查看: 2154|回复: 2
紧急求救
发表于 2004-4-16 17:54:28 | 显示全部楼层 |阅读模式
为什么我建立的模型不能运行呢?大家帮忙看看吧,我的RESUNLT文件如下所示:
         CCCC HHH        PHOENICS Version 3.4.0 - EARTH
      CCCCCCCC     H     (C) Copyright 2001
    CCCCCCC    See   H   Concentration Heat and Momentum Ltd
   CCCCCCC   our new  H  All rights reserved.
   CCCCCC    Web-site  H  Address:  Bakery House, 40 High St
   CCCCCCC  www.cham. H  Wimbledon, London, SW19 5AU
    CCCCCCC   co.uk  H   Tel:       0208-947-7651
      CCCCCCCC     H     Fax      : 0208-879-3497
         CCCC HHH        E-mail:  phoenics@cham.co.uk
  This program forms part of the PHOENICS installation for:
                   CHAM
  The code expiry date is the end of : Mar 2004
RDDF10: Error reading COVAL data (2)
RDDF10: Error reading COVAL data (3)
  C5GR: Yccha, Ycvol =     4.563943E-01    1.469057E-01
  C5GR: Yvold, Ychad =     3.176702E-01    5.653298E-01
  C5GR: Yvol =     3.597624E-01
  C5GR: x in CHx =         2.957000
  C5GR: Ychxvol=     5.764018E-01 Yo2vol=     3.132179E-01
  C5GR: Heat Vol -> CO2, MJ/Kg C =        67.465027
  C5GR: Heat Vol -> CO,  MJ/Kg C =        43.875023
C5GR: Source relaxation:
VAPO X1  1.00E+00 X2  1.00E+00 Y1  3.00E-01 Y2  3.00E-01TIPO-1.00E+00
QDOT X1  1.00E+00 X2  1.00E+00 Y1  3.00E-01 Y2  3.00E-01TIPO-1.00E+00
BOUT X1  1.00E-01 X2  1.00E+20 Y1  3.00E-01 Y2  1.00E-20TIPO-4.00E+00
VRAT X1  1.00E+00 X2  1.00E+00 Y1  3.00E-01 Y2  3.00E-01TIPO-1.00E+00
COM1 X1  1.00E+00 X2  1.00E+00 Y1  3.00E-01 Y2  3.00E-01TIPO-1.00E+00
COM2 X1  1.00E+00 X2  1.00E+00 Y1  3.00E-01 Y2  3.00E-01TIPO-1.00E+00
  LITER (COM1) =            1
  LITER (COM2) =            1
          material properties used are...
denst1
cmprs1
vistrb
visclm
tempr1
mixln1
thrme1
speht1
denst2
tempr2
thrme2
speht2
intfco
     also, other related settings are ...
usegrx  =    T
usegrd  =    T
Number of F-array locations available is        30000000
Number used before BFC allowance is             39975883
* 3D velocity coeffs stored out of core
Number used before BFC allowance is             37637323
* Dependent variables stored out of core
Number used before BFC allowance is             21690763
Number used after BFC allowance is              21690763
好急啊,大家办帮帮忙啊,不胜感激!
发表于 2004-4-18 09:56:03 | 显示全部楼层
紧急求救
你为什么不把Q1贴出来??
 楼主| 发表于 2004-4-19 08:53:34 | 显示全部楼层
紧急求救
哦,我计算的时候,系统提示说有错误,让参看result文件,我看不懂,所以就把结果文件贴出来了。现在这个问题已经解决了,是因为我模型中的一层入口在实际过程中是不通风的,所以我就让那一层入口的属性只全部设置为0.0,这样就导致了读数的错误了,还由就是模型入口太注重实际,导致网格特别复杂,这也使得计算不能进行。但是我现在一直算不收敛,真是好头痛啊.......
