查看: 2867|回复: 3
DEFINE_DPM_BODY_FORCE ( name, p, i) 中i是什么意思?
发表于 2012-10-15 14:20:41 | 显示全部楼层 |阅读模式
/* UDF for computing the ic force on a charged particle */
#include "udf.h"
#define Q 1.0         /* particle electric charge      */
#define BZ 3.0        /* z component of ic field */
#define TSTART 18.0   /* field applied at t = tstart   */
/* Calculate ic force on charged particle.  ic   */
/* force is particle charge times cross product of particle  */
/* velocity with ic field: Fx= q*bz*Vy,  Fy= -q*bz*Vx  */
DEFINE_DPM_BODY_FORCE(particle_body_force,p,i)
        real bforce;
        if(P_TIME(p)>=TSTART)
           if(i==0) bforce=Q*BZ*P_VEL(p)[1];
           else if(i==1) bforce=-Q*BZ*P_VEL(p)[0];
        else
           bforce=0.0;
        /* an acceleration should be returned */
        return (bforce/P_MASS(p));
麻烦各位大侠看看。这是从fluent中的help文件中的, if(i==0) 这个命令是什么意思?i指的是什么?
发表于 2012-10-15 15:09:15 | 显示全部楼层
帮助中说的明明白白,An index (0, 1, or 2) that identifies the Cartesian component of the body force that is to be returned by the function.
原帖由 passflame 于 2012-10-15 06:20 发表
#include "udf.h"
#defin ...
 楼主| 发表于 2012-10-15 15:40:59 | 显示全部楼层
回复 2# gearboy78 的帖子
An index (0, 1, or 2) that identifies the Cartesian component of the body force that is to be returned by the function这句话是什么意思?麻烦楼主再帮忙看看!谢谢了!
发表于 2012-10-15 20:58:34 | 显示全部楼层
回复 3# passflame 的帖子
i=0,1,2指的是x,y,z三个不同的方向
