查看: 3775|回复: 1
[求助]cfx计算流固耦合出错
发表于 2007-12-22 13:46:04 | 显示全部楼层 |阅读模式
在用ansys cfx计算流固耦合的模型(均为非结构化网格)时,出现以下错误信息:
ERROR #001100279 has occurred in subroutine erraction.
Message:
SYMASS_CS_ELIM:The solver ran out of temporary space while building a linked list for a domain.Try setting the expert parameter"topology estimate factor" to a value greater than 1.0,values higher than 1.2 should not be necessary.
  请教一下这是什么问题引起的错误。谢谢。
发表于 2007-12-30 11:55:59 | 显示全部楼层
[求助]cfx计算流固耦合出错
这个不是很好说的,你可以把模型放上来,大家讨论一下
