查看: 6188|回复: 1
求助!ansys17.0安装后无法运行
发表于 2019-1-30 21:58:48 | 显示全部楼层 |阅读模式
ansys17.0安装后无法运行,多次重装也无法解决,一直显示如下:
ANSYS LICENSE MANAGER ERROR:Failover feature 'ANSYS Academic Teaching CFD' specified in license preferences is not available.
Request name aa_t_cfd does not exist in the licensing pool.
SIGN= keyword required but missing from the license certificate.
This is probably because the license is older than the application
You need to obtain a SIGN= version of this license from your vendor.
Feature:       aa_t_cfd
Missing:       SIGN2=
License path:  C:\PROGRA~1\ANSYSI~1\Shared Files\Licensing\license.dat;
FlexNet Licensing error:-114,582
For further information, refer to the FlexNet Licensing documentation,
available at "www.flexerasoftware.com".
Cannot find license file.
The license files (or license server system network addresses) attempted are
listed below.  Use LM_LICENSE_FILE to use a different license file,
or contact your software provider for a license file.
Feature:       fluent
Filename:      C:\PROGRA~1\ANSYSI~1\v170\fluent\license\win64\..\license.dat
License path:  C:\PROGRA~1\ANSYSI~1\v170\fluent\license\win64\..\license.dat
FLEXnet Licensing error:-1,359.  System Error: 2 "No such file or directory"
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
Hit return to exit.
Unexpected license problem; exiting.
恳请各位大神指导解决!
发表于 2019-2-1 23:29:48 来自手机 | 显示全部楼层
感觉是证书问题
