查看: 3604|回复: 1
there is no active application
发表于 2021-12-3 15:45:24 | 显示全部楼层 |阅读模式
各位前辈请问这个错误是什么原因导致的
 楼主| 发表于 2021-12-3 17:00:31 | 显示全部楼层
Error: There is no active application.
Error Object: (case-modified?)
Error: No journal response to dialog box message:'There is no active application.'
. Internally, cancelled the dialog.
Error Object: (rp-var-value 'delta-time-sampled)
这个是具体错误
Error Object: (%inquire-equations 1 'init)
Error Object: (get-current-context)
