查看: 4008|回复: 1
紧急求助:CFX流固双向耦合出现错误
发表于 2011-4-26 16:16:38 | 显示全部楼层 |阅读模式
CFX做双向耦合时计算了40多步之后出现了下列错误提示:ERROR #002100012 has occurred in subroutine cVolSec.               |
| A negative ELEMENT volume has been detected.  This is a fatal      |
| error and execution will be terminated.  The location of the first |
| negative volume is reported below.                                 |
|     Volume   :  -0.2342E-11                                        |
|     Location : ( -0.37996E+00,  0.16409E+00,  0.15158E+00)         |
| ERROR #001100279 has occurred in subroutine ErrAction.             |
| CFX encountered the error:                                         |
|                                         0.  A folded mesh has oc-  |
| curred.  This process will shut down as soon as possible.
恳请大家帮助,谁遇到过类似的问题,怎么解决的
发表于 2015-3-13 09:25:25 | 显示全部楼层
朋友 你这个问题应该早都已经解决了吧,这应该是网格重叠了。
