查看: 2552|回复: 2
cfx-post怎么画这样的流线
发表于 2007-8-12 13:01:12 | 显示全部楼层 |阅读模式
cfx-post怎么画图中的流线?[br][br][以下内容由 yuqh103 在 2007年08月12日 01:01pm 时添加] [br]
 楼主| 发表于 2007-8-12 13:02:05 | 显示全部楼层
cfx-post怎么画这样的流线
发表于 2007-8-13 09:11:26 | 显示全部楼层
cfx-post怎么画这样的流线
你做一下CFX第一个例子就知道如何做了。
From the main menu, select Insert > Streamline.
Under Definition, in Start From, ensure that Inlet is set.
To create streamlines originating from more than one location, click the ellipsis icon to the right of the Start From box. This displays the Location Selector dialog box, where you can use the <Ctrl> and <Shift> keys to pick
multiple locators.
Set Mode to Variable.
Set Variable to Velocity.
Set Range to Local.
Click Apply.
