查看: 1940|回复: 1
Fluent是否可以只在cluster后台运行?
发表于 2011-2-9 23:47:27 | 显示全部楼层 |阅读模式
请问在cluster中运行时,是否可以像CFX那样,关闭本地程序而程序继续在cluster运行?
发表于 2011-2-10 07:26:41 | 显示全部楼层
fluent 2d -g < inputfile >& outputfile &
fluent is the command you type to execute FLUENT interactively.
-g indicates that the program is to be run without the GUI or graphics (see Section  1.1).
inputfile is a file of FLUENT commands that are identical to those that you would type interactively.
outputfile is a file that the background job will create and which will contain the output that FLUENT would normally print to the screen (e.g., the menu prompts and residual reports).
& tells the Linux/UNIX system to perform this task in background and to send all standard system errors (if any) to outputfile.
