查看: 4678|回复: 2
[求助]动网格中的负网格???
发表于 2007-5-29 17:27:59 | 显示全部楼层 |阅读模式
我在做和粒子中差不多的一个项目(free surface),但是在算一个方案的时候,前面的计算稳态初场的时候,计算没有问题,但是在计算动网格,网格移动就出现负网格,不知咋回事,清高手指点。下面是出错信息
Parallel run: Received message from slave
Slave partition :        2
Slave routine   : cVolSec
Master location : RCVBUF,MSGTAG=1020
Message label   : 002100012
Message follows below - :
| ERROR #002100012 has occurred in subroutine cVolSec.               |
| A negative element volume has been detected.  This is a fatal      |
| error and execution will be terminated.  The location of the first |
| negative volume is reported below.                                 |
|     Volume   :  -0.8412E-08                                        |
|     Location : (  0.78521E+00,  0.18607E+00,  0.45017E+00)         |
Slave partition :        2
Slave routine   : ErrAction
Message label   : 001100279
| ERROR #001100279 has occurred in subroutine ErrAction.             |
| c_fpx_handler: Floating point exception: Invalid Operand           |
Slave partition :        2
| Stopped in routine c_fpx_handler:                                  |
|                An error has occurred in cfx5solve:                 |
| The CFX-5 solver exited with return code 1.   No results file has  |
| been created.                                                      |
End of solution stage.
发表于 2007-5-30 09:44:51 | 显示全部楼层
[求助]动网格中的负网格???
网格变形太大,产生负体积了。
 楼主| 发表于 2007-5-30 10:34:22 | 显示全部楼层
[求助]动网格中的负网格???
哦,明白了,多谢大版主!
