查看: 2628|回复: 2
有关松弛系数的问题,希望大家参与讨论
发表于 2004-3-29 19:18:54 | 显示全部楼层 |阅读模式
False-time step relaxation:applied to all solved variables,except P1,R1,R2,RS(?)in the form of positive number
Linear relaxation :all stored variables can use it ,including P1,R1,R2,RS,KE,EP,in the form of negative number
The value of false-time step relaxation:Usually it base on some characteristic time-scale(?),normally the smallest one will be used ,multiplied by some factor(?).
A typical starting point:the domain length divided by the inlet velocity divided by the the number of cells in that direction
以上是我看phoenics文件总结出来的,但是看完后还是不知道如何去确定松弛系数,不知道大家看完后有什么想法?请赐教哦:)上面代问好的地方,是小女子不明白的地方,即不知道她们的具体含义,也请赐教哦:)
发表于 2004-3-30 15:05:32 | 显示全部楼层
有关松弛系数的问题,希望大家参与讨论
RS....standard name used to denote the second-phase shadow volume fraction, i.e. that which would be present in the absence of inter-phase mass-transfer. RS is especially useful for the simulation of particle combustion
) FALSDT; ie False-time-step relaxation
Its effect is to add to the phi-balance for each cell a source equal to:
(latest_phi - next_phi) * (mass in cell) / DTFALS(phi)
where latest_phi is the current value of the variable being solved for, and next_phi is that which it will take after adjustment.
This has the effect of making next_phi very close to latest_phi when DTFALS is large, so that changes can occur only after many repetitions of the adjustment process.
A value of DTFALS=1.E-20 would prevent change entirely on many machines, a fact which it is sometimes convenient to exploit, for example when seeking to understand the causes of divergence.
PATCH-wise false-time step under-relaxation can be introduced by means of PATCH and COVAL by using the name SAME in the fourth argument of COVAL. See SAME for further information
这是polis中的文档
 楼主| 发表于 2004-3-30 22:02:04 | 显示全部楼层
有关松弛系数的问题,希望大家参与讨论
This has the effect of making next_phi very close to latest_phi when DTFALS is large, so that changes can occur only after many repetitions of the adjustment process. 这段话是说当DTFALS较大时,变化很难产生
A value of DTFALS=1.E-20 would prevent change entirely on many machines, a fact which it is sometimes convenient to exploit, for example when seeking to understand the causes of divergence.这段话诗句个例子,当DTFALS=1.E-20 (应该是很小的数吧)时,would prevent change entirely on many machines。
这两段话是不是矛盾啊,还是我理解的不对啊?
