查看: 2687|回复: 0
请大家来帮我解释一下FLUENT日志文件的语法
发表于 2007-9-15 00:15:56 | 显示全部楼层 |阅读模式
[这个贴子最后由wingnuaa在 2007/09/15 00:24am 第 1 次编辑]
以下是我今晚用FLUENT计算的一个小算例记录的日志文件。
请大家帮我解释下这些语句什么意思,谢谢!
(cx-gui-do cx-activate-item "MenuBar*ReadSubMenu*Case...")
(cx-gui-do cx-set-text-entry "Select File*FilterText" "e:\work\\*")
(cx-gui-do cx-activate-item "Select File*Apply")
(cx-gui-do cx-set-text-entry "Select File*Text" "du98-w-210.msh")
(cx-gui-do cx-activate-item "Select File*OK")
(cx-gui-do cx-activate-item "MenuBar*GridMenu*Scale...")
(cx-gui-do cx-set-real-entry-list "Scale Grid*Frame1(Scale Factors)*RealEntry1(X)" ';( 2.04))
(cx-gui-do cx-set-real-entry-list "Scale Grid*Frame1(Scale Factors)*RealEntry2(Y)" ';( 2.04))
(cx-gui-do cx-activate-item "Scale Grid*PanelButtons*PushButton1(OK)")
(cx-gui-do cx-activate-item "Scale Grid*PanelButtons*PushButton2(Cancel)")
(cx-gui-do cx-activate-item "MenuBar*ModelsSubMenu*Viscous...")
(cx-gui-do cx-set-toggle-button "Viscous Model*Table1*Frame1(Model)*ToggleBox1(Model)*Inviscid" #f)
(cx-gui-do cx-activate-item "Viscous Model*Table1*Frame1(Model)*ToggleBox1(Model)*Inviscid")
(cx-gui-do cx-activate-item "Viscous Model*PanelButtons*PushButton1(OK)")
(cx-gui-do cx-activate-item "MenuBar*DefineMenu*Boundary Conditions...")
(cx-gui-do cx-set-list-selections "Boundary Conditions*Table1*Frame1*List1(Zone)" ';( 3))
(cx-gui-do cx-activate-item "Boundary Conditions*Table1*Frame1*List1(Zone)")
(cx-gui-do cx-activate-item "Boundary Conditions*PanelButtons*PushButton1(OK)")
(cx-gui-do cx-set-list-selections "velocity-inlet-7-1*Frame4*Frame3(Momentum)*Table1*DropDownList2(Velocity Specification Method)" ';( 1))
(cx-gui-do cx-activate-item "velocity-inlet-7-1*Frame4*Frame3(Momentum)*Table1*DropDownList2(Velocity Specification Method)")
(cx-gui-do cx-set-real-entry-list "velocity-inlet-7-1*Frame4*Frame3(Momentum)*Table1*Table6*RealEntry2(X-Velocity)" ';( 2))
(cx-gui-do cx-activate-item "velocity-inlet-7-1*PanelButtons*PushButton1(OK)")
(cx-gui-do cx-set-list-selections "Boundary Conditions*Table1*Frame1*List1(Zone)" ';( 4))
(cx-gui-do cx-set-list-selections "velocity-inlet-6-1*Frame4*Frame3(Momentum)*Table1*DropDownList2(Velocity Specification Method)" ';( 1))
(cx-gui-do cx-activate-item "velocity-inlet-6-1*Frame4*Frame3(Momentum)*Table1*DropDownList2(Velocity Specification Method)")
(cx-gui-do cx-set-real-entry-list "velocity-inlet-6-1*Frame4*Frame3(Momentum)*Table1*Table6*RealEntry2(X-Velocity)" ';( 2))
(cx-gui-do cx-activate-item "velocity-inlet-6-1*PanelButtons*PushButton1(OK)")
(cx-gui-do cx-activate-item "Boundary Conditions*PanelButtons*PushButton2(Cancel)")
(cx-gui-do cx-activate-item "MenuBar*ReportMenu*Reference Values...")
(cx-gui-do cx-set-list-selections "Reference Values*DropDownList1(Compute From)" ';( 4))
(cx-gui-do cx-activate-item "Reference Values*DropDownList1(Compute From)")
(cx-gui-do cx-set-list-selections "Reference Values*DropDownList1(Compute From)" ';( 5))
(cx-gui-do cx-set-list-selections "Reference Values*DropDownList3(Reference Zone)" ';( 1))
(cx-gui-do cx-activate-item "Reference Values*DropDownList3(Reference Zone)")
(cx-gui-do cx-activate-item "Reference Values*PanelButtons*PushButton1(OK)")
(cx-gui-do cx-activate-item "MenuBar*InitializeSubMenu*Initialize...")
(cx-gui-do cx-set-list-selections "Solution Initialization*DropDownList1(Compute From)" ';( 2))
(cx-gui-do cx-activate-item "Solution Initialization*DropDownList1(Compute From)")
(cx-gui-do cx-activate-item "Solution Initialization*PanelButtons*PushButton1(OK)")
(cx-gui-do cx-activate-item "Solution Initialization*PanelButtons*PushButton1(Apply)")
(cx-gui-do cx-activate-item "Solution Initialization*PanelButtons*PushButton2(Cancel)")
(cx-gui-do cx-activate-item "MenuBar*SolveMenu*Iterate...")
(cx-gui-do cx-set-integer-entry "Iterate*Table1*Frame2(Iteration)*Table2(Iteration)*IntegerEntry1(Number of Iterations)" 100)
(cx-gui-do cx-activate-item "Iterate*PanelButtons*PushButton1(OK)")
(cx-gui-do cx-activate-item "Working*Cancel")
(cx-gui-do cx-activate-item "MenuBar*WriteSubMenu*Case & Data...")
(cx-gui-do cx-set-text-entry "Select File*FilterText" "c:\documents and settings\wangchang\桌面\\*")
(cx-gui-do cx-set-text-entry "Select File*Text" "du98-w-210.cas")
(cx-gui-do cx-activate-item "Warning*Cancel")
(cx-gui-do cx-set-text-entry "Select File*FilterText" "d:\\*")
(cx-gui-do cx-activate-item "Warning*OK")
我的目的是通过修改FLUENT日志文件实现批处理。请有经验朋友帮帮忙,非常感谢!
