查看: 3741|回复: 2
招聘Aerodynamic CFD 高手
发表于 2010-7-28 15:34:46 | 显示全部楼层 |阅读模式
Computational Fluid Dynamics: CFD Application Specialist
Job Requirements:
•        Fundamental knowledge of contemporary CFD techniques and familiarity with the process of CFD analysis and its design applications.
•        Solid back ground in fluid dynamics with advanced knowledge in at least one of the following areas: aerodynamics, turbulence models, combustion, acoustics, or heat transfer.
•        Strong expertise in using commercial CFD tools including geometry modeling, grid generation and post-processing.
•        Provide timely, accurate and detailed reports and presentations
Preferred Candidates will possess the following:
•        Master or Ph.D in Aerodynamics, Mechanical Engineering, Physics or equivalent.
•        2-5 years experience in aerodynamic area.
•        Experience in CD-Adapco is favorable.
•        Ability to work effectively within multidisciplinary teams in both China and USA
•        Fluent English (both written and spoken) and excellent communication skills
FOR FURTHER INFORMATION OR TO SUBMIT CREDENTIALS PLEASE CONTACT
Cristina.wang@careerfocus.com.cn
发表于 2010-7-28 21:08:11 | 显示全部楼层
company name, location & package ?
发表于 2010-7-29 23:10:40 | 显示全部楼层
回复 1# cristina 的帖子
莫非还是UTRC的那个职位?
