查看: 2732|回复: 13
NUSSELT NUMBER COMPUTATION FOR TURBULENT HEAT TRANSFER
发表于 2004-7-21 21:13:38 | 显示全部楼层 |阅读模式
BY : CHAM Technical Support
DATE : March 2003
PHOENICS Version : 3.5 (Dec 2002)
INTRODUCTION :
The case considered is a steady, turbulent, axisymmetric heated jet impinging on a block of lightweight concrete. The task is to predict the distribution of the heat-transfer coefficient and Nusselt number along the block.
The Reynolds number of the jet is 20,000 and it discharges at 500 deg C into ambient at 25 deg C. The jet is located 3.75 nozzle diameters above the concrete block, which has a thickness of 1.25 nozzle diameters.
The standard k-e model is used in the calculations.
A polar computational grid of 40 radial and 40 axial cells is used. The outer boundary of the solution domain is located 4 nozzle diameters from the jet axis.
All model settings have been made in a VR-based Q1 of PHOENICS 3.5.
The IN-FORM facility is used to compute both the Nusselt number and heat transfer coefficient distribution along the surface of the block.
DEFINITION OF NUSSELT NUMBER AND HEAT TRANSFER COEFFICIENT :
The Nusselt number is defined as a function of radius r along the surface by:
    Nu (r) = h(r)*d/k
where h is the heat transfer coefficient (HTC), d is the nozzle diameter, and k is the gas laminar thermal conductivity. The HTC is defined by:
    h(r) = qw(r)/(Tw(r) - Tj)
where qw is the wall heat transfer rate per unit area, Tw is the wall temperature, and Tj is the jet discharge temperature. Tw can be computed from a thermal balance at the gas-solid interface, i.e.
    Tw = (bs*Ts + bg*Tg)/(bs + bg)
where Ts and Tg are the solid and gas temperatures with bs = ks/ds and bg = a. Here, ks is the solid thermal conductivity, ds is the wall-to-solid node distance, and a is the local heat transfer coefficient computed by the PHOENICS wall functions, defined by:
   a(r) = qw(r)/[Tg(r) - Tw(r)]
THE USE OF INFORM :
As a pre-cursor to defining the INFORM statements, the following whole-field stores are assigned in the 'Models' section of the VR Editor: HTCO (PHOENICS-recognised name for the surface htc based on local conditions); QWAL (user-defined name for the local wall heat transfer rate); TWAL (defines the surface temperature); HTCB (defines the surface htc based on reference conditions); and NUSS (defines the surface Nusselt number).
The INFORM commands for generation of the surface heat-transfer coefficient HTC and Nusselt number Nu have been inserted after the STOP statement in the Q1 file. This has been done from the VR Environment by clicking on 'File'>'Open file for editing'>'Q1'. The following INFORM sequence is used:
** Compute Nu distribution along plate on the last sweep
CHAR(PART1,PART2)
** +1 refers to high-z slab otherwise current z slab
PART2=((KOND[&&+1]/(0.5*DZW[&&+1]))*TEM1[&&+1]+HTCO*TEM1) PART1=((KOND[&&+1]/(0.5*DZW[&&+1]))+HTCO)
** compute surface temperature
(STORED OF TWAL at SURF is PART2/PART1 with IF(ISWEEP.EQ.LSWEEP))
** compute surface heat flux
(STORED OF QWAL at SURF is HTCO*(TEM1-TWAL) with IF(ISWEEP.EQ.LSWEE$
P))
** compute bulk heat-transfer coefficient
CHAR(TJET,TAMB,DIAM);TJET=500.0;TAMB=25.0;DIAM=0.04
(STORED OF HTCB at SURF is ABS(QWAL/(:TJET:-TWAL)) with IF(ISWEEP.E$
Q.LSWEEP))
** compute bulk nusselt number
(STORED OF NUSS at SURF is HTCB*IAM:/KOND with IF(ISWEEP.EQ.LSWEE$
P))
The relevant Q1 file can be inspected and downloaded by clicking here.
发表于 2004-7-22 09:10:54 | 显示全部楼层
怎么没有q1文件啊,请phoencis在发一下吧!
发表于 2004-7-22 09:27:35 | 显示全部楼层
还有这是在3.5版本上运行,3.4可以么?我用的是3.4版本。另外:
where Ts and Tg are the solid and gas temperatures ,其中Ts与Tw有什么区别阿?谢谢各位大虾!
发表于 2004-7-23 14:51:56 | 显示全部楼层
希望phoenics看到后能把q1文件上传上来,谢谢先!
发表于 2004-7-26 09:53:43 | 显示全部楼层
ding一下
发表于 2004-7-27 14:18:35 | 显示全部楼层
最近这么冷清阿/
 楼主| 发表于 2004-7-27 18:48:31 | 显示全部楼层
TALK=T;RUN( 1, 1)
   Q1 created by VDI menu, Version 3.5, Date 08/10/02
CPVNAM=VDI;SPPNAM=Core
IRUNN   =       1 ;LIBREF =       0
  Group 1. Run Title
TEXT(INFORM - Nusselt number computation     )
  Group 2. Transience
STEADY  =    T
  Groups 3, 4, 5  Grid Information
    * Overall number of cells, RSET(M,NX,NY,NZ,tolerance)
RSET(M,1,40,40)
    * Cylindrical-polar grid
CARTES=F
  Group 6. Body-Fitted coordinates
  Group 7. Variables: STOREd,SOLVEd,NAMEd
ONEPHS  =    T
    * Non-default variable names
NAME(135) =HTCB ; NAME(137) =ENUL
NAME(138) =TWAL ; NAME(139) =YPLS
NAME(140) =STAN ; NAME(141) =HTCO
NAME(142) =SPH1 ; NAME(143) =DEN1
NAME(144) =ENUT ; NAME(145) =QWAL
NAME(146) =MACH ; NAME(147) =EPKE
NAME(148) =PRPS ; NAME(149) =TEM1
NAME(150) =KOND
    * Solved variables list
SOLVE(P1  ,V1  ,W1  ,TEM1)
    * Stored variables list
STORE(KOND,PRPS,EPKE,MACH,QWAL,ENUT,DEN1,SPH1)
STORE(HTCO,STAN,YPLS,TWAL,ENUL,HTCB)
    * Additional solver options
SOLUTN(P1  ,Y,Y,Y,N,N,Y)
SOLUTN(TEM1,Y,Y,Y,N,N,Y)
TURMOD(KEMODL)
  Group 8. Terms & Devices
NEWRH1  =    T
NEWENL  =    T
DENPCO  =    T
  Group 9. Properties
PRESS0  = 1.000000E+05 ;TEMP0  = 2.730000E+02
SETPRPS(1,  2)
DRH1DP  = GRND5
DVO1DT  = 3.330000E-03
PRNDTL(TEM1) = -2.630000E-02
PRT   (EP  ) =  1.314000E+00
  Group 10.Inter-Phase Transfer Processes
  Group 11.Initialise Var/Porosity Fields
FIINIT(PRPS) = -1.000000E+00
   No PATCHes used for this Group
INIADD  =    F
  Group 12. Convection and diffusion adjustments
  Group 13. Boundary & Special Sources
PATCH (SURF    ,CELL  ,5,0,0,0,0,0,1,2)
EGWF    =    T
  Group 14. Downstream Pressure For PARAB
  Group 15. Terminate Sweeps
LSWEEP  =     700
SARAH   = 5.000000E-02
RESFAC  = 1.000000E-03
  Group 16. Terminate Iterations
LITER (P1  ) =       50 ;LITER (TEM1) =       50
  Group 17. Relaxation
RELAX(P1  ,LINRLX, 1.000000E+00)
RELAX(V1  ,FALSDT, 1.000000E-02)
RELAX(W1  ,FALSDT, 1.000000E-02)
RELAX(KE  ,LINRLX, 5.000000E-01)
RELAX(EP  ,LINRLX, 5.000000E-01)
RELAX(TEM1,LINRLX, 3.000000E-01)
KELIN   =       3
  Group 18. Limits
VARMAX(V1  ) = 1.000000E+06 ;VARMIN(V1  ) =-1.000000E+06
VARMAX(W1  ) = 1.000000E+06 ;VARMIN(W1  ) =-1.000000E+06
  Group 19. EARTH Calls To GROUND Station
USEGRD  =    T  ;USEGRX =    T
GENK    =    T
ASAP    =    T
IDISPB  =       1 ;IDISPC =      30
  Group 20. Preliminary Printout
ECHO    =    T
  Group 21. Print-out of Variables
  Group 22. Monitor Print-Out
IXMON   =       1 ;IYMON  =      40 ;IZMON  =      30
NPRMON  =  100000
NPRMNT  =       1
TSTSWP  =      -1
  Group 23.Field Print-Out & Plot Control
NPRINT  =  100000
NYPRIN  =       1
IYPRF   =       1 ;IYPRL  =      40
NZPRIN  =       1
IZPRF   =      28 ;IZPRL  =      36
YZPR    =    T
ISWPRF  =       1 ;ISWPRL =  100000
ITABL   =       2
  Group 24. Dumps For Restarts
NOWIPE  =    T
IDISPA  =       1 ;IDISPB =       1 ;IDISPC =      30
CSG1    ='N'
CSG2    ='C'
GVIEW(P,-9.004471E-01,0.000000E+00,-4.349655E-01)
GVIEW(UP,4.349655E-01,0.000000E+00,-9.004471E-01)
> DOM,    SIZE,        1.000000E-01, 1.600000E-01, 2.000000E-01
> DOM,    MONIT,       5.000000E-02, 1.580000E-01, 1.475000E-01
> DOM,    SCALE,       1.000000E+00, 1.000000E+00, 1.000000E+00
> DOM,    SNAPSIZE,    1.000000E-02
> OBJ,    NAME,        OUTLETSI
> OBJ,    POSITION,    0.000000E+00, 1.600000E-01, 0.000000E+00
> OBJ,    SIZE,        1.000000E-01, 0.000000E+00, 1.500000E-01
> OBJ,    CLIPART,     cube12t
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        OUTLET
> OBJ,    PRESSURE,      0.000000E+00
> OBJ,    TEMPERATURE,   2.500000E+01
> OBJ,    COEFFICIENT,   1.000000E+03
> OBJ,    TURBULENCE,   -1.026000E+04,-1.026000E+04
> OBJ,    NAME,        JET
> OBJ,    POSITION,    0.000000E+00, 0.000000E+00, 0.000000E+00
> OBJ,    SIZE,        1.000000E-01, 2.000000E-02, 0.000000E+00
> OBJ,    CLIPART,     cube3t
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        INLET
> OBJ,    VELOCITY,      0.000000E+00, 0.000000E+00, 4.000000E+01
> OBJ,    TEMPERATURE,   5.000000E+02
> OBJ,    TURB-INTENS,   5.000000E+00
> OBJ,    NAME,        CONCRETE
> OBJ,    POSITION,    0.000000E+00, 0.000000E+00, 1.500000E-01
> OBJ,    SIZE,        1.000000E-01, 1.600000E-01, 5.000000E-02
> OBJ,    CLIPART,     cube14
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        BLOCKAGE
> OBJ,    MATERIAL,      122
> OBJ,    INI_TEMP,      2.500000E+01
> OBJ,    NAME,        OUTTOP
> OBJ,    POSITION,    0.000000E+00, 2.000000E-02, 0.000000E+00
> OBJ,    SIZE,        1.000000E-01, 1.400000E-01, 0.000000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        OUTLET
> OBJ,    NAME,        SURF
> OBJ,    SIZE,        1.000000E-01, 1.600000E-01, 0.000000E+00
> OBJ,    CLIPART,     poldef
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        USER_DEFINED
STOP
  coefficient and Nusselt number along the block. The Reynolds
  1.25 nozzle diameters. The standard k-e model is used in the
  calculations. A polar computational grid of 40 radial and 40
  is located 4 nozzle diameters from the jet axis. All model
  settings have been made in VR-based Q1 of PHOENICS 3.5. The
  of the block.
  ** Compute Nusselt number distribution along plate
     on the last sweep
CHAR(PART1,PART2)
P))
Q.LSWEEP))
P))
发表于 2004-7-28 09:18:28 | 显示全部楼层
真是太感谢phoenics了!
发表于 2004-7-28 09:44:21 | 显示全部楼层
怎么不能运行啊,我运行run=>earth然后屏幕一闪而过,我没有改动模型。模型的问题还是我软件的问题,我的软件只有core,是因为模型中用inform编程的原因么?
发表于 2004-7-28 09:49:33 | 显示全部楼层
这是result文件中提示:
              message from function l0mat
??? imat=      -1
prps value does not correspond to those
placed by SATELLITE in eardat. INIAD=T ?
If you need this material, insert in Q1
SPEDAT(SET,MATERIAL, -1,L,T)
发表于 2004-7-28 09:56:45 | 显示全部楼层
我发现在调入q1文件后
,vr中的模型显示只有一个物体模型,其他的根本没有调入,这是什么原因呢?
 楼主| 发表于 2004-8-5 21:23:39 | 显示全部楼层
把下面的命令写入Q1文件,试试看
发表于 2004-8-6 09:26:36 | 显示全部楼层
写在q1中的那一部分呢?group?是物性设置那一group么?还是任意放置就可以?
发表于 2004-8-7 09:13:15 | 显示全部楼层
试了一试还是不能运行,我把SPEDAT(SET,MATERIAL, -1,L,T)放在物性设置那一group里面了。
