查看: 4575|回复: 6
[求助]终止后再重新计算时出错
发表于 2007-7-4 12:27:44 | 显示全部楼层 |阅读模式
我在计算的时候,计算过程很稳定。但是当我cancle后,用display查看一些变量的参数时后,再接着iterate的时候,就出现error了
发表于 2007-7-4 19:18:49 | 显示全部楼层
[求助]终止后再重新计算时出错
经常出现的问题,是不是出现好多条错误?
那就关掉fluent,重新开一下就好了,我怀疑是不是盗版软件的问题
 楼主| 发表于 2007-7-5 00:43:07 | 显示全部楼层
[求助]终止后再重新计算时出错
不知道什么原因,以前这样操作就可以继续计算,可是最近就不行了
发表于 2007-7-5 10:11:07 | 显示全部楼层
[求助]终止后再重新计算时出错
是不是CASE比较大?显示窗口随便关之后计算会报一些错误的
当然,最好把错误贴来大家都看看
 楼主| 发表于 2007-7-5 19:02:49 | 显示全部楼层
[求助]终止后再重新计算时出错
是的,case有点大,100多M,
在启动Fluent的时候,就没有出现选择2d还是3d的对话框,直接出现了下面的文字:
Loading "C:\Fluent.Inc\fluent6.3.26\lib\fl114.dmp"
Done.
Warning: -path flag not specified.
Defaulting to -pathC:\Fluent.Inc
     Welcome to Fluent 6.3.26
     Copyright 2006 Fluent Inc.
     All Rights Reserved
Loading "C:\Fluent.Inc\fluent6.3.26\lib\flprim1119.dmp"
Done.
Host spawning Node 0 on machine "46E7D250F4F549E" (ntx86).
You can click CTRL+C to stop the startup process!
ID     Comm.   Hostname        O.S.        PID     Mach ID HW ID   Name
host   net     46E7D250F4F549E Windows-32  3508    0       1508    Fluent Host
n1     mpich2  46E7D250F4F549E Windows-32  3572    0       1       Fluent Node
n0*    mpich2  46E7D250F4F549E Windows-32  3588    0       0       Fluent Node
结果也能读入case后出现如下文字:
> Reading "D:\lvfen\air-al both\xufei-2doupen-6750.cas"...
   15019 quadrilateral cells, zone  2, binary.
    2247 quadrilateral cells, zone  3, binary.
      68 mixed wall faces, zone 16, binary.
      32 mixed interior faces, zone 15, binary.
    4410 2D interior faces, zone 12, binary.
     120 2D wall faces, zone  1, binary.
      50 2D wall faces, zone  4, binary.
      76 2D interface faces, zone  5, binary.
      18 2D interface faces, zone  6, binary.
      64 2D wall faces, zone  7, binary.
      76 2D velocity-inlet faces, zone  8, binary.
      50 2D wall faces, zone  9, binary.
     196 2D wall faces, zone 10, binary.
      10 2D wall faces, zone 11, binary.
   29792 2D interior faces, zone 13, binary.
      68 interface face parents, binary.
      32 interface face parents, binary.
      68 interface metric data, zone 16, binary.
      32 interface metric data, zone 15, binary.
   17598 nodes, binary.
   17598 node flags, binary.
Parallel variables...
Building...
     grid,
auto partitioning mesh by Principal Axes,
distributing mesh
parts..,
faces..,
nodes..,
     materials,
     interface,
     domains,
mixture
     zones,
default-interior:012
wall-nouse:001
default-interior
wall-nouse
wall-duiiman
fuleinlet
wall-kong
kong
arc
wall-16
wall-17
pressureout1
pressureout2
fluid1
fluid2
interior-15
     grid interfaces,
     parallel,
     shell conduction zones,
Done.
Reading "D:\lvfen\air-al both\xufei-2doupen-6750.dat"...
cells..,
read 66991 particles.
locating particles on compute nodes...
all particles successfully re-located!
Done.
重新迭代后出现的错误是:
Updating solution at time level N... done.
DPM Iteration ....
Injecting 7 particles at t = 0.0675
Injecting 3 particles at t = 0.0675
number tracked = 67001, escaped = 0, aborted = 0, trapped = 0, evaporated = 5, incomplete = 0
Parallel particle tracking concurrency: 75%
  iter continuity x-velocity y-velocity     energy          k    epsilon        h2o         o2      al2o3     time/iter
!65058 solution is converged
65058 8.0767e-04 1.2946e-05 1.8632e-05 1.0379e-09 9.7912e-06 7.8086e-05 0.0000e+00 3.4336e-11 2.8693e-07  0:00:00  200
Error: Floating point error: invalid number
Error Object: #f
不知道这是什么原因?再次感谢!
发表于 2007-7-6 21:33:46 | 显示全部楼层
[求助]终止后再重新计算时出错
这是由于并行计算引起的,在FLUENT图标属性里已指定3D,以及使用的处理器个数,所以在起动时不用再选择3D或2D了.如果计算量不是很大,建议不要用双核并行计算,因为两个处理器间的数据交换要占用一部分时间,在计算量不大时,单核与双核几乎没有区别,但对于计算量较大的模型,还是有一定的优势的.[br][br][以下内容由 youzhizhe 在 2007年07月06日 09:35pm 时添加] [br]
并行计算中途报错是很正常的,我也经常遇到.莫名其妙的错误
 楼主| 发表于 2007-7-7 23:23:16 | 显示全部楼层
[求助]终止后再重新计算时出错
谢谢解答。
那出现这样的错误后,就不能接着算了?得重新开始了
那样好郁闷
