查看: 2357|回复: 2
请教patch的名称如何在手册中查询及它们的使用方法,比如BUOYANCY,WWEST等
发表于 2004-5-8 19:01:52 | 显示全部楼层 |阅读模式
Group 13. Boundary & Special Sources
PATCH (BUOYANCY,PHASEM,0,0,0,0,0,0,1,1)
COVAL (BUOYANCY,U1  , FIXFLU      , GRND2       )
COVAL (BUOYANCY,V1  , FIXFLU      , GRND2       )
COVAL (BUOYANCY,W1  , FIXFLU      , GRND2       )
BUOYA   = 0.000000E+00 ; BUOYB =-9.810000E+00
BUOYC   = 0.000000E+00
BUOYD   = 1.189000E+00
还有
PATCH(WWEST,WWALL,1,1,1,12,4,18,1,1)
COVAL(WWEST,Wl,GRND2,0. 0);COVAL(W WEST,V1,GRND2,0. 0)
COVAL(WWEST,KE,GRND2,GRND2)
COVAL(WWEST,EP,GRND2,GRND2)
这里的BUOYANCY,WWEST分别代表什么意思啊,在手册的哪部分可以查到?
发表于 2004-5-9 09:10:54 | 显示全部楼层
WWEST是指壁面(WALL)的西面,具体可看polis,地址如下
..phoenics/D_POLIS/D_ENC/WALL.HTM#walls
发表于 2004-5-9 09:14:08 | 显示全部楼层
BUOYA... is used by GXBUOY to carry the gravitational acceleration in the x-direction.
In the GRND4 (or LINBC) option for GRAVitational source terms, BUOYC is used as a constant in a linear function of two variables for the VALue.
u can find the detail at this page:
...phoenics/D_POLIS/D_ENC/ENC_B.HTM#buoy
