查看: 8357|回复: 3
CFX计算错误
发表于 2009-11-11 12:10:57 | 显示全部楼层 |阅读模式
我用ICEM画了一个简单的网格,但是CFX却无法计算,solver一开始没几秒就提示错误停止,那位大哥帮我看看,应该是网格错误,但是小弟实在是找不出哪里错误。
软件环境是Ansys12,ICEM和CFX都是Ansys12里面带的,网格文件比较大,附件是网格设定文件,只要从block中载入网格即可得到网格,然后输出为CFX网格,在CFX中设定域和边界条件即可开始计算,下面是计算的出错信息
| ERROR #001100279 has occurred in subroutine ErrAction.             |
| Floating point exception: Overflow                                 |
|                    Writing crash recovery file                     |
Details of error:-
Error detected by routine POPDIR
CRESLT = ILEG
Current Directory : /FLOW/NAMEMAP
|                An error has occurred in cfx5solve:                 |
| The ANSYS CFX solver exited with return code 1.   No results file  |
| has been created.                                                  |
End of solution stage.
|                              Warning!                              |
| The ANSYS CFX Solver has written a crash recovery file.  This file |
| has been saved as E:\Ansys\NACA0018\0\NACA0018_0_001.res.err and   |
| may be an aid to diagnosing the problem or restarting the run.     |
| More details should be available in the solver output section of   |
| the output file.                                                   |
| The following user files have been saved in the directory          |
| E:\Ansys\NACA0018\0\NACA0018_0_001:                                |
| mon        |
This run of the ANSYS CFX Solver has finished.
0018.zip
27.32 KB, 下载次数: 605
发表于 2009-12-11 14:20:44 | 显示全部楼层
把时间步长调小一点试试看。
发表于 2010-2-24 21:45:10 | 显示全部楼层
我也是同样的错误,即便是一个比较小的网格也会出错,我怀疑是软件bug,不过使用AWB却没有这种毛病,只是AWB里划分网格总出错,没办法啊!
今天采用了另外一个方案:ICEMCFD出网格导入CFDRC(Fastran)中计算!
发表于 2010-9-2 09:48:43 | 显示全部楼层
应该是网格问题,把质量调高些
