查看: 3466|回复: 2
[求助]Fortran高手看看:我在调试Fortran时出现如下情况咋办啊
发表于 2004-9-10 00:59:37 | 显示全部楼层 |阅读模式
forrtl: info (58): format syntax error at or near
forrtl: severe (62): syntax error in format, unit -4, file CONIN$
Image              PC        Routine            Line        Source
flow.exe           0040F609  Unknown               Unknown  Unknown
flow.exe           0040F421  Unknown               Unknown  Unknown
flow.exe           0040E5F4  Unknown               Unknown  Unknown
flow.exe           0040EA5D  Unknown               Unknown  Unknown
flow.exe           004078DA  Unknown               Unknown  Unknown
flow.exe           004010E8  Unknown               Unknown  Unknown
flow.exe           00438FE9  Unknown               Unknown  Unknown
flow.exe           0042C594  Unknown               Unknown  Unknown
kernel32.dll       77E614C7  Unknown               Unknown  Unknown
Incrementally linked image--PC correlation disabled.
Press any key to continue
发表于 2004-9-11 10:47:45 | 显示全部楼层
都给你提示了呀,format语法错误
发表于 2004-9-12 19:58:44 | 显示全部楼层
文件4的名称有问题:没有找到文件或者对文件操作的语法有问题
可以把元程序这一段的语句法上来
