查看: 5072|回复: 2
求教一个关于并行运算有关license的问题!
发表于 2009-12-15 23:28:47 | 显示全部楼层 |阅读模式
我设置run mode为HP MPI Local Parallel点击Start Run 不久后,出现了信息:
|                          Job Information                           |
Run mode:       parallel run (MPI)
Host computer:  DEEPINXP
Par. Process:   Master running on mesh partition:       1
Solver Build:   Tue Apr 14 23:55:42 GMTDT 2009
Attributes:     single-int32-32bit-novc8-noifort-novc6-optimised-su...
Job started:    Tue Dec 15 22:44:09 2009
Par. Process:   Slave  running on mesh partition:       2
Unable to check out 2 licenses: No license for ANSYS CFX Solver Parallel could
be found.
| ERROR #001100247 has occurred in subroutine  .                     |
| The solver is unable to continue because of licensing problems.    |
| A license for the following capability level could not be checked  |
| out:                                                               |
| PARALLEL PROCESSING                                                |
| Please carefully examine the error message output above and check  |
| that:                                                              |
| 1) The license server is specified correctly and is running.       |
| 2) An appropriate license is available for checking out.           |
| These problems can be checked using the ANSYS Client ANSLIC_ADMIN  |
| utility.  For further troubleshooting information please consult   |
| ANSYS, Inc. Licensing Guide.                                       |
|                An error has occurred in cfx5solve:                 |
| The ANSYS CFX solver exited with return code 1.   No results file  |
| has been created.                                                  |
End of solution stage.
This run of the ANSYS CFX Solver has finished.
其中licence到底应该怎样?希望高人赐教!注:本人是在一台带四个处理器的电脑上运算的!
不甚感谢!
[ 本帖最后由 lizhen276 于 2009-12-15 23:31 编辑 ]
发表于 2009-12-16 10:03:52 | 显示全部楼层
回复 1# lizhen276 的帖子
"Unable to check out 2 licenses: No license for ANSYS CFX Solver Parallel could
be found."
从这里看,可能没有并行版的licence吧。
 楼主| 发表于 2009-12-17 17:40:32 | 显示全部楼层
回复 2# nuer 的帖子
谢谢,我已经知道问题的所在了。原因是在装12.0版本前我装了10.0版本,两个版本有冲突。我把10.0版本的删了,重新安转12.0版本的就可以运行了!
