查看: 3219|回复: 7
Some Desing3D cases --- to Mr. ydavid
发表于 2003-4-14 18:42:12 | 显示全部楼层 |阅读模式
This is a power fan used in PC or other similar machines, which is optimized
successfully with FINE/Design3D.
发表于 2003-4-14 18:43:01 | 显示全部楼层
A Pump-Impeller optimized with FINE/Design3D.
发表于 2003-4-14 18:44:49 | 显示全部楼层
[这个贴子最后由redboy在 2004/03/01 01:53pm 第 1 次编辑]
A centrifugal compressor optimized by FINE/Design3D
发表于 2003-4-14 18:46:22 | 显示全部楼层
[这个贴子最后由redboy在 2004/03/01 01:54pm 第 1 次编辑]
A Francis turbine optimized with FINE/Design3D
发表于 2003-4-15 10:57:50 | 显示全部楼层
非常不错的东东
发表于 2003-4-17 16:57:31 | 显示全部楼层
How much computational resource is needed to perform the above mentioned optimization successfully and efficiently?
 楼主| 发表于 2003-4-17 17:46:50 | 显示全部楼层
This is related to the database sample number and the free parameters which
are used to be optimized.
Nomally, FINE/Design3D can perform 100 samples database and relize the final optimization process in 24 hours.
发表于 2004-2-20 09:02:08 | 显示全部楼层
非常不错哦!
