查看: 1967|回复: 0
悬赏急求help_gambit2.2/tutfiles中的两个文件:drill_bit.stp和nacelle-9.stp
发表于 2006-5-6 23:38:13 | 显示全部楼层 |阅读模式
谁有help_gambit2.2/tutfiles中的两个文件:drill_bit.stp和nacelle-9.stp,我做gambit例子时发现缺这两个文件.提供这两个文件者留下邮件地址本人可与您分享一册
本人典藏的流体力学电子书,可选范围见书目。
名称        大小       日期   时间
lumley-A First Couse in Turbulence        目录  2006-1-10  21:31
(eBook - pdf) - CFD - Fundamentals_of_Computational_Fluid_Dynamics.pdf                                                3,727KB   2006-4-7  23:31
Analogy between the Electromagnetic and Hydrodynamic Equations - Application to Turbulence(1).pdf                       789KB   2006-4-8   0:27
Analogy between the Electromagnetic and Hydrodynamic Equations - Application to Turbulence.pdf                          789KB   2006-4-7  23:28
Anderson J.D. Modern compressible flow (2ed., MGH, 1990)(T)(671s).djvu                                                6,998KB   2006-4-8   0:26
Anderson J.D.Jr. Computational fluid dynamics. The basics with applications (MGH, 1995)(T)(563s).djvu                 6,740KB   2006-4-8   0:25
Arnold V., Khezin B. Topological Methods in Hydrodynamics (Springer, 1998)(T)(392s)(1).djvu                           3,369KB   2006-4-7  23:51
Arnold V., Khezin B. Topological Methods in Hydrodynamics (Springer, 1998)(T)(392s).djvu                              3,369KB   2006-4-7  23:26
Batchelor. Introduction to fluid dynamics (CUP, 2000)(T)(631s).djvu                                                   8,112KB   2006-4-7  23:36
Bloomer J J Practical Fluid Mechanics For Engineering Applications (M Dekker, 2000)(T)(408s).djvu                     4,834KB   2006-4-7  23:26
Bloomer.-.Practical.Fluid.Mechanics.For.Engineering.Applications.(2000).djvu                                          4,834KB   2006-4-7  23:51
Boon, Yip. Molecular hydrodynamics (Dover, 1991)(T)(430s)_PT_.djvu                                                    4,571KB   2006-4-7  23:27
Chorin A., Marsden J. A Mathematical Introduction to Fluid Mechanics (Springer, 1993)(T)(182s).djvu                   1,245KB   2006-4-7  23:49
Chorin A., Marsden J.E. Mathematical introduction to fluid mechanics (Springer, draft, 2000)(181s).pdf                1,382KB   2006-4-7  23:48
Chuang_fk_1950.pdf        5,983KB  2005-3-15  13:02
Computational methods for fluid dynamics.pdf        46,219KB  2004-4-10  23:07
Drazin P. Introduction to Hydrodynamic Stability (CUP, 2002)(276s).djvu                                               2,586KB   2006-4-7  23:36
Drazin P. Introduction to Hydrodynamic Stability (CUP, 2002)(T)(276s).djvu                                            2,634KB   2006-4-7  23:29
Egbers C., Pfister G. (eds.) Physics of rotating fluids (proc. Bremen 1999, Springer LNP549, 2000)(445s).pdf         13,155KB   2006-4-7  23:52
Fluid Mechanics - Frank M White-by stonecp.zip        26,476KB   2006-4-8   0:19
Fluid Mechanics.pdf        3,015KB   2006-4-7  23:28
Foundations of fluid mechanics - Gallavotti.djvu        3,727KB   2006-4-7  23:16
Fundamentals of CFD(Zingg).pdf        1,522KB  2003-1-19   9:05
Fundamentals Of Gas Dynamics (2Ed , Wiley, 2002).pdf        4,337KB   2006-4-7  23:39
Hydrodynamics and steel tube wastage in a fluidized bed at elevated temperature.pdf                                     559KB   2006-4-8   0:22
Hydrodynamics Of A Water Rocket.pdf        469KB   2006-4-7  23:28
Intermediate_Fluid Mechanics_Lecture Notes.pdf        1,744KB   2006-4-7  23:37
Introduction to Fluid Mechanics Solutions Manual (Fox, 5th ed).pdf                                                   71,379KB   2006-4-8   0:14
Lagrangian uid descriptionwith simple applications in.pdf                                                               754KB   2006-4-8   0:21
Lumley J.L. (ed.) Fluid mechanics and the environment.. dynamical approaches (LNP566, Springer, 2001)(T)(412s).djvu   7,094KB   2006-4-8   0:22
Marine Hydrodynamics.pdf        164KB   2006-4-7  23:27
McComb W.D. The physics of fluid turbulence (Oxford, 1991)(T)(595s).djvu                                              5,122KB   2006-4-8   0:20
mecanica de fluidos.pdf        252KB   2006-4-8
Mechanica de Fluidos - Irving H. Shames.pdf        37,567KB   2006-4-7  23:47
Mihalas D., Mihalas B.W. Foundations of radiation hydrodynamics (Oxford, 1984)(T)(741s).djvu                          7,440KB   2006-4-7  23:31
Milne-Thomson - Theoretical Aerodynamics.pdf        25,998KB   2006-4-8
Myshkis A.D., et al. Low-Gravity Fluid Mechanics (Springer, 1987)(601s).djvu                                          4,650KB   2006-4-7  23:45
Pozrikidis C. Fluid dynamics. Theory, computation and numerical simulation (Kluwer, 2001)(T)(557s).djvu               4,114KB   2006-4-7  23:45
Smoothed Particle Hydrodynamics Theory And Application To Nonspherical Stars.pdf                                      1,164KB   2006-4-7  23:29
The.Finite.Volume.Method.1.pdf        4,814KB   2004-4-5  20:43
The.Finite.Volume.Method.2.pdf        4,597KB   2004-4-5  20:43
Zienkiewicz-Taylor_The finite element method Fluid dynamics vol3.djvu                                                 4,559KB   2006-4-8   0:23
ZUCKER_Fundamentals of Gas Dynamics 2nd.pdf        4,339KB   2006-4-8   0:22
空化空蚀.pdf        5,954KB  2005-2-24  17:11
力学名著译丛 边界层理论上册.pdf        14,252KB  2002-4-26   2:06
力学名著译丛 力学中的相似方法与量纲理论.pdf        7,091KB  2001-9-18
力学名著译丛 流体动力学引论.pdf        12,879KB  2002-4-26   1:26
力学名著译丛 流体力学概论.pdf        19,220KB  2002-4-25  21:50
流体力学数值模拟.pdf        5,905KB  2002-4-25  21:36
