查看: 6371|回复: 2
cfx HP-MPI并行错误
发表于 2009-12-15 07:14:27 | 显示全部楼层 |阅读模式
ERROR: ld.so: object 'libmpi_cpu.so' from LD_PRELOAD cannot be preloaded: ignored
发表于 2009-12-15 23:27:14 | 显示全部楼层
同样是关于并行运算的一个问题!求教
我设置run mode为HP MPI Local Parallel点击Start Run 不久后,出现了
|                          Job Information                           |
Run mode:       parallel run (MPI)
Host computer:  DEEPINXP
Par. Process:   Master running on mesh partition:       1
Solver Build:   Tue Apr 14 23:55:42 GMTDT 2009
Attributes:     single-int32-32bit-novc8-noifort-novc6-optimised-su...
Job started:    Tue Dec 15 22:44:09 2009
Par. Process:   Slave  running on mesh partition:       2
Unable to check out 2 licenses: No license for ANSYS CFX Solver Parallel could
be found.
| ERROR #001100247 has occurred in subroutine  .                     |
| The solver is unable to continue because of licensing problems.    |
| A license for the following capability level could not be checked  |
| out:                                                               |
| PARALLEL PROCESSING                                                |
| Please carefully examine the error message output above and check  |
| that:                                                              |
| 1) The license server is specified correctly and is running.       |
| 2) An appropriate license is available for checking out.           |
| These problems can be checked using the ANSYS Client ANSLIC_ADMIN  |
| utility.  For further troubleshooting information please consult   |
| ANSYS, Inc. Licensing Guide.                                       |
|                An error has occurred in cfx5solve:                 |
| The ANSYS CFX solver exited with return code 1.   No results file  |
| has been created.                                                  |
End of solution stage.
This run of the ANSYS CFX Solver has finished.
其中licence到底应该怎样?希望高人赐教!
发表于 2017-2-18 15:51:52 | 显示全部楼层
我今天也碰到了这个问题,请问一下楼主解决了吗?怎么解决的,谢谢啦。
