查看: 3942|回复: 3
CFD工程师职位(猎头职位)
发表于 2010-11-16 17:28:30 | 显示全部楼层 |阅读模式
500强著名欧洲公司在苏州招聘极具竞争力的职位,欢迎大家跟我联系,积极推荐。
科锐猎头顾问:Charlie
TELE: 86-21-6164 5540; MOB: 139 1743 4980
Email:Charlie.ru@careerfocus.com.cn
Fluid Engineer (R&D)
Requirements:
Your education is M.Sc. Engineering with specialty in fluid mechanics and a good knowledge of CFD. You have insight in pumps as well as knowledge of measuring technique, fluid mechanics and construction. At Grundfos, you will be thoroughly introduced to the detailed pump theory.
If you are newly qualified and wish to pursue a career within fluid mechanics and product development, we will make sure that you get the relevant further education at Grundfos. The most important thing is that you have good technical insight and are enthusiastic about mechanics and good solutions construction wise. Experience within pump design and numerical simulation (Ansys CFX or similar) is an advantage.
Personally you are an engaged team player and keep up good relations to your partners naturally. In you work you have focus on the customer’s need and are driven by the wish to create results. You work independently and enterprisingly with a high energy level. You are able to draw up your own sub goals from an overall goal and have an analytical ability to see the simple in complex connections.
Responsibility:
The employees typically work in product development projects where they work cross organizational as pump specialists.
You will be working with:
- Pump design
- CFD calculations for analyses
- Construction of prototypes
- Comparison with tests
All construction work is done as 3D-modelling in Catia V5. In the group we work with parametric description of the geometry, and CAD is very closely linked to the other development tools. We use a lot of different tools from commercial CFD programmes to self-developed Matlab codes.
[ 本帖最后由 ruzhen517 于 2010-11-16 18:23 编辑 ]
发表于 2010-11-19 11:03:02 | 显示全部楼层
立个记号
发表于 2010-11-22 22:27:03 | 显示全部楼层
学了fluent ,专业不对口,人家不要啊
发表于 2011-1-12 09:10:30 | 显示全部楼层
不知道学习阀门的可以不?
