各位好朋友们,我想问一下下面给出的gambit生成网格错误怎么解决.请耐心看看!!
我生成体volume.8后,在体上的edges上生成线网格,然后直接对体采用Tet/Hybrid-> Tgrid生成体网格。出现错误如下:(可否告诉一下怎么检查?我是这么检查的,我先删体网格,对面网格检查,非常OK,查不出错误来呀,怎么办呢?)
Error: volume mesh "volume.8" tetrahedral size 1
remove duplicate nodes before meshing:
TG_mesh_Domain failed with error code 1
Error: Tetrahedral meshing has failed for volumen volume.8
提示:
This is usually caused by problems in the face meshes. Check the skewnesses of your face meshes and make sure the face mesh sizes are not too large in areas of small gaps.
谢谢各位朋友们耐心看完,还希望给点建议!!
祝大家国庆节愉快!!
