查看: 1923|回复: 0
[求助]cfx收敛后出现一个notice请高手指教该如何处置呀。
发表于 2005-4-15 16:10:56 | 显示全部楼层 |阅读模式
|                     ****** Notice ******                           |
| Newtons method failed to converge in  100 iterations.  This        |
| occured while computing the following variable:                    |
| Variable Name  : Temperature                                       |
| Location Name  : twister                                           |
| Mesh location  : VERTICES                                          |
| Mesh entity    :                                                   |
| Last 3 Changes :  2.18547E+02  2.18547E+02  2.18547E+02            |
| Tolerance      :  1.0000E-02                                       |
| The Newton iteration was either slowly converging or has stalled.  |
| The solver will continue with the variable set as it was on the    |
| final iteration.  If this situation continues you might try        |
| increasing the number of iterations allowed for Newtons method.    |
| This can be changed by setting one of the parameters:              |
| Temperature : "Constitutive Relation Iteration Limit"              |
| Pressure    : "Newton Pressure Iteration Limit"                    |
| for your mixture using the definition file editor.                 |
