查看: 3596|回复: 6
请各位帮忙
发表于 2006-2-19 21:54:38 | 显示全部楼层 |阅读模式
MAXIMUM COURANT NUMBER =  2.563E+07 AT CELL  606784 MEAN COURANT NUMBER =  1.174E+03
    RESIDUAL REDUCTION:
     RESU = 9.78713E+01 RESV = 3.37665E+01 RESW = 1.04434E+01 RESP = 6.42805E+03
*** WARNING #013 *** MAXIMUM SPECIFIED CORRECTOR STAGES  20 REACHED BEFORE CONVERGENCE CRITERION IS SATISFIED.
   <<<<U-MOMENTUM EQUATION NOT CONVERGED>>>>
   <<<<V-MOMENTUM EQUATION NOT CONVERGED>>>>
   <<<<W-MOMENTUM EQUATION NOT CONVERGED>>>>
   <<<<CONTINUITY EQUATION NOT CONVERGED>>>>
  ______________________________FIELD DATA_________________________________________________
  Field Extrema:
     Umax        Vmax        Wmax        VMAGmax     Pmax        TKEmax      EPSmax      Tmax        RHOmax
    2.0101E+08  6.5649E+07  8.9411E+06  2.1188E+08  2.9270E+10         INF         INF  7.9496E+06  1.2050E+00
     Umin        Vmin        Wmin        VMAGmin     Pmin        TKEmin      EPSmin      Tmin        RHOmin
   -1.8766E+07 -1.2578E+07 -1.6638E+07  5.1619E-04 -6.0583E+11  3.0590E-08  1.6030E-04  2.8849E+02  1.2050E+00
  Field Volume-Averages:
     Pvav        RHOvav      Tvav        TKEvav      EPSvav
          -NaN  1.2050E+00  3.6912E+02        -NaN        -NaN
  Field Mass-Averages:
     Pmav        RHOmav      Tmav        TKEmav      EPSmav
  Field Totals:
     Mass        Volume      TKE         EPS
    3.3930E+01  2.8158E+01        -NaN        -NaN
     Mass in     Mass accu.  Diff.
    1.8563E-05  0.0000E+00  1.8563E-05
  Field Solver information:
    NSU  =     4 NSV  =     4 NSW  =     3 NSP  =   187 NSTE =    10 NSED =     0 NST  =     0
    NUMBER OF PISO CORRECTORS= 20
  CPU TIME IS     3830.70    ELAPSED TIME IS     3838.00
  __________________________________________________________________________________________
  FLUID  1: YPLUSMAX=       INF AT CELL  583211;   YPLUSMIN= 4.068E+00 AT CELL  576611
  NUMBER OF INNER ITERATIONS/SWEEPS FOR VARIABLE:
        NSU  =       7 NSV  =       7 NSW  =       6 NSP  =    3526 NSTE =      22 NSED =       3 NST  =      51
           TOTAL NUMBER OF SWEEPS=      3622
  CPU TIME IS     3839.30    ELAPSED TIME IS     3847.30
我这个计算结束了吗?那个warning是什么意思啊?
                                         谢谢
发表于 2006-2-19 22:22:11 | 显示全部楼层
请各位帮忙
計算發散了
有可能是網格品質不好
也可能是條件設定不當
很難說明真正的原因
建議先把紊流選項關掉測試看看
若還有問題很可能就是網格的問題
 楼主| 发表于 2006-2-21 22:21:41 | 显示全部楼层
请各位帮忙
谢谢,我估计是边界的问题。是不是要设进口和压力边界,就不能有出口边界了。而且进口边界就需要压力,那压力边界和进口边界的压力有什么不同呢?
我要算的是排气管流场,压力是一波一波的,速度也是变化的,这应该怎么设定啊?
发表于 2006-2-22 13:02:24 | 显示全部楼层
请各位帮忙
進口也是壓力邊界
出口也是壓力邊界
只要這兩者的設定不一樣
壓力場就會產生速度場
所以這是ok地
也就是假設進出的壓力差去看流場
沒啥不行啊
 楼主| 发表于 2006-2-22 14:15:53 | 显示全部楼层
请各位帮忙
可是现在只知道进口压力和速度的具体值,要算的就是出口的参数,那是不是只把进口设压力边界,速度就不用设了?
发表于 2006-2-23 10:44:32 | 显示全部楼层
请各位帮忙
您不可以同時設進口壓力又設進口速度
建議不用管進口壓力值
直接設進口速度値
出口用OUTLET的邊界條件即可
記算完後查看進出口壓力差異即可
不需要強迫要設進口壓力
用換算地即可
反正在流道內
壓力損耗的差値跟您設的進口壓力值沒有關係
 楼主| 发表于 2006-2-23 20:58:23 | 显示全部楼层
请各位帮忙
哦,原来如此,受益拉,我算算看先
