查看: 1636|回复: 0
怎么看fluent出错信息
发表于 2006-3-13 22:19:07 | 显示全部楼层 |阅读模式
我觉得看得懂fluent本身的出错信息提示很重要,可是基本不太理解。
请版上大牛指点一下。斑竹要是能组织大家讨论就更好了。[br][br]-=-=-=-=- 以下内容由 saint13 在 时添加 -=-=-=-=-
chip-exec: heat_flux: argument 1: incorrect type (36): int expectedchip-exec: heat_flux: argument 2: incorrect type (5): pointer expectedchip-exec: heat_flux: argument 3: incorrect type (0): int expectedchip-exec: heat_flux: argument 4: incorrect type (0): pointer expectedchip-exec: heat_flux: argument 5: incorrect type (0): pointer expectedchip-exec: heat_flux: argument 6: incorrect type (0): pointer expected
Updating solution at time level N... done.
  iter continuity x-velocity y-velocity     energy          k    epsilon     time/iter
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
Error Object: ()
可以就拿这个例子来说说
