查看: 2429|回复: 0
dpm,喷雾旋转模型,求助
发表于 2022-4-26 22:15:45 | 显示全部楼层 |阅读模式
在旋转喷雾的过程中算到3000多步时出现了这样的错误,我设置了俩个喷嘴,开始结束时间差1s,时间步长为1e-4,步数为2500,迭代20次,出现这样的错误有点不清楚意思,意思是我的时间步数错了吗,还是说颗粒太多了,网格出问题了,最后
1.5254% of the total discrete phase mass was not tracked for the expected residence time:
0.00685 s less on a mass-weighted average (which is 20.3688% of their total age or 13.6920% of the last time step).
You may be able to reduce this discrepancy by increasing the maximum number of time steps used to compute a single particle trajectory.
登录/注册后可看大图
