查看: 2782|回复: 3
How to setup the STAR/kinetics module?
发表于 2005-4-19 17:31:30 | 显示全部楼层 |阅读模式
Hello, everyone,
Does your STAR/kinetics module available in 3.2X work properly? I pre-process the chemical scheme as required through Star-CD GUI but it does not work at all. The same reaction in Chemical Kinetics works.
The error is:
"STAR/KINetics has not been installed. Please check your installation."
However, I have already installed this module and I can find some STAR/KINetics files in my installion directory. what';s happened? Is it the bug of STAR_PNP as described in star3.20 release notes? How should I do to solve this problem? Thanks a lot!
BTW, my current Star-CD version is 3.22.
发表于 2005-4-28 21:28:14 | 显示全部楼层
this module is an add-on module sold by React-Design company. make sure you have bought it.
发表于 2005-5-2 00:21:42 | 显示全部楼层
D版的可能会全吧?
我不知道React-Design 的这个kinetics为什么在Chemkin中找不到,
就是使用帮助也没有?为什么?
发表于 2005-5-4 15:50:35 | 显示全部楼层
唉唉唉
這就是STARCD就算有D版也不太用怕的原因
因為要進到更深的設計分析層面
沒有原廠的協助是很難完成這樣的工作地
這問題也不用問我
因為小弟也不太會
STARCD太全面了
我沒有實際做過燃燒的問題
動態網格除了風扇的分析會外其他也不熟
兩相流的設計分析小弟也僅知道皮毛
所以囉
有些問題小弟遲遲沒有回是因為
真的不會
一些細節如資料的擷取除非常用否則不太曉得
出來工作時間很忙
也不可能像以前一樣可以慢慢學習
