查看: 1826|回复: 0
请教Roesolver黎曼间断分解问题
发表于 2005-1-13 22:11:39 | 显示全部楼层 |阅读模式
这个程序好像只能计算两边都是激波的情况!请问波浪号是什么意思?
      program roe
c...Find Roe';s approximate solution to the Riemann problem for the
c...Euler equations.
      real*8 gamma, p1, p2, p3, p4, u1, u2, u3, u4
      real*8 a1, a2, a3, a4, aa, bb, t, x
      real*8 rho1, rho2, rho3, rho4
      real*8 R, cu, cp, rr
      real*8 ent1, ent2, ent3, ent4
      real*8 mom1, mom2, mom3, mom4, re1, re2, re3, re4
      real*8 h1, h2, h3, h4, dvm, dvp, dv0
      real*8 lambda0, lambdam, lambdap
      parameter(gamma=1.4, R=287.0, N = 1000)
      parameter (cu = R/(gamma-1), cp = gamma*R/(gamma-1.))
      open ( unit=11, file=';input.dat'; )
      read( 11, *) aa, bb, t
      read( 11, *) p4, rho4, u4
      read( 11, *) p1, rho1, u1
      close(unit=11)
c... Compute state 1 (right state)
      mom1 = rho1*u1
      re1 = p1/(gamma-1.) + .5*mom1*u1
      h1 = (re1+p1)/rho1      ent1 = cu*log(p1)-cp*log(rho1)
      a1 = sqrt(gamma*p1/rho1)
c... Compute state 4 (left state)
      mom4 = rho4*u4
      re4 = p4/(gamma-1) + .5*mom4*u4
      h4 = (re4+p4)/rho4
      ent4 = cu*log(p4)-cp*log(rho4)
      a4 = sqrt(gamma*p4/rho4)
c...Compute Roe averages
      rr = sqrt(rho1/rho4)
      rhoavg = rr*rho4
      uavg = (rr*u1+u4)/(rr+1.)
      havg = (rr*h1+h4)/(rr+1.)
      aavg = sqrt((gamma-1.)*(havg-.5*uavg*uavg))
c...Compute wavespeeds
      lambda0 = uavg
      lambdap = uavg + aavg
      lambdam = uavg - aavg
c...Compute delta_v
      dv0 = rho1 - rho4 - (p1 - p4)/(aavg*aavg)
      dvp = u1 - u4 + (p1 - p4 )/(rhoavg*aavg)
      dvm = u1 - u4 - (p1 - p4 )/(rhoavg*aavg)
      ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~这几段什么意思?
c...Compute state 3
      rho3 = rho4 - .5*rhoavg*dvm/aavg
      mom3 = mom4 - .5*rhoavg*lambdam*dvm/aavg
      re3  = re4 - .5*rhoavg*(havg-aavg*uavg)*dvm/aavg
      ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~这几个公式是怎么来的?
      u3 = mom3/rho3
      p3 = (gamma-1.)*(re3-.5*mom3*u3)
      ent3 = cu*log(p3)-cp*log(rho3)
      a3 = sqrt(gamma*p3/rho3)
      h3 = (re3+p3)/rho3
c...Compute state2
      rho2 = rho1 - .5*rhoavg*dvp/aavg
      mom2 = mom1 - .5*rhoavg*lambdap*dvp/aavg
      re2  = re1 - .5*rhoavg*(havg+aavg*uavg)*dvp/aavg
      u2 = mom2/rho2
      p2 = (gamma-1.)*(re2-.5*mom3*u2)
      ent2 = cu*log(p2)-cp*log(rho2)
      a2 = sqrt(gamma*p2/rho2)
      h2 = (re2+p2)/rho2
      open ( unit=12, file=';waves.out'; )
      write(12,*) ';   To left of - wave:';
      write(12,*) ';pressure= ';,p4
      write(12,*) ';density= ';, rho4
      write(12,*) ';velocity= ';, u4
      write(12,*) '; ';
      write(12,*) ';   - WAVE';
      write(12,*) ';strength= ';, dvm
      write(12,*) ';speed= ';, lambdam
      write(12,*) ';location= ';, lambdam*t
      write(12,*) '; ';
      write(12,*) ';   Between - and 0 waves:';
      write(12,*) ';pressure= ';,p3
      write(12,*) ';density= ';, rho3
      write(12,*) ';velocity= ';, u3
      write(12,*) '; ';
      write(12,*) ';   0 WAVE';
      write(12,*) ';strength= ';, dv0
      write(12,*) ';speed= ';, lambda0
      write(12,*) ';location= ';, lambda0*t
      write(12,*) '; ';
      write(12,*) ';   Between 0 and + waves:';
      write(12,*) ';pressure= ';, p2
      write(12,*) ';density= ';, rho2
      write(12,*) ';velocity= ';, u2
      write(12,*) '; ';
      write(12,*) ';   + WAVE';
      write(12,*) ';strength= ';, dvp
      write(12,*) ';speed= ';, lambdap
      write(12,*) ';location= ';, lambdap*t
      write(12,*) '; ';
      write(12,*) ';   To right of + waves:';
      write(12,*) ';pressure= ';, p1
      write(12,*) ';density= ';, rho1
      write(12,*) ';velocity= ';, u1
      close(unit=12)
      open ( unit = 13, file = ';pressure.out';)
      open ( unit = 14, file = ';velocity.out';)
      open ( unit = 15, file = ';sound.speed';)
      open ( unit = 16, file = ';density.out';)
      open ( unit = 17, file = ';entropy.out';)
      open ( unit = 18, file = ';mach.out';)
      do 30, i=1,N+1
        x = aa + (bb-aa)*real(i-1)/real(N)
        if(x.lt.lambdam*t) then
            write(13,*) x, p4
            write(14,*) x, u4
            write(15,*) x, a4
            write(16,*) x, rho4
            write(17,*) x, ent4
            write(18,*) x, u4/a4
        elseif(x.ge.lambdam*t.and.x.lt.lambda0*t) then
            write(13,*) x, p3
            write(14,*) x, u3
            write(15,*) x, a3
            write(16,*) x, rho3
            write(17,*) x, ent3
            write(18,*) x, u3/a3
        elseif(x.ge.lambda0*t.and.x.lt.lambdap*t) then
            write(13,*) x, p2
            write(14,*) x, u2
            write(15,*) x, a2
            write(16,*) x, rho2
            write(17,*) x, ent2
            write(18,*) x, u2/a2
        else
            write(13,*) x, p1
            write(14,*) x, u1
            write(15,*) x, a1
            write(16,*) x, rho1
            write(17,*) x, ent1
            write(18,*) x, u1/a1
        endif
30   continue
      close(unit=13)
      close(unit=14)
      close(unit=15)
      close(unit=16)
      stop
      end
