查看: 3867|回复: 0
ICEM问题求助
发表于 2010-11-11 10:03:27 | 显示全部楼层 |阅读模式
划网格有以下提示,请高人指点主要是那方面的原因,多谢了
A minor internal error has occurred.
You may continue to work but if problems arise they may be related to this error.
Try using the check/fix function to fix the problem
The following message was designed to aid developers fix the problem:
degenerate edge encountered
zero denom in match edges
internal error in mesh_params
