查看: 2657|回复: 1
这是怎么回事?
发表于 2006-11-26 14:59:48 | 显示全部楼层 |阅读模式
用cfx计算时出现这样的问题是怎么回事啊?
A wall has been placed at portion(s) of an OUTLET                 |
|  boundary condition (at   1.0% of the faces,   1.5% of the area)   |
|  to prevent fluid from flowing into the domain.                    |
|  The boundary condition name is: outlet.                           |
|  The fluid name is: Water.                                         |
|  If this situation persists, consider switching                    |
|  to an Opening type boundary condition instead.
发表于 2006-11-27 22:27:07 | 显示全部楼层
这是怎么回事?
出口有回流,计算中CFX在回流处设置了wall边界条件,防止回流。
你可以设置成openging边界条件或者将出口设置在没有回流的区域。
