查看: 1670|回复: 9
为什么我的fluent6.1.22并行比不并行慢?
发表于 2003-11-8 16:56:30 | 显示全部楼层 |阅读模式
我在启动的时候输入fluent 3d -t4(我有4的cpu的电脑windows版本的)。
除了这样启动之外,还要干什么事情阿?我看了帮助,好像有多cpu的电脑并行比较简单,帮助里只有一小段介绍。
还有我的所谓并行之后,cpu使用率还没有单搞用的多!
求诸位赐教!
 楼主| 发表于 2003-11-8 17:30:17 | 显示全部楼层
Loading "E:\Fluent.Inc\fluent6.1.22\lib\fl114.dmp"
Done.
     Welcome to Fluent 6.1.22
     Copyright 2003 Fluent Inc.
     All Rights Reserved
Loading "E:\Fluent.Inc\fluent6.1.22\lib\flprim117.dmp"
Done.
Host spawning Node 0 on machine "njuct" (ntx86).
ID     Comm.   Hostname        O.S.        PID     Mach ID HW ID   Name
host   net     njuct           Windows-32  568     0       1820    Fluent Host
n3     smpi    njuct           Windows-32  1140    0       3       Fluent Node
n2     smpi    njuct           Windows-32  600     0       2       Fluent Node
n1     smpi    njuct           Windows-32  3600    0       1       Fluent Node
n0*    smpi    njuct           Windows-32  5544    0       0       Fluent Node
> Reading "F:\WK\chamber.cas"...
    7350 hexahedral cells, zone  2, binary.
     825 quadrilateral wall faces, zone  3, binary.
     495 quadrilateral symmetry faces, zone  4, binary.
     544 quadrilateral symmetry faces, zone  5, binary.
     313 quadrilateral pressure-outlet faces, zone  6, binary.
      68 quadrilateral velocity-inlet faces, zone  7, binary.
      53 quadrilateral velocity-inlet faces, zone  8, binary.
   20901 quadrilateral interior faces, zone 10, binary.
    8564 nodes, binary.
    8564 node flags, binary.
Parallel variables...
Building...
     grid,
auto partitioning mesh by Principal Axes,
distributing mesh
parts....,
faces....,
nodes....,
     materials,
     interface,
     domains,
mixture
     zones,
default-interior
inlet1
inlet2
outlet
symmetryx
symmetryy
wall
fluid
     parallel,
     shell conduction zones,
Done.
cells....,
>> 4 Active Partitions:
       P   Cells I-Cells Cell Ratio   Faces I-Faces Face Ratio Neighbors
       0    1837     226      0.123    6084     411      0.068         2
       1    1837     496      0.270    6144     816      0.133         3
       2    1838     321      0.175    6074     593      0.098         3
       3    1838     267      0.145    6049     484      0.080         2
   Collective Partition Statistics:        Minimum   Maximum   Total
   Cell count                              1837      1838      7350
   Mean cell count deviation               -0.0%     0.0%
   Partition boundary cell count           226       496       1310
   Partition boundary cell count ratio     12.3%     27.0%     17.8%
   Face count                              6049      6144      23199
   Mean face count deviation               -0.6%     0.9%
   Partition boundary face count           411       816       1152
   Partition boundary face count ratio     6.8%      13.3%     5.0%
   Partition neighbor count                2         3
   Partition Method                        Principal Axes
   Stored Partition Count                  4
Done.
Interrupting...
Done.
 楼主| 发表于 2003-11-8 17:36:35 | 显示全部楼层
我的cpu使用率1
 楼主| 发表于 2003-11-8 17:37:06 | 显示全部楼层
我的cpu使用率2
发表于 2003-11-8 19:05:32 | 显示全部楼层
可能并行时,CPU相互间的通信,或更多可能是内存间的通信耗的时间多些
你并行后计算时间显著减少了吗?
发表于 2003-11-8 22:44:14 | 显示全部楼层
你的CAS显然没有大到需要用并行的地步,数据交换占用的时间比计算处理用时还多,这显然是不经济的。换个足够大的CAS一试你就知道了。
好羡慕你硬件的水平!
发表于 2003-11-9 12:39:12 | 显示全部楼层
多少网格?
 楼主| 发表于 2003-11-9 15:19:51 | 显示全部楼层
谢谢了,和分子动力学计算不一样.那玩意只要并行就快.
发表于 2003-11-9 18:35:14 | 显示全部楼层
问一下,你的分子动力学程序是基于什么模型的,是自己编的程序吗,能不能介绍一下?
 楼主| 发表于 2003-11-10 10:11:16 | 显示全部楼层
可以自己编,大多数时候都用商业程序。基于经典力场模型。
