查看: 1886|回复: 1
计算正常终止,后处理实体却不见了
发表于 2005-5-20 14:55:50 | 显示全部楼层 |阅读模式
计算开始时出现以下信息,计算正常终止,可是,在后处理时,由这些结点所控制的实体却不见了,是什么原因呢?请指点一下,好吗?
0 t 0.0000E+00 dt 0.00E+00 flush i/o buffers
     solid element #   108300 failed at time   0.00000E+00
     node  number  #   108306 deleted   time   0.00000E+00
     node  number  #   146841 deleted   time   0.00000E+00
     node  number  #   146667 deleted   time   0.00000E+00
     node  number  #   137854 deleted   time   0.00000E+00
     node  number  #   137863 deleted   time   0.00000E+00
     solid element #   138767 failed at time   0.00000E+00
100 smallest timesteps
element                       timestep
solid    142088               0.33966E+01
solid    142051               0.33966E+01
solid    140375               0.33966E+01
solid    140372               0.33966E+01
solid    140364               0.33966E+01
f a i l e d   e l e m e n t   r e p o r t  time=    0.000E+00
      number of failed solid elements =   30468
      number of failed beam  elements =       0
      number of failed shell elements =       0
       1 t 0.0000E+00 dt 3.40E+00 flush i/o buffers
      97 t 7.9971E+01 dt 7.87E-01 write d3plot file
    2110 t 4.9976E+03 dt 3.36E+00 write d3plot file
    2110 t 5.0010E+03 dt 3.36E+00 write d3dump01 file
******** termination time reached ********
    2110 t 5.0010E+03 dt 3.36E+00 write d3plot file
N o r m a l    t e r m i n a t i o n
发表于 2005-5-20 16:47:58 | 显示全部楼层
计算正常终止,后处理实体却不见了
没遇到过,比较奇怪
呵呵,怎么会遇到这么恶心的问题呢,唉!
