查看: 8612|回复: 0
计算结果出错,ERROR #001100279 has occurred in subroutine ErrAction
发表于 2010-5-15 10:15:09 | 显示全部楼层 |阅读模式
计算收敛后,保存结果时,出现以下的错误
|               CPU Requirements of Numerical Solution               |
Subsystem Name                  Discretization       Linear Solution
                                (secs.   %total)     (secs.   %total)
Momentum and Mass              2.54E+03  45.0 %     4.55E+02   8.1 %
Heat Transfer                  7.18E+02  12.7 %     2.26E+02   4.0 %
TurbKE and Diss.K              7.07E+02  12.5 %     5.06E+02   9.0 %
Subsystem Summary              3.97E+03  70.3 %     1.19E+03  21.0 %
Variable Updates               4.31E+02    7.6 %
File Reading                   9.06E-01    0.0 %
Miscellaneous                  5.98E+01    1.1 %
Total                          5.65E+03
| ERROR #001100279 has occurred in subroutine ErrAction.             |
| write_compressed_dataarray: (fwrite failed) syserr:: No space lef- |
| t on device                                                        |
| iocnt: write data failed                                           |
| WriteLong: write data failed: what=G/MFLOIP_FL1 where=ZN1/ES1      |
| write_index: warning: new index not at end of file, file may be b- |
| ad        |
|                    Writing crash recovery file                     |
| t on device                                                        |
| WriteLong: write data failed: what=G/ENTHTOT_FL1 where=ZN1/VX      |
|                An error has occurred in cfx5solve:                 |
| The ANSYS CFX solver exited with return code 1.                    |
End of solution stage.
| Error reported by IO module: create_indextable: stored index is    |
| wrong: missing start tag                                           |
| Error reported by IO module: iif_open: unable to read the stored   |
| index, attempting to rebuild it                                    |
| Error reported by IO module: recreate_indextable: warning: file    |
| was not closed correctly, data may be inconsistent                 |
| Error reported by IO module: write_index: warning: new index not   |
| at end of file, file may be bad                                    |
打开res文件,发现后处理文件中类似压力,温度,速度等等所有的参数都没有……
这是为什么啊,那位高人帮助以下啊
