查看: 3967|回复: 0
ADINA 流固耦合应用
发表于 2003-10-9 09:52:04 | 显示全部楼层 |阅读模式
This example presents a spring/mass-configuration, which is damped by the fluid viscosity. The spring (which presents the mass in this system) is slowly deflected. The spring oscillates with the representative natural frequency. The surrounding fluid damps the spring. Increasing the fluid velocity results in a higher damping.
