查看: 3032|回复: 0
UDS的边界条件设置为题
发表于 2012-2-14 11:54:04 | 显示全部楼层 |阅读模式
请教各位大侠,FLUENT中提供的UDS出口边界条件有两类,specified value和specified flux。一般来讲进口处的value或者flux是已经知道的,但出口处一般不能提前知道,这时给怎样设置边界条件?
另外看help里面的解释,其flux的定义为负的扩散项,并不包括对流项,而且是不包括面积的,这该如何解释呢?(具体见下面链接)
https://www.sharcnet.ca/Software/Fluent13/help/flu_ug/flu_ug_sec_ug_uds_setup.html(该链接中说flux是方程1-9中括号项乘以边界法向矢量。:If you select Specified Flux, your input will be the value of the flux at the boundary (i.e., the negative of the term in parenthesis on the left hand side of Equation 1–9 in the Theory Guide) dot [as in the dot product of]   [as in the vector, n], where   is the normal into the domain). )
https://www.sharcnet.ca/Software/Fluent13/help/flu_th/flu_th_sec_uds_sp_theory.html#flu_th_eq_uds_1a
(该链接为式1-9的链接)
