查看: 1153|回复: 6
[讨论]我已经试了9999999999遍了,还是不行,恳求哪位大侠拉我一把
发表于 2004-8-25 13:32:39 | 显示全部楼层 |阅读模式
我已经试了9999999999遍了,还是不行,恳求哪位大侠拉我一把,
我装的gambit不能用,出错信息如图
发表于 2004-8-25 13:52:04 | 显示全部楼层
再多试一次嘛,呵呵
把*.lok文件删掉试试看。
发表于 2004-8-25 14:37:00 | 显示全部楼层
這應該是EXCEED沒灌好,遇到很多次,重灌就好了
发表于 2004-8-27 09:04:33 | 显示全部楼层
我的出错信息与你差不多,但是我的可以打开EXCEED
发表于 2004-8-27 11:53:57 | 显示全部楼层
This problem can be solved by two options:
(1) For D version Windows users, locate your lecense into "C:\fluent.inc\license" which is default path for software to search for license.
(2) For FLUENT customers, if you know SERVER line at the top of licese, you can install LMTOOLS (license software), so you don't worry about the location of license, in other words you are able to locate it at any place you want but make sure to select the correct path for LMTOOLS to find the license and location to start the license software (lazy!!! make your life to be easy before paying for it).
I think it's no problem for the most of users to install EXCEED,even if you've met problems for it. Reinstall it, and eliminate whole files which was made by GABIMT at  "C:\fluent.inc\ntbin\ntx86", but make sure not to throw other" ..exe" files away!!!! otherwise you will meet other troubles!
(3) For PLUENT customers, if you are not sure to use LMTOOLS correctly
Please follow (1) with D version consumer to make your life easier, that's silly Auncle Sam's offering for the most lovely D version consumers.
Have you gotten it ? Yes, you have.
发表于 2004-8-27 18:34:53 | 显示全部楼层
你把目录中所有default文件删掉再试一下看看。
 楼主| 发表于 2004-8-27 21:19:37 | 显示全部楼层
谢谢大家,问题解决了,是我没装exceed,呵呵,没办法,谁让我是新手呀。
