)
        There was an unexpected Hoops internal error -
        You must name either a particular family member or
        a particular Aheight to Mark-System-Default
显然红色标记的部分是出错信息,由于本人对NUMECA懂的太少,不知道什么意思,高手能否指点一下?我特别想搞清楚这些细节。非常感谢!
发表于 2009-7-3 11:20:19 | 显示全部楼层
如果不出错,不用管它
 楼主| 发表于 2009-9-16 03:09:47 | 显示全部楼层
回复 2# monday 的帖子
谢谢,我也觉得是!
发表于 2009-10-6 17:59:15 | 显示全部楼层
没见过,不清楚!
