查看: 2359|回复: 0
icepak问题
发表于 2007-3-22 23:19:12 | 显示全部楼层 |阅读模式
模型求解过程没启动,下面是左下方的窗口里的提示:
Warning: the solver hasn';t started running after 10 minutes: perhaps something is wrong?
Seems like there was a problem with versi-100.
下面是单独窗口的提示:
> (benchmark ';(icepak-iterate 1000 "versi-100"  100))  iter continuity x-velocity y-velocity z-velocity     energy     time/iter
Couldn';t allocate memory for pp, size 15065520, tid 326, file storage.c, line 6480, myid 1000000.
Couldn';t allocate memory for X Velocity Ap, size 15065520, tid 326, file storage.c, line 6480, myid 1000000.
Couldn';t allocate memory for X Velocity Source, size 15065520, tid 326, file storage.c, line 6480, myid 1000000.
Couldn';t allocate memory for X Velocity Reconstruction, size 45196560, tid 326, file storage.c, line 6480, myid 1000000.
Couldn';t allocate memory for Y Velocity Ap, size 15065520, tid 326, file storage.c, line 6480, myid 1000000.
Couldn';t allocate memory for Y Velocity Source, size 15065520, tid 326, file storage.c, line 6480, myid 1000000.
Couldn';t allocate memory for Y Velocity Reconstruction, size 45196560, tid 326, file storage.c, line 6480, myid 1000000.
Couldn';t allocate memory for Z Velocity Ap, size 15065520, tid 326, file storage.c, line 6480, myid 1000000.
Couldn';t allocate memory for Z Velocity Source, size 15065520, tid 326, file storage.c, line 6480, myid 1000000.
Couldn';t allocate memory for Z Velocity Reconstruction, size 45196560, tid 326, file storage.c, line 6480, myid 1000000.
Couldn';t allocate memory for %s Velocity Prev Itn, size 45196560, tid 326, file storage.c, line 6480, myid 1000000.
Couldn';t allocate memory for velocity-sa 0, size 45196560, tid 326, file storage.c, line 6480, myid 1000000.
Couldn';t allocate memory for pp, size 42820304, tid 325, file storage.c, line 6480, myid 1000000.
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
Error Object: ()
Warning: An error or interrupt occurred while reading the journal file.
Some commands may not have been completed.
Interrupting...
Done.
用的4.0.12,内存1G,250万网格,最小face alignment 0.19
为啥呀?
