查看: 2829|回复: 5
请问求解大型稀疏矩阵一般都用什么方法,求解速度如何?
发表于 2004-8-24 11:33:59 | 显示全部楼层 |阅读模式
xiexie
发表于 2004-8-27 08:53:30 | 显示全部楼层
我现在用的是预处理双稳定共轭梯度算法,计算速度和稳定性都还可以!
发表于 2004-9-14 01:01:38 | 显示全部楼层
I use GMRES, and I developed an approximate inverse preconditiner based on Grote's work to speed up the convergency.
发表于 2004-9-16 23:54:57 | 显示全部楼层
采用LU分解,应该可行!
发表于 2004-9-18 03:56:46 | 显示全部楼层
综合来讲, Bio- Conjugated Gradient Method (BiCG) 是性能最好的,一般的比较的迭代揭发,Matlab 都有 , 网上也有原代码下载
发表于 2004-9-28 05:54:58 | 显示全部楼层
LU factorization, especially Frontal solver based on LU factorization, is perfect for not large scale sparse matrix. However, it is imappropriate for large scale problem due to the intensive memory requirement and cpu time.
For a non-symmetric matrix, I personally think GMRES method is the best.
